On Mar 14, 9:11*am, Brian wrote:
As for your question above, given that the airplanes are ascending or decending at constant rates then the lift is equal to the wieght of the airplane in both cases. If the aircraft are the same wieght then the lift generated will be the same. That is not correct. Cheers |
WingFlaps wrote:
On Mar 14, 9:11*am, Brian wrote: As for your question above, given that the airplanes are ascending or decending at constant rates then the lift is equal to the wieght of the airplane in both cases. If the aircraft are the same wieght then the lift generated will be the same. That is not correct. Hmmm. Brian's statement appears essentially correct - and you are correct too. The "gotcha" is that the vertical component of the lift force exceeds the weight only during the transition from level flight to constant ascending flight. And the lift force is less than the weight during the transition from level flight to constant descending flight. But once the vertical speed becomes constant (whether up or down) the vertical component of lift has to equal the downward force of gravity. If it didn't, then the aircraft would begin _accelerating_ up or down, depending on the difference. |
On Mar 12, 7:14*pm, WingFlaps wrote:
Hi All, Imagine a plane in 2 conditions. 1) Climbing with full power 2) Descending fast with 50% power. Both have constant rates of ascent and descent. Question A: Which wing is closer to stall? Question B: A big updraft occurs, which is more likely to stall? If you vote first it _may_ lead to some good discussion later... Cheers It would depend on the angle of attack. You could be in a very shallow climb at full power, and have lots of margin above the stall. On the other hand, you could be descending at 50% power in a very nose- high attitude, and have very little margin above the stall. Plus, there's the cost of the hamburger you are flying towards. Phil |
On Wed, 12 Mar 2008 17:14:17 -0700 (PDT), WingFlaps
wrote: Hi All, Imagine a plane in 2 conditions. 1) Climbing with full power 2) Descending fast with 50% power. Both have constant rates of ascent and descent. Question A: Which wing is closer to stall? Question B: A big updraft occurs, which is more likely to stall? If you vote first it _may_ lead to some good discussion later... Cheers *************************************** Obviously #2. Any one should be able to see that. Big John |
On Mar 13, 6:45*pm, Big John wrote:
On Wed, 12 Mar 2008 17:14:17 -0700 (PDT), WingFlaps wrote: Hi All, Imagine a plane in 2 conditions. 1) Climbing with full power 2) Descending fast with 50% power. Both have constant rates of ascent and descent. Question A: Which wing is closer to stall? Question B: A big updraft occurs, which is more likely to stall? If you vote first it _may_ lead to some good discussion later... Cheers *************************************** Obviously #2. Any one should be able to see that. Aha, so it is closer to the stall? Cheers |
"WingFlaps" wrote in message ... Hi All, Imagine a plane in 2 conditions. 1) Climbing with full power 2) Descending fast with 50% power. Both have constant rates of ascent and descent. Question A: Which wing is closer to stall? Question B: A big updraft occurs, which is more likely to stall? I'm not sure if there's enough information. If it's a typical prop plant I would expect that there would be a difference between a high wing and a low wing due to slipstream effects, but my guess would be that the right wing would be closer. Or, are you asking which of the two scenarios is closer/more likely to stall. In that case, I'd say the first configuration. Full-power departure stalls are easy to encounter. -c |
On Mar 14, 4:02*am, "gatt" wrote:
"WingFlaps" wrote in message ... Hi All, Imagine a plane in 2 conditions. 1) Climbing with full power 2) Descending fast with 50% power. Both have constant rates of ascent and descent. Question A: Which wing is closer to stall? Question B: A big updraft occurs, which is more likely to stall? I'm not sure if there's enough information. *If it's a typical prop plant I would expect that there would be a difference between a high wing and a low wing due to slipstream effects, but my guess would be that the right wing would be closer. * Or, are you asking which of the two scenarios is closer/more likely to stall. * *In that case, I'd say the first configuration. * *Full-power departure stalls are easy to encounter. Ok good, but let's say both planes have the same airspeed. Does that change anything? Cheers |
Put me in the "not enough info" column.
Plane #2 could be in fact _in_ a stall (or spin), "descending fast with 50% power" or _more_. Think Delta Flight 191, for example. On Mar 12, 8:14 pm, WingFlaps wrote: Hi All, Imagine a plane in 2 conditions. 1) Climbing with full power 2) Descending fast with 50% power. Both have constant rates of ascent and descent. Question A: Which wing is closer to stall? Question B: A big updraft occurs, which is more likely to stall? If you vote first it _may_ lead to some good discussion later... Cheers |
On Mar 14, 11:37*am, Bertie the Bunyip wrote:
TakeFlight wrote in news:935d6394-8224-482e-9428- : Put me in the "not enough info" column. Plane #2 could be in fact _in_ a stall (or spin), "descending fast with 50% power" or _more_. *Think Delta Flight 191, for example. That was something else entirely. That was a microburst. The rules pretty much go out the window with one of those. not to say the laws of physics are suspended, but it's a scenario that is so different from what we learn as pilots that drastic retraining was * introduced right across the board after it. Flight guidance systems were modified to account for the new methods, so it's not really relevant. Just to give you some idea of what I mean, I'll give you a scenario. You've just aken off and yoou're climibing away at best rate. Suddenly, your airspeed increases by a fairly large lump. 15-20 knots, say. you increase your pitcha bit to absorb it and your speed bleeds back a tad. Still plenty in hand, though. all the sudden the pitch you have is dragging your speed back and it's beginning to decrease as the wind that delivered that extra speed vanishes. You're still OK and back to your orignal pitch and have a couple of knots more than you had at the beginning. All the sudden, the bottom falls out of your airplane. Your climb stops and then a second later * you begin to sink, and fast. another second or two and your speed washes off even further and now you're sinkng and your stall warning is starting to squeak. you gotta do something and right now. you still have some altitude, say 400 feet. what do you do? Bertie Alt-Ctl-Del No, wait, change my underwear. Yoke forward, nose down and max power? Richard |
| Thread Tools | |
| Display Modes | |
| Stalls?? | Ol Shy & Bashful | Piloting | 155 | February 22nd 08 04:24 PM |
| why my plane stalls | Grandss | Piloting | 22 | August 14th 05 08:48 AM |
| Practice stalls on your own? | [email protected] | Piloting | 34 | May 30th 05 06:23 PM |
| Newbie Qs on stalls and spins | Ramapriya | Piloting | 72 | November 23rd 04 05:05 AM |
| Wing tip stalls | mat Redsell | Soaring | 5 | March 13th 04 06:07 PM |
