Updating KLN 94 - Parallels Mac OS X
Old February 10th 08, 12:33 AM posted to rec.aviation.owning
Andrew Andersen[_2_]
Default Updating KLN 94 - Parallels Mac OS X
Hi
Has anyone been successful in updating a Honeywell Bendix-King KLN 94
(or 89/B) database via "direct cable connection" from the computer to
the KLN94's serial port using an Intel Apple Mac running Windows under
Parallels? The Mac doesn't have a serial port so it is necessary to use
a USB serial adapter.
I'm particularly interested in knowing precisely what USB serial adapter
you used and with which build of Parallels.
I have tried with a Keyspan USA-19HS, both using the Windows XP drivers
and via a socket to the OS X port without success. Honeywell BK list a
Belkin F5U 103 and iConcepts 60446 but neither of these are readily
available here in Australia.
I realise this sounds weird (and maybe too ambitious), but the Honeywell
BK GPS Database Loader is the last remaining problem to be solved before
I ditch my old laptop.
Thanks in advance
Andrew/.
tecsight@bigpondDOTnetDOTau
Old February 10th 08, 10:54 PM posted to rec.aviation.owning
Michelle[_1_]
Andrew Andersen wrote:
Hi
Thanks in advance
Andrew/.
never got it to work with the same setup. The problem was Parallels USB
driver translation. They keep claiming it has been fixed.
Old February 11th 08, 05:07 PM posted to rec.aviation.owning
Ross
Hi
Thanks in advance
Andrew/.
On a side note, I have a KLN89/B and use a laptop to update the
database. I want to get a new PC and they all come with Vista. I called
BK and the Dataloader is not yet compatible with Vista. Not sure when it
will be.
Regards, Ross
C-172F 180HP
KSWI
Old February 23rd 08, 08:54 PM posted to rec.aviation.owning
Hi
Parallels? *The Mac doesn't have a serial port so it is necessary to use
and via a socket to the OS X port without success. *Honeywell BK list a
Thanks in advance
Andrew/.
will be.
Regards, Ross
C-172F 180HP
KSWI- Hide quoted text -
- Show quoted text -
When it comes to USB to Serial adapters it's "Buyer Beware". I
purchased a $20 cable that I couldn't get to work using the updater
program on my HP laptop (no serial port) running Win XP. Called
Honeywell and they say that they have a few "supported" cables that
have been tested. They sent me to Radio Shack for a "supported" cable
that cost $35. I couldn't get that one running either. I ended up
getting an old Dell 266mhz laptop from a buddy that has a serial port
and is running Win XP (and nothing else) and it works great. I traded
him a couple him a couple of broken laptops for that one and it's sole
purpose in life now is updating the database on my 89B.
Paul
C172M - 175HP (or thereabouts with the Power Flow exhaust)
Old February 13th 08, 11:20 AM posted to rec.aviation.owning
Thanks for the input guys - looks like I'm not the only one..
I'll stick with the old Windows laptop, at least for the plane.
Andrew/.
updating AirChart IFR charts - PITA for everyone? [email protected] Instrument Flight Rules 15 February 18th 05 04:58 AM
Updating B-100 Paul M. Cordell Soaring 2 November 12th 04 02:10 AM
Help updating Garmin 195 software Dan White Owning 2 April 2nd 04 07:20 PM
