Minimum rates of climb/descent for VFR
Old February 15th 08, 09:58 AM posted to rec.aviation.student,rec.aviation.piloting
WingFlaps
Default Minimum rates of climb/descent for VFR
On Feb 15, 9:32*am, Bertie the Bunyip wrote:
WingFlaps wrote in news:043b8c97-e1d9-463a-9d5f-
On Feb 15, 12:31*am, "John" wrote:
No there are no regulations for climb or descent rates for VFR flight.
*Only true as long as you don't bust airspace or aircraft operating
limitations...
Well, neither one has much to do with a vertical speed limit.
A dive which goes over Vne?
Cheers
Old February 15th 08, 01:08 PM posted to rec.aviation.student,rec.aviation.piloting
Bertie the Bunyip[_25_]
WingFlaps wrote in
WingFlaps wrote in
flight.
limitations...
Well, yes, flight testing for instance. VNE is 10% below a tested dive
speed. Alos, as I posted before, some airplanes had an emergency dive
speed. Vd. I'd have to look it up to see, though. In any case, it's not a
legal limit, it;'s a design limitation.
Bertie
Old February 15th 08, 02:16 AM posted to rec.aviation.student,rec.aviation.piloting
Mxsmanic
WingFlaps writes:
limitations...
Are there climb/descent rate restrictions for specific airspaces, for VFR
flights operating without ATC restrictions?
I recall that if ATC tells you to climb or descend, you need to be able to do
so at at least 500 fpm, although I don't remember where I read this. However,
if you're VFR in, say, Class B, and ATC has _not_ directed you specifically to
climb or descend, and you decide to change altitude yourself, is there any
regulatory constraint on the rate that you must use?
Old February 15th 08, 02:35 AM posted to rec.aviation.student,rec.aviation.piloting
Mxsmanic wrote in
WingFlaps writes:
limitations...
VFR flights operating without ATC restrictions?
In your world? Nope.
Bertie
Old February 15th 08, 01:59 PM posted to rec.aviation.student,rec.aviation.piloting
JB
On Feb 14, 9:16*pm, Mxsmanic wrote:
However,
climb or descend, and ******you decide to change altitude yourself*****
Say, what? You have just committed an airspace violation and the
VATSIM controllers will remotely detonate your aircraft and kill all
onboard. You will be black-balled and not permitted to fly MSFS
again. Then what would you do?
--Jeff
Old February 15th 08, 02:25 PM posted to rec.aviation.student,rec.aviation.piloting
Gig 601XL Builder[_2_]
JB wrote:
On Feb 14, 9:16 pm, Mxsmanic wrote:
However,
--Jeff
Actually, from a quick look at Anthony's Guest Book on his website, it
seems that the VATSIM forum is tired of him as well.
Old February 14th 08, 07:58 PM posted to rec.aviation.student,rec.aviation.piloting
WingFlaps
Err I don't think that's 100% correct but it will do for MX.
Cheers
Old February 14th 08, 08:19 PM posted to rec.aviation.student,rec.aviation.piloting
Cheers
Please then for my benefit point me to such a regulation.
Old February 14th 08, 08:39 PM posted to rec.aviation.student,rec.aviation.piloting
Michael Ash
Technically speaking, it is illegal to descend faster than about 25,000fpm
(needs to be adjusted based on density, since it's give in terms of
indicated airspeed) when below 10,000ft. I doubt too many flights would
need to worry about this limitation.
Michael Ash
Rogue Amoeba Software
Old February 14th 08, 08:40 PM posted to rec.aviation.student,rec.aviation.piloting
Michael Ash wrote in
flight.
25,000fpm (needs to be adjusted based on density, since it's give in
terms of indicated airspeed) when below 10,000ft. I doubt too many
flights would need to worry about this limitation.
Or climb!
But in fact this can be waived and very frequently is.
Bertie
Descent below MDA -- what would you do? Roy Smith Instrument Flight Rules 50 August 29th 05 12:39 AM
ANR squeal on descent Juan Jimenez General Aviation 13 August 19th 05 10:39 PM
descent below minimums hsm Instrument Flight Rules 82 January 11th 05 06:33 PM
BRS and descent rate Roger Long Piloting 21 May 7th 04 05:34 PM
Minimum rate of climb or descent Aaron Kahn Instrument Flight Rules 3 July 25th 03 03:22 PM
