What glue to use for replacing cockpit interior fabric
Old February 7th 08, 05:37 AM posted to rec.aviation.soaring
Default What glue to use for replacing cockpit interior fabric
Easy....first take off all the residual adhesive with a scotch brite
roloc pad on an air die grinder mandrel. Not very expensive but
effective without worry of hurting the underlying structure.
For adhesive.....3M 1300L. It's like contact cement on steroids,
holds up in the heat, and consequently is what they use to glue
interior fabric, carpet, insulation, plastic, leather...the list goes
on an on.....in everything from Cessna 150's to 747's. You know it's
good if they can use it to glue fabric to aluminum.
All this stuff is available from www.aircraftspruce.com or Brown Tool,
or probably even your local fbo. I think I've seen the roloc
scotchbright pads at the local Checker auto parts store.
Hope that helps.
Old February 8th 08, 06:13 PM posted to rec.aviation.soaring
Jim Vincent
3M77 spray contact cement. Mask off the areas you don't want sprayed. More
even than brush on and faster to apply. Did my old ship this way...tied out
in the sun for a few years, never a problem.
"Gary Emerson" wrote in message
t...
Greetings,
I've got a SH glider. Have ordered new cockpit interior fabric, and am
ready to glue them in. Old fabric is removed, but there is some residual
glue on the cockpit sides that is pretty well stuck that I'd prefer not to
have to remove.
Asked SH, but got no reply.
One pilot suggested Pliobond, but it has a stronger odor that lingers
after it dries that I'm really not very excited about.
Has anyone used the Weldwood contact cement successfully or is there
another lower odor cement/glue that is recommended???
Many thanks in advance!
Gary
Replacing Cockpit placards toad Soaring 9 March 28th 06 03:04 PM
Pirep on replacing interior plastic parts [email protected] Owning 1 April 12th 05 05:06 AM
Cobra Interior Carpet Glue Brian Iten Soaring 7 August 24th 04 05:35 AM
Looking for pics of SU-24 Fencer cockpit interior Boomer Naval Aviation 0 March 6th 04 12:43 AM
Looking for pics of SU-24 Fencer cockpit interior Boomer Military Aviation 0 March 6th 04 12:42 AM
