nrp wrote:
You could try brushing some STP on the outside of the exposed strut. It is amazing how a tiny amount of STP will reduce elastomeric seal friction for many cycles, but it will probably have to be replaced (rebrushed) every few weeks. From my experience in hydraulics, it would cut friction easily in half for many cycles. Good idea. Better yet, add a little STP to the hydraulic oil next time the strut is overhauled. Dry graphite powder works, as well. Happy Flying! Scott Skylane |
![]() You could try brushing some STP on the outside of the exposed strut. It is amazing how a tiny amount of STP will reduce elastomeric seal friction for many cycles, but it will probably have to be replaced (rebrushed) every few weeks. From my experience in hydraulics, it would cut friction easily in half for many cycles. In the "old days" (WWII), they sold sealed envelopes with a pad soaked in 5606 hydraulic oil especially for the purpose of keeping the strut oiled up. After some time, it was determined that keeping the polished struts oiled up and hanging in the breeze actually attracted more dirt and bunged up the seals anyway. So, the practice was discontinued. Go figure Mike |
![]() "Gus Cabre" wrote in message ... I have a sticky main strut in my Pa-28-151. My engineer has suggested changing the o-rings and valves of both struts. I was curious about the whole structure and have looked everywhere in the internet with no luck Any suggestions where I could find them? Gus Dear All, Thanks for the replies. Jay, I live in England and this winter is turning out to be quite warmish. So it's not the cold this time. In fact, she started sticking last summer. But as mentioned, by jiggling it before taxying, or just turning around bend on the way to the active, she would unstick. It wasn't a real problem until just before Xmas. As I was getting in, a friend jumped on. We are both biggish and I felt that strut give way. It sunk more than normal. The inspection has revealed that it practically lost all its nitrogen. And now there is a tiny leak. A friend of mine, an engineer for the UK PFA, something like your EAA, had a look and reckons the o-rings have "gone". He suggests changing them and the valve (!?). Hence, I will take it to my engineer but wanted to read more about the thing. Once again, thanks for your help. Gus EGWE |
![]() Jay, I live in England and this winter is turning out to be quite warmish. So it's not the cold this time. In fact, she started sticking last summer. But as mentioned, by jiggling it before taxying, or just turning around bend on the way to the active, she would unstick. It wasn't a real problem until just before Xmas. As I was getting in, a friend jumped on. We are both biggish and I felt that strut give way. It sunk more than normal. The inspection has revealed that it practically lost all its nitrogen. And now there is a tiny leak. A friend of mine, an engineer for the UK PFA, something like your EAA, had a look and reckons the o-rings have "gone". He suggests changing them and the valve (!?). Hence, I will take it to my engineer but wanted to read more about the thing. Ahhhh. Now that you mention that one has gone flat, that puts a different complexion on the discussion. A common technique to extend the life of a leaking seal that really does work is Granville Strut Seal. It is a bit of a chore to get the stuff into the struts, but most report that it does work well and can extend the life of leaking/sticking seals by several years. I actually used it to seal up a NEW nose strut seal job. It is relatively inexpensive, but then again so are a new set of seals and labor. And yes, it is recommended that the valve cores are replaced, if not the valve bodies too. Good Luck, Mike |
Mike,
Thanks for the advice. The engineer has suggested changing the seals and valves. However, I am concerned with the fact that a new set can stick relatively soon again. Oh well, we might then have to buy the Granville Strut Seal. Once again, thanks to all for the advice. Gus England "Mike Spera" wrote in message ... Jay, I live in England and this winter is turning out to be quite warmish. So it's not the cold this time. In fact, she started sticking last summer. But as mentioned, by jiggling it before taxying, or just turning around bend on the way to the active, she would unstick. It wasn't a real problem until just before Xmas. As I was getting in, a friend jumped on. We are both biggish and I felt that strut give way. It sunk more than normal. The inspection has revealed that it practically lost all its nitrogen. And now there is a tiny leak. A friend of mine, an engineer for the UK PFA, something like your EAA, had a look and reckons the o-rings have "gone". He suggests changing them and the valve (!?). Hence, I will take it to my engineer but wanted to read more about the thing. Ahhhh. Now that you mention that one has gone flat, that puts a different complexion on the discussion. A common technique to extend the life of a leaking seal that really does work is Granville Strut Seal. It is a bit of a chore to get the stuff into the struts, but most report that it does work well and can extend the life of leaking/sticking seals by several years. I actually used it to seal up a NEW nose strut seal job. It is relatively inexpensive, but then again so are a new set of seals and labor. And yes, it is recommended that the valve cores are replaced, if not the valve bodies too. Good Luck, Mike |
Oleo Struts | xerxes | Owning | 4 | September 7th 06 04:54 AM |
Cessna Struts | jls | Home Built | 7 | July 16th 05 03:26 PM |
Gas Struts for Clamshell Trailer | [email protected] | Soaring | 1 | April 26th 05 02:49 AM |
172 Nosewheel Struts Leak Nitrogen | jls | Owning | 4 | April 9th 04 06:28 PM |
Regulator/valve for filling struts | Ben Jackson | Owning | 5 | January 24th 04 03:12 AM |
