#11
Emergency landings eh
It's obvious that the glider pilots are away flying. |
In rec.aviation.student george wrote:
Emergency landings eh It's obvious that the glider pilots are away flying. Alas I'm not, but I've been keeping quiet. I know that there's a significant difference between landing a 20:1, 30:1, or 40:1 glider with no engine and landing a 7:1 winged brick whose engine has suddenly decided to stop after a long period of appearing to work fine. Landing a glider doesn't worry me at all but I would not be happy taking the controls of a Cessna after the fan stopped cooling the pilot. For one thing, no spoilers for glideslope control! -- Michael Ash Rogue Amoeba Software |
On Tue, 26 Feb 2008 18:55:12 -0600, ManhattanMan wrote:
Man - memories, circa 1968........ ![]() Yeah... back when you were forty... G -- Dallas |
Michael Ash wrote: In rec.aviation.student george wrote: Emergency landings eh It's obvious that the glider pilots are away flying. Alas I'm not, but I've been keeping quiet. I know that there's a significant difference between landing a 20:1, 30:1, or 40:1 glider with no engine and landing a 7:1 winged brick whose engine has suddenly decided to stop after a long period of appearing to work fine. Landing a glider doesn't worry me at all but I would not be happy taking the controls of a Cessna after the fan stopped cooling the pilot. For one thing, no spoilers for glideslope control! That's what slips are for :-) rg |
On Feb 27, 5:57 pm, Michael Ash wrote:
In rec.aviation.student george wrote: Emergency landings eh It's obvious that the glider pilots are away flying. Alas I'm not, but I've been keeping quiet. I know that there's a significant difference between landing a 20:1, 30:1, or 40:1 glider with no engine and landing a 7:1 winged brick whose engine has suddenly decided to stop after a long period of appearing to work fine. Landing a glider doesn't worry me at all but I would not be happy taking the controls of a Cessna after the fan stopped cooling the pilot. For one thing, no spoilers for glideslope control! Well you might look at the Shuttle returning from space as a rather large glider |
In rec.aviation.student Ron Garret wrote:
In article , Michael Ash wrote: In rec.aviation.student george wrote: Emergency landings eh It's obvious that the glider pilots are away flying. Alas I'm not, but I've been keeping quiet. I know that there's a significant difference between landing a 20:1, 30:1, or 40:1 glider with no engine and landing a 7:1 winged brick whose engine has suddenly decided to stop after a long period of appearing to work fine. Landing a glider doesn't worry me at all but I would not be happy taking the controls of a Cessna after the fan stopped cooling the pilot. For one thing, no spoilers for glideslope control! That's what slips are for :-) True enough, but using only slips is a royal pain, particularly in higher-performing gliders. A mid-range glider with a 35:1 glideslope may have a 5:1 glideslope with full spoilers, but a slip won't do nearly that much good. It reduces the size of your glideslope "basket" and requires a lot more precision. Combine that with not doing surprise power-off landings all the time and the whole business seems chancier than I'd like. -- Michael Ash Rogue Amoeba Software |
On Feb 27, 5:57 pm, Michael Ash wrote: In rec.aviation.student george wrote: Emergency landings eh It's obvious that the glider pilots are away flying. Alas I'm not, but I've been keeping quiet. I know that there's a significant difference between landing a 20:1, 30:1, or 40:1 glider with no engine and landing a 7:1 winged brick whose engine has suddenly decided to stop after a long period of appearing to work fine. Landing a glider doesn't worry me at all but I would not be happy taking the controls of a Cessna after the fan stopped cooling the pilot. For one thing, no spoilers for glideslope control! Well you might look at the Shuttle returning from space as a rather large glider Certainly, and I wouldn't want to land that one either! Ridiculously low glide ratio, low forgiveness for poor positioning, and far too much reliance on computer control make me leery. -- Michael Ash Rogue Amoeba Software |
Dudley Henriques wrote:
Considering this, there should NEVER be a need to pull the mixture on a student. Doing this can easily turn a practice session into an actual forced landing. I agree about stopping the prop. I have done it before, but only to satisfy my curiosity about performance differences between stopped and windmilling. I did it over a deserted airport with a long runway (actually 3 long runways). I am curious about pulling the mixture, though. The only difference between pulling the throttle and pulling the mixture is that one cuts off air to the engine and the other cuts off fuel. Since pulling the mixture cuts off the fuel, it keeps the engine and plugs from loading up as much. In practice (at least in Cherokees and 172s), I've found that the prop is not going to stop when the mixture is pulled, unless the plane gets within a few knots of stall speed. I'm not a CFI, but I do practice engine out landings on a regular basis (religiously, since my real engine out). I prefer pulling the mixture to idle cutoff as a means of simulating the power loss, just because it keeps the plugs cleaner. Power recovery is as simple as pushing the mixture back in and verifying that the throttle is full forward. Is there something I'm not thinking of? John Galban=====N4BQ (PA28-180) -- Message posted via AviationKB.com http://www.aviationkb.com/Uwe/Forums...ation/200802/1 |
JGalban via AviationKB.com wrote:
Dudley Henriques wrote: Considering this, there should NEVER be a need to pull the mixture on a student. Doing this can easily turn a practice session into an actual forced landing. I agree about stopping the prop. I have done it before, but only to satisfy my curiosity about performance differences between stopped and windmilling. I did it over a deserted airport with a long runway (actually 3 long runways). I am curious about pulling the mixture, though. The only difference between pulling the throttle and pulling the mixture is that one cuts off air to the engine and the other cuts off fuel. Since pulling the mixture cuts off the fuel, it keeps the engine and plugs from loading up as much. In practice (at least in Cherokees and 172s), I've found that the prop is not going to stop when the mixture is pulled, unless the plane gets within a few knots of stall speed. I'm not a CFI, but I do practice engine out landings on a regular basis (religiously, since my real engine out). I prefer pulling the mixture to idle cutoff as a means of simulating the power loss, just because it keeps the plugs cleaner. Power recovery is as simple as pushing the mixture back in and verifying that the throttle is full forward. Is there something I'm not thinking of? John Galban=====N4BQ (PA28-180) Pulling to ICO is simply not necessary to teach forced landings. Doing it is just asking for possible trouble. Bottom line is that the pros just don't outweigh the potential cons. It's just not a practice I have ever recommended. DH -- Dudley Henriques |
Emergency Landings | Ol Shy & Bashful | Piloting | 7 | October 15th 07 09:09 PM |
Teaching the aerotow | Paul Moggach | Soaring | 5 | September 12th 05 03:31 AM |
Teaching emergency procedures | Ramapriya | Piloting | 9 | January 4th 05 09:14 PM |
Channel News Asia: Taiwan Jets Practise Emergency Landings on Freeway Amid Tensions with China | Dionaea muscipula | Military Aviation | 0 | July 21st 04 08:18 AM |
Teaching airworthiness | Roger Long | Piloting | 28 | October 2nd 03 09:08 PM |
