hand-propping a 172SP
Old March 4th 08, 10:39 PM posted to rec.aviation.piloting
Larry Dighera
Default hand-propping a 172SP
On Tue, 4 Mar 2008 11:07:24 -0800 (PST), Tom
wrote in
We tried after pumping the throttle.
As there is no carb pump, that is probably not a very useful
technique.
Old March 4th 08, 11:12 PM posted to rec.aviation.piloting
On Mar 4, 1:11 pm, "JGalban via AviationKB.com" u32749@uwe wrote:
Tom wrote:
Let me provide a couple more details:
The engine was hot - had just been flown for 1 hour, and had only been
off for maybe 15 minutes. The starter was malfunctioning in some way
but the battery was good. When I tried to start it with the starter,
it made a noise as though the starter motor was spinning but the
engine didn't crank.
I'll bet that was your problem with the hand prop attempt. Hot starts on
injected engines can take quite a few cranks even with a working starter.
Doesn't the 172 hot start procedure have the mixture lean, then you move it
to rich as the engine starts to catch? It would seem to be tough to
duplicate that with the engine turning one revolution at a time.
Your starter problem sounds like a sticky bendix gear. When the bendix
shaft gets gummed up, the bendix gear won't pop out and engage the ring gear.
It just spins. As you found, it will sometimes cure itself, but a permanent
fix involves cleaning and lubing of the bendix shaft. This is a common
problem on Cherokees, whose wacky design leaves the starter exposed to the
airstream (and all of the dirt, bugs and debris).
I usually carry some silicone spray lube and a very long, skinny
screwdriver (since I fly a Cherokee). If the bendix gear strands you, you
can always try dousing the bendix shaft with lube, then poking the bendix
gear a bit with the screwdriver. That's always worked for me.
Message posted via AviationKB.comhttp://www.aviationkb.com/Uwe/Forums.aspx/aviation/200803/1
A battery just a hair too low to run the starter would still
run the fuel boost pump. Starters consume several hundred amps,
causing a massive voltage drop in the system; a boost pump takes a few
amps and won't cause such a hassle.
Those sticky Bendix drives are often sticky because someone
used oil on them instead of silicone spray. The oil attracts dust and
sticky sludge forms.
Dan
Old March 6th 08, 04:23 AM posted to rec.aviation.piloting
William Hung[_2_]
* I'll bet that was your problem with the hand prop attempt. *Hot starts on
to rich as the engine starts to catch? * It would seem to be tough to
* *Your starter problem sounds like a sticky bendix gear. *When the bendix
It just spins. * As you found, it will sometimes cure itself, but a permanent
fix involves cleaning and lubing of the bendix shaft. *This is a common
* I usually carry some silicone spray lube and a very long, skinny
screwdriver (since I fly a Cherokee). *If the bendix gear strands you, you
gear a bit with the screwdriver. *That's always worked for me.
Do airplanes with fuel injected engines still have a mixture knob? I
don't know the answer, but I would think not.
Wil
Old March 6th 08, 11:34 AM posted to rec.aviation.piloting
Peter Clark
On Wed, 5 Mar 2008 20:23:14 -0800 (PST), William Hung
How the fuel enters the intake manifold and cylendars doesn't change
that the mixture needs to be adjusted. We're talking injected fuel
here, not FADEC.
Old March 6th 08, 03:24 PM posted to rec.aviation.piloting
Larry Dighera
wrote in
You've never flown behind an injected engine?
Old March 7th 08, 10:12 AM posted to rec.aviation.piloting
Bertie the Bunyip[_24_]
Larry Dighera wrote in
wrote in
I think he implied that, fjukkwit.
Bertie
172SP Greenwood IN KHFY #5.jpg (1/1) 3-18-07 Castman Aviation Photos 0 March 18th 07 02:26 PM
172SP Greenwood IN KHFY #3.jpg (1/1) 3-18-07 Castman Aviation Photos 0 March 18th 07 02:26 PM
172SP Greenwood IN KHFY #2.jpg (1/1) 3-18-07 Castman Aviation Photos 0 March 18th 07 02:26 PM
172SP Greenwood IN KHFY #1.jpg (1/1) 3-18-07 Castman Aviation Photos 0 March 18th 07 02:26 PM
Hand propping - licensed pilot at the controls? TRA Piloting 38 July 15th 06 05:05 PM
