Robert M. Gary writes:
On Feb 6, 9:24*am, Mxsmanic wrote: writes: Fixed-wing aircraft taxi because their wheels reduce friction as they move forward on the ground. So, logically, spacecraft in the frictionless environment of outer space should immediately accelerate to the speed of light. No, it still takes energy to accelerate a mass, even in a frictionless environment. But the original post said that aircraft taxi because their wheels reduce friction. No mention of energy or force. So if the statement is true, movement results from a lack of friction alone, so zero friction should produce infinite speed (or lightspeed if one allows the speed of light as an absolute upper limit). However, space (especially near space) is not frictionless. Nor does friction produce acceleration. QED. |
Gee, where would the energy come from to cause the acceleration?
On Feb 6, 2:00*pm, Mxsmanic wrote: writes: And to answer your next post before you post it: What molecules? http://en.wikipedia.org/wiki/Outer_space "While not being an actual perfect vacuum, outer space contains such sparse matter that it can be effectively thought of as one. The pressure of interstellar space is on the order of 10 pPa (1×10-11 Pa)." So, no molecules. *And no friction. Even if you don't wish to consider the hard vacuum of space as perfect, with a pressure that is 10,000,000,000,000,000 times lower than that of Earth at sea level, the friction should be also that much lower, and thus the speed of a taxi should be trillions of times faster. *The speed of light is only fifteen million times faster than a 40-knot taxi, so nearly the speed of light might well be achieved long before any residual friction could have any effect. |
"Phil J" wrote
... Wrong. Wrong. Wrong. Fixed-wing aircraft can only achieve a stable taxi by keeping the CG between the forward and aft wheel points(WPs). This is why it is so important in aircraft design that the WPs be placed correctly. In the early days of aviation some designers placed all the wheels to one side of the CG, with the result that the aircraft was dynamically unstable in taxi. Sadly, many lives were lost before this phenomenon was understood. If the CG is placed correctly in relation to the WPs, the aircraft establishes taxi by moving the Earth beneath it. Turns are achieved by rotating the Earth. Flight is achieved by dropping the Earth down, and a landing is made by lifting it back up. Aerobatics involve combinations of lifting, dropping, and rotating. I hope this clears things up for everyone. Phil Hah...hah.... This is called the pilot's perspective: (s)he sits in the cockpit and the earth performs the requisite manoevers. |
Phil, to support your theory, I can tell you the earth weighs 130
pounds in my gravitional field (that's before breakfast. It gains a little after that.). On Feb 6, 1:58*pm, Phil J wrote: On Feb 6, 10:19*am, wrote: Fixed-wing aircraft taxi because their wheels reduce friction as they move forward on the ground. Wrong. *Wrong. *Wrong. Fixed-wing aircraft can only achieve a stable taxi by keeping the CG between the forward and aft wheel points(WPs). * This is why it is so important in aircraft design that the WPs be placed correctly. * In the early days of aviation some designers placed all the wheels to one side of the CG, with the result that the aircraft was dynamically unstable in taxi. *Sadly, many lives were lost before this phenomenon was understood. If the CG is placed correctly in relation to the WPs, the aircraft establishes taxi by moving the Earth beneath it. *Turns are achieved by rotating the Earth. *Flight is achieved by dropping the Earth down, and a landing is made by lifting it back up. *Aerobatics involve combinations of lifting, dropping, and rotating. I hope this clears things up for everyone. Phil |
On Feb 6, 11:24*am, Mxsmanic wrote:
writes: Fixed-wing aircraft taxi because their wheels reduce friction as they move forward on the ground. So, logically, spacecraft in the frictionless environment of outer space should immediately accelerate to the speed of light. http://en.wikipedia.org/wiki/Inertia -- Gene Seibel Gene & Sue's Flying Machine - http://pad39a.com/gene/ Because we fly, we envy no one. |
Mxsmanic wrote in
: writes: Fixed-wing aircraft taxi because their wheels reduce friction as they move forward on the ground. So, logically, spacecraft in the frictionless environment of outer space should immediately accelerate to the speed of light. No, it takes a few minutes. Don't you watch star trek? Bertie |
Mxsmanic wrote in
: writes: Space isn't frictionless dummy. Where does the friction come from? Klingons, fjukkwit! Bertie |
Mxsmanic wrote in
: writes: And to answer your next post before you post it: What molecules? http://en.wikipedia.org/wiki/Outer_space "While not being an actual perfect vacuum, outer space contains such sparse matter that it can be effectively thought of as one. A bit like the inside of your skull. Bertie |
yrb-49-taxi.jpg | [email protected] | Aviation Photos | 2 | September 25th 07 09:50 PM |
Hanoi Taxi | john smith | Piloting | 0 | April 27th 06 03:48 AM |
License To Taxi? | SteveT | Piloting | 29 | October 16th 05 04:57 PM |
Leaning for taxi | Jim Rosinski | Piloting | 28 | September 12th 04 03:53 AM |
taxi in reverse? | [email protected] | Owning | 20 | February 21st 04 12:26 AM |
