Photos of Ice on the wings of a Crj 200
Old February 18th 08, 05:08 PM posted to rec.aviation.piloting
F. Baum
Default Photos of Ice on the wings of a Crj 200
On Feb 17, 11:18*am, wrote:
I took some pictures of some ice accumulation on the wings if a
Crj-200. *Its a good example of how well the wing anti-icing works on
the Crj-200. *After seeing how much ice was picked up, I was surprised
that there was no icing in the tail at all.
Dear RJ pilot,
Has it occured to you that you are violating Sterile Cockpit
procedures by using your camera on short final ? I hope this was a
ferry flight. I like the way you snub your nose at prudent operating
practices by posting this to the web. You better hope a fed (Or your
Chief Pilot ) never sees these pics.
Frank
Old February 18th 08, 06:05 PM posted to rec.aviation.piloting
John[_14_]
William Hung wrote:
On Feb 17, 1:41 pm, Mxsmanic wrote:
writes:
Crj-200. Its a good example of how well the wing anti-icing works on
the Crj-200. After seeing how much ice was picked up, I was surprised
The efficiency of the anti-icing features is impressive.
Did the aircraft behave differently with this amount of ice, or were the
effects unnoticeable?
I think that answer is rather obvious.
How long were you in icing conditions? What actions
did you take (if any) to avoid or escape the icing conditions?
Looks like he turned on the anti-ice stuff. Again, fairly obvious.
Wil
The 200, like most airliners, has an "evaporative" anti icing system.
The leading edges are kept very hot, well above the boiling point of
water. When supercooled water hits the LE, the drops immediately
vaporize. If the LE isn't hot enough and the water just is heated above
the freezing point, it can cause "runback ice" because it flows back and
refreezes behind the LE.
The tail doesn't use anti ice because the tail area is large enough to
generate required downforce with ice. If anti ice was used for the
horizontal tail, it could be made a fair bit smaller.
John
Old February 18th 08, 08:16 PM posted to rec.aviation.piloting
Bertie the Bunyip[_24_]
John wrote in
writes:
on the Crj-200. After seeing how much ice was picked up, I was
surprised that there was no icing in the tail at all.
the effects unnoticeable?
Wil
above the freezing point, it can cause "runback ice" because it flows
back and refreezes behind the LE.
Actually, we only use them as de-ice these days, to prevent just such a
scenario as you describe.
Yeah, but the tail doesn't really accrue ice anyway. Actually, neither
does the wing. I think I can count on two fingers the number of times
I've de-iced the wing in a 737 in flight. Still haven't used it on the
75.
bertie
PC-9 with all the wings :-) Glenn[_2_] Aviation Photos 1 August 19th 07 01:52 AM
Sea Wings pin? Robert M. Gary Piloting 15 September 23rd 06 06:49 PM
X-Wings and Canard Rotor Wings. Charles Gray Rotorcraft 1 March 22nd 05 12:26 AM
~ PHOTOS FROM THE FALLUJAH MASSACRE [won't find *these* photos on TekTeam26 Military Aviation 0 April 12th 04 01:49 AM
FS SGS 1-35 Wings MHende6388 Soaring 0 September 11th 03 02:06 AM
