On Feb 19, 9:42 pm, C J Campbell
wrote: The plane is not airworthy if this is the condition. I doubt that the CFIs are aware of it. Even if they were, they might not report it because they don't want the plane taken off the line for repairs. A broken rudder bar spring can cause the rudder to jamb in a spin recovery. After that there is no way to recover from the spin. Pushing on the rudder harder just jambs it harder. See here for a related accident report: http://www.tsb.gc.ca/en/reports/air/...4/a98q0114.asp That airplane had two problems: A busted spring, which really wasn't the issue, and badly worn rudder hinges, which allowed the rudder stops to override the stop bolt heads and lock in a fully- deflected position. Since they couldn't get the spin rotation stopped, they couldn't break the stall. The busted spring was just another symptom of really poor maintenance. The FAA issued an AD on it. Dan |
![]() wrote in message ... On Feb 19, 11:40 am, wrote: On Feb 19, 9:33 am, wrote: Yesterday on a short sight-seeing x-cntry I noticed the following flight characteristic of a 1975 C150: whenever I turned to the left, especially with low power setting, the ball indicated a skid with no bottom rudder at all. Explanations I've seen usually are illustrating the danger of skidding a turn onto final, at high AoA, the typical scenario being tightening a turn to not overshoot the runway. The inside wing and the rudder are pointing toward the ground. The ball indicates skid. The pilot gives more back pressure -- that's where you can get into big trouble. But I noticed a substantial ball deflection indicating skid with neutral rudder (shallow turn, not anywhere near critical AoA, by the way). In a left turn it seemed to me to take a fair bit of top rudder to keep the ball centered. That seems weird to me. It doesn't happen in the 152 or 172 I fly so I'm wondering if other people have seen this in 150s (or other aircraft) or maybe the ball indicator has a problem? I remember during my checkride in the same aircraft the ball showed substantial skid on a demo approach the DE was doing after I had passed the checkride. He saw it too and corrected, but the plane's behavior seemed to catch him off guard as well. You have a broken rudder bar spring. Cessna's springs regularly do that and will have the airplane uncoordinated, requiring constant rudder force on one pedal to keep things centered. The unbroken spring is pulling on one pedal. The other, more remote possibility, is a worn nosewheel centering cam. The nosewheel is the rudder's centering system while in flight on a Cessna single, with the sprung steering pushrods acting as system centers. Cessna rudder systems are frequently found badly misrigged, too, since too few mechanics refer to the maintenance manuals while fixing them. Dan- Hide quoted text - - Show quoted text - Hey thanks, I will convey that info in terms of a question to the FBO and see what they say. I'm sure other pilots have noted this weirdness as well. ---------------old post ends----------- Sorry for putting this in the wrong place, there is a post missing on my server. Some of these planes had a little ground adjustable trim tab--which was adjusted by the simple expedient of bending it by hand. It could obviously be bent out of position by someone's knee or nearly anything else on the ramp. I don't recall whether all 150s and 152s had the feature, and I only ever flew one 152 that was obviously out of rig. Peter |
On Feb 19, 8:33*am, wrote:
In a left turn it seemed to me to take a fair bit of top rudder to keep the ball centered. That seems weird to me. It doesn't happen in the 152 or 172 I fly so I'm wondering if other people have seen this in 150s (or other aircraft) or maybe the ball indicator has a problem? Sure you weren't flying a helicopter? ![]() -Robert |
On Feb 19, 12:26*pm, "Robert M. Gary" wrote:
On Feb 19, 8:33*am, wrote: In a left turn it seemed to me to take a fair bit of top rudder to keep the ball centered. That seems weird to me. It doesn't happen in the 152 or 172 I fly so I'm wondering if other people have seen this in 150s (or other aircraft) or maybe the ball indicator has a problem? Sure you weren't flying a helicopter? ![]() -Robert Hah! For my own safety and that of everyone else I hope I'm not hallucinating *that* bad! ![]() |
Question: Standard rate turns, constant rate turns, and airspeed | Robert Barker | Piloting | 5 | April 15th 07 04:47 PM |
A Q on horizontal turns | Ramapriya | Piloting | 2 | January 8th 05 05:57 PM |
A Q on horizontal turns | Ramapriya | Piloting | 14 | January 7th 05 11:46 PM |
A320 doing S-turns at LAS | Gerald Sylvester | Piloting | 7 | May 7th 04 02:59 PM |
Slipping in Turns | Jim Hendrix | Soaring | 16 | November 30th 03 04:39 PM |
