#11
On Feb 26, 9:53 pm, Frank wrote:
On Feb 20, 7:07 pm, RN wrote: Can anyone recommend a USB to Serial Converter that works for communication with with the Ilec SN10 Thanks John I have used a CEFC USB-to-serial adaptor from 'Cables to Go' for at least 10 years, and it has worked flawlessly on the SN-10, Garmin GPS units, PDA's and everything in between, with several different laptops. Frank (TA) Thanks Frank - Can you provide a bit more detail, especially which OS you've used, precise model and part number on packaging and also from Windows device manager, and I'll update the web page ? Thanks again, Best Regards, Dave |
On Wed, 20 Feb 2008 16:07:09 -0800, RN wrote:
Can anyone recommend a USB to Serial Converter that works for communication with with the Ilec SN10 Thanks John I have a "no name" branded USB/Serial convertor with a "Prolific Technology PL2303" chipset. (For technically minded it has the manufacturer/model identifier "067b:2303"). I have used this without any problems with Volkslogger, Flarm and B500 without problems on an HP nx6110 Laptop with both Ubuntu Linux and Windows XP. (Not all of the above have Linux interface software). However when I first used under Windows XP I had an issue with the USB/ Serial driver. I had to download another driver that I found on the Internet, delete all versions of the "tainted" driver on the hard drive to prevent it from being re-installed, and then install the new driver. Since the combination has been sorted, I have had no problems at all with USB/Serial issues. Regards Ian |
On Feb 20, 5:07 pm, RN wrote:
Can anyone recommend a USB to Serial Converter that works for communication with with the Ilec SN10 Thanks John I have used a Belkin F5U109 to successfully upload waypoint databases and downloads logger files from my SN10B. Used a Lenov Thinkpad X61S Windows XP Pro. Just did it last weekend, 3/8/08. The original driver did not work until I upgraded it from the Belkin web site. I still wonder how well this arrangement will work to flash the firmware. Still a little skeptical about that. Paul Remde's recommendation to use a PC Card with a real serial UART may be a better answer. Anyone know if this Belkin F5U109 will flash SN10B firmware OK? Walt Rogers, WX |
12 to 24v up-converter | ccwillwerth | Home Built | 2 | August 10th 06 03:11 AM |
KLN to Garmin 396 Converter | Mike Granby | Owning | 7 | February 5th 06 01:48 PM |
AC to DC Converter for APU | Newps | Owning | 8 | November 30th 04 03:41 PM |
1 Amp DC/DC Converter Chip? | bcjames | Soaring | 11 | September 25th 04 06:32 AM |
24/12 volt DC converter | Victor J. Osborne, Jr. | Products | 1 | February 18th 04 02:11 PM |
