#11
One thing I've wondered is whether some of these "wing lift" incidents
are actually *wing drop* incidents. I don't have much ridge-time in full-scale gliders, but I have already experienced some good amounts of turbulence. There's nothing that says a turbulent parcel of air couldn't hit the wing that's closer to the ridge. After all, the wing closer to the ridge is also closer to the ground. Accordingly, that wing is possibly more exposed to turbulence caused by ground features - these can extend downwind (i.e. up-slope) to a distance of 10 or 20 times the height of the original object. For example, a 100-foot-tall tree can create turbulence over 1000 feet downwind of it. When I did slope- soaring with R/C gliders, we used to have to be VERY cautious of this - so its always in my mind when I visually scan the ridge ahead of me when in my cockpit. So imagine a situation where you're getting rocked by lift and turbulence, and all of a sudden the ridge-facing wing drops. Could you confidently distinguish that from a wing-lift on the opposite side if you're going through pulses of lift and sink, or turbulent roiling air? Of course, there's a BIG difference in what might be the best way to recover from those two different situations. With a wing-drop, you have a stalled condition - giving the aircraft full aileron to lower the upwind wing just increases the angle of attack on the stalled wing and doesn't make the situation any better. And if we're close to terrain we might subconsciously be pulling on the stick, too (again, not helpful to a stalled wing). ....Just some food for thought that a relative newbie like me wonders about at midnight (being a night-owl I tend to be obsessing over gliders at that time quite frequently *grin*). Take care, --Noel |
Noel,
You do make in interesting point in making that distinction. In that situation , rolling inverted so as not to stall the mountain side wing would seem the best way out alive without stalling or more probably spinning in. The main hindrance I think is most pilot's reluctance to actually deliberately go inverted and steer from that position and without stalling while inverted. I'm interested in thoughts on this issue, am I nuts? |
On Feb 15, 11:43 pm, tommytoyz wrote:
The main hindrance I think is most pilot's reluctance to actually deliberately go inverted and steer from that position and without stalling while inverted. I'm interested in thoughts on this issue, am I nuts? Its been proven how much lower the survival rate is for people who haven't had spin training and get into a spin. Do you really want to advocate that people should go into an unusual attitude that they are neither used to nor is their glider rated for, in a moment of confusion and stress? Can we expect them to stay oriented? Can we expect their aircraft to perform well invertted? Can we expect their aircraft to hold together under negative "G" loads while invertted? (especially if this is a rough/strong day on a mountain ridge)? --Noel |
Any chance of getting a link to the source of these
numbers. I just got the official statistics of Germany for 2007. 20 fatal accidents with German gliders involved (compared to 10 in 2006). 15 of them abroad, 12 in the French Alps. ------------------ Daniel Scopel Silent 2 Targa C-GODY serial 2027 Volez souvent et soyez prudent. http://pages. videotron. com/dscopel/ |
I actually saw Tom Madigan hit the Whites just east of Bishop. Most
of us thought he had experienced heat prostration, but after re- reading Henry Combs explanation I can see that Tom might have placed his sailplane in exactly the wrong position relative to the mountain. It was the second day of the 1985 regionals and hotter than hell, like 105! About 12:30 we started towing to the Whites which weren't working very well because the sun hadn't been hitting the western slopes very long. Several of us were slope-soaring back and forth without much success. Then I saw a ship circling and immediately headed for his location, figuring he had finally snagged a thermal. Just before getting there I saw the ship CRASH on a small plateau! The terrain was about 30 degrees up slope with a small plateau of maybe 100 feet across, then the mountain continued on up the 30 degree slope. Tom obviously turned because he had hit lift, lets say 300 fpm. Using Henry's explanation, that thermal would have been kicked off when rising hot air hit the edge of the plateau. When Tom's ship got between the thermal and the air coming down the mountain feeding his thermal, he may have been in exactly the wrong place at the wrong time. Let's say he had 300 fpm UP air under his LEFT wing and 200 fpm DOWN air on top of his RIGHT wing. Old Tom might not have had the aileron AUTHORITY to make the ship do his bidding? Food for thought, this would explain how a relatively weak 'first thermal' could have overpowered Tom's ship and also the Phoebus example in Henry's article which crashed about 10:45 in the morning JJ On Feb 15, 9:29*pm, "noel.wade" wrote: One thing I've wondered is whether some of these "wing lift" incidents are actually *wing drop* incidents. *I don't have much ridge-time in full-scale gliders, but I have already experienced some good amounts of turbulence. There's nothing that says a turbulent parcel of air couldn't hit the wing that's closer to the ridge. *After all, the wing closer to the ridge is also closer to the ground. *Accordingly, that wing is possibly more exposed to turbulence caused by ground features - these can extend downwind (i.e. up-slope) to a distance of 10 or 20 times the height of the original object. *For example, a 100-foot-tall tree can create turbulence over 1000 feet downwind of it. *When I did slope- soaring with R/C gliders, we used to have to be VERY cautious of this - so its always in my mind when I visually scan the ridge ahead of me when in my cockpit. So imagine a situation where you're getting rocked by lift and turbulence, and all of a sudden the ridge-facing wing drops. *Could you confidently distinguish that from a wing-lift on the opposite side if you're going through pulses of lift and sink, or turbulent roiling air? Of course, there's a BIG difference in what might be the best way to recover from those two different situations. *With a wing-drop, you have a stalled condition - giving the aircraft full aileron to lower the upwind wing just increases the angle of attack on the stalled wing and doesn't make the situation any better. *And if we're close to terrain we might subconsciously be pulling on the stick, too (again, not helpful to a stalled wing). ...Just some food for thought that a relative newbie like me wonders about at midnight (being a night-owl I tend to be obsessing over gliders at that time quite frequently *grin*). Take care, --Noel |
At 16:24 16 February 2008, Jj Sinclair wrote:
I actually saw Tom Madigan hit the Whites just east of Bishop. I dont think anyone has discussed airspeed in this thread. My glider has crap airelon authority at 50kts but at Va it is very good. Isn't safety near rocks a factor of speed? If you are belting along at a Va would you not be able to pull up / fly away from the cliff if you needed to? Jim |
On Feb 16, 9:04*am, Jim White
wrote: At 16:24 16 February 2008, Jj Sinclair wrote: I actually saw Tom Madigan hit the Whites just east of Bishop. I dont think anyone has discussed airspeed in this thread. My glider has crap airelon authority at 50kts but at Va it is very good. Isn't safety near rocks a factor of speed? If you are belting along at a Va would you not be able to pull up / fly away from the cliff if you needed to? Jim Sure Jim, but these guys were trying to climb and flying fairly slow in weak slope lift ond/or trying to work weak thermals. You bring up a good point though, I never slow down below 65 knots on my first pass across a piece of ridge that I haven't made at least one pass by to check for squirrely air. JJ |
On Feb 16, 12:43*am, tommytoyz wrote:
Noel, You do make in interesting point in making that distinction. In that situation , rolling inverted so as not to stall the mountain side wing would seem the best way out alive without stalling or more probably spinning in. The main hindrance I think is most pilot's reluctance to actually deliberately go inverted and steer from that position and without stalling while inverted. I'm interested in thoughts on this issue, am I nuts? Have you ever had any aerobatic training in a glider? Or a power plane? I have. What you suggest is extremely dangerous, and unlikely to work with a glider due to their extremely slow roll rate and extreme negative angle of attack needed when inverted - combined with limited elevator authority. As well as being extremely disorienting. In addition, while most gliders are extremely spin resistant right side up, they will spin in a heartbeat inverted (think anhedral and wash-in). So yes, in this case, you are nuts! ;) But please, if you get a chance, get some glider acro training and see for yourself, at a safe altitude, in a proper acro glider (which most XC ships are definitely not). Cheers, Kirk 66 |
Ok Kirk,
I concede it is a very dangerous and likely nutty idea. But when you're roll authority is gone, is smacking into the mountain a better alternative? Maybe the chances of coming out are not good, but isn't it better than certain doom? When you're suddenly looking at the mountain slope and the mountain side wing is going down, despite full input to the opposite, what is the best alternative? We have discussed how to avoid getting into this situation, my suggestion is what do you do when you encounter it despite all efforts not to get into one. This may not even be an idea to pursue, but just maybe it's a chance to NOT crash into a mountain in an emergency situation. Like I said, it may not be a good idea nor am I advocating people do this. But those who say it's nutty, of those I ask, what is the better alternative is the exact same situation? Tom |
On 16 Feb 2008 12:59:45 GMT, Dan Silent
wrote: Any chance of getting a link to the source of these numbers. As far as I know they are not on the web yet, unfortunately - I got them during an CFI training one week ago on paper only directly from one of the German fligt safety commisioners. They are going to be published on bfu-web.de - please send me a reminder if you cannot find them there within a couple of weeks (the site is in German only). Bye Andreas |
USA / The Soaring Safety Foundation (SSF) Safety Seminars 2008 | [email protected] | Soaring | 0 | November 8th 07 11:15 PM |
The Soaring Safety Foundation (SSF) Safety Seminars Hit The Road in the USA | [email protected] | Soaring | 0 | September 11th 06 03:48 AM |
Soaring Safety programs at the SSA Convention | Burt Compton - Marfa | Soaring | 0 | January 21st 06 03:40 AM |
Soaring Safety Seminar - SSA Convention | Burt Compton | Soaring | 0 | January 26th 04 03:57 PM |
Soaring Safety Foundation invitation | Burt Compton | Soaring | 0 | January 18th 04 02:51 PM |
