#11
![]() Not possible at all at that time. The V-1 (aka Fi-103, FZG-76) took years to develop. Rheinbote was started in 1943. One is a short range artillery rocket, the other a long range flying bomb meant to hit Sweden. There's no comparison between the two other than you thinking it is a derivative of the Rheinbote due to (I assume) general appearance without the ramjet. BTW, an engineer cannot simply strap on an experimental ramjet onto a Rheinbote-like missile, add wings, and hope it makes it to Sweden. No, but they could strap on a ram jet and wings to see how much range they could get, and develop from there. Considering how much impulse they got out of the first stage of the Rheinbote, I'm suprised there wasn't more R&D done with the system. Using a ramjet instead of another stage or two(or three) would seem to be a logical growth direction. And the arti guys were no entirely unaware of ramjets, with the R&D done with ramjet shells and such. But to have this "V-4" spring up out of nowhere, without any R&D trail or name attached to its manufacture seems a bit iffy. If it was purpose designed, then why not a better configuration? A better length/diameter ratio or tapered rear fuselage would have been obvious. Now, a lack of taper could be to accommodate a tail mounted rocket motor to supplement the catapult and rato strap ons. But unless the was based on something else, the length/diameter ratio seems off. On Misdroy they had catapults aimed towards Sweden, not the West. The ramps were for the V-4. Misdroy was also the testing ground for the long-range V-3 weapon which fired shells at Luxembourg. The Rheinbote, OTOH, was made by Rheinmetall-Borsig and used to shell Antwerp in Nov '44- 220 being fired. Its maximum range was 135 miles. No Rheinbote was on Misdroy. Misdroy was the testing ground for long-range missiles and shells. Where was "Misdroy"? My refs mention it too, but can't find it on a map. For that matter, the "V-4" was likely little more than a vaporware threat rather than a credible piece of hardware. It wouldn't make any sense to threaten a neutral nation like Sweden with a non-existant weapon in 1945 with the Allies closing in on Germany. If you remember postwar it was Sweden that complained about the "Ghost Rockets" coming from the same region. Most "Ghost Rockets" were described as long cigar-shaped burning objects. These were suspected of being Russian modified extended-body V-1s but looking at the V-4... it looks like a strong possibility, especially if a Swede saw it from below, the ramjet unseen burning above the body. I don't know about "ghost rockets" but at least one A-4 ended up in that direction. But in general, the whole threaten Sweden things soulds more than a bit iffy, and given the nature of the time, Germany did have all kinds of scary things so even a bluff would have had weight, on the one hand, and on the other, the Swedes would have known that the German's days were numbered and even a wonder weapon threat would have seemed a bit toothless. Even if some kind of launch rig was built, that doesn't mean there as anything to launch, other than, perhaps, more V-1s. |
![]() Uzytkownik "steve gallacci" napisal w wiadomosci ... [snip...] No Rheinbote was on Misdroy. Misdroy was the testing ground for long-range missiles and shells. Where was "Misdroy"? My refs mention it too, but can't find it on a map. You cannot find this place if you didn't have BdV (Bund der Vertriebener) approved maps. Try finding Miedzyzdroje (or better Miedzyzdroje), which is proper Polish name for this city located on Wolin island East of Swinoujscie (Swinemuende) and North of Szczecin (Stettin). If you are a little bit nostalgic you can see a strange German-Polish site http://www.misdroy.de/ or even buy pre-war photos http://www.sammler-bonn.de/online-sh...pommern/misdro y/misdroy.htm. [snip...] Regards JasiekS Warsaw, Poland |
Eyeballing those pictures of the As044 and the Pabst ramjet - IMHO the
AS044 is a pulse jet (else why the square grilled inlet?) and the Pabst ramjet is a neat way to convert fuel into smoke and noise. Its specific fuel consumption (Kg fuel/newton/hr) must have been very high indeed. I believe the ramjet fighter as pictured would have had a range even less than that of the Me163b. (Little volume for fuel.) Doubtless why it never made it off the sketch board. Walt BJ |
![]() "robert arndt" wrote in message om... Third, the pulsejet IS a form of ramjet, with intermittent combustion vs continuous. It cannot operate until it reaches a certain airspeed. In the Ta 283 this would be accomplished by the Walter rocket in the tail. This is incorrect A pulsejet CAN work at zero airspeed as long as you provide a good stream of air into the intake at lightup. The launch procedure for the V-1 required the pulse jet to be started on the ground using air from a fan or compressor At least one company makes a scaled down copy of the Argus engine for propelling model aircraft, the strating instructions are as follows "To start the engine a pulsed high voltage supply usually from a Ford T coils is used to provide a constant stream of sparks at the spark plug and compressed air from a tank or pump is fed to the air attachment on the flowjector. Fuel is drawn into the head by the air stream which also opens the valve and lets the fuel air mixture into the pipe. Here it encounters the spark and burns in a sharp pop. This rapid increase in pressure closes the valve. The expanding gas has only one place to go, out the back of the pipe. The momentum of the gas leaving the pipe creates a less than atmospheric pressure in the combustion chamber. ( In terms of the pressure waves in the engine the compression wave produced by the combustion races down the pipe, it hits the open end of the pipe and is reflected as a rarefaction wave and travels back to the combustion chamber) Atmospheric pressure pushes open the valves and a fresh fuel-air mixture enters the combustion chamber. This is then ignited by residual combustion from the first pulse and the process repeats. This repeats at 230 times a second and makes the most incredible noise!! The compressed air and spark source are disconnected and the engine roars away on its own. The extreme heat means that the plane should be moving very quickly, within a few seconds of startup to get a good cooling airflow over the pipe ( also helps cool the plane!!)." Keith |
Australia to participate in US missile defence program | David Bromage | Military Aviation | 40 | December 13th 03 01:52 PM |
AIM-54 Phoenix missile | Sujay Vijayendra | Military Aviation | 89 | November 3rd 03 09:47 PM |
Poland: French Missile Report Was Wrong | Michael Petukhov | Military Aviation | 8 | October 7th 03 10:54 PM |
Surface to Air Missile threat | PlanetJ | Instrument Flight Rules | 1 | August 14th 03 02:13 PM |
Rafael's AIM-AIR IR Missile Countermeasure | JT | Military Aviation | 8 | July 13th 03 03:41 AM |
