It's because the alcohol in the auto fuel absorbs it all...
Sadly, we still have to burn a fair amount of that over-priced blue crap (that fouls my plugs and contaminates the earth) since most airports don't sell mogas... I've never found water in either mogas or avgas in our planes. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
"Jay Honeck" wrote in
news:ZyQCj.76791$yE1.8290@attbi_s21: It's because the alcohol in the auto fuel absorbs it all... Sadly, we still have to burn a fair amount of that over-priced blue crap (that fouls my plugs and contaminates the earth) since most airports don't sell mogas... I've never found water in either mogas or avgas in our planes. Because you don't know how to look, more than likely. Bertie |
![]() "Ron Garret" wrote: It occurred to me today that in fifteen years of flying I have never once found water in my fuel when I've drained my tanks. Not a drop. Ever. Am I just lucky, or is this really as rare an occurrence as it seems to be? (I fly in SoCal. Maybe that has something to do with it.) I've never found any in fuel samples unless the airplane was exposed to rain and the fuel cap gaskets were defective. That's in the Mobile, AL area, one of the most humid spots in the U. S. -- Dan T182T at 4R4 |
Ron Garret wrote:
It occurred to me today that in fifteen years of flying I have never once found water in my fuel when I've drained my tanks. Not a drop. Ever. Am I just lucky, or is this really as rare an occurrence as it seems to be? (I fly in SoCal. Maybe that has something to do with it.) I'm also in SoCal and have had a few drops a couple of times, except... One time I stopped for fuel in Barstow. For those not familiar, Barstow is in the middle of the desert and the last place in the world one would expect to find water in the gas. The first sample out of each sump had about a quarter cup of water. It took many drains from each sump to get to clean gas. This was a one time occurance (I've been to Barstow many times). So the moral is, drain, as it only takes one fluke to screw up your day. -- Jim Pennino Remove .spam.sux to reply. |
Depends on where you live and the design/condition of the fuel caps. Some
older Cessna fuel caps were notorious for letting water into the tanks. I live in the Seattle area and would never pass up a chance to check for water. Bob Gardner "Ron Garret" wrote in message ... It occurred to me today that in fifteen years of flying I have never once found water in my fuel when I've drained my tanks. Not a drop. Ever. Am I just lucky, or is this really as rare an occurrence as it seems to be? (I fly in SoCal. Maybe that has something to do with it.) rg |
On Mar 15, 11:49 am, "Bob Gardner" wrote:
Depends on where you live and the design/condition of the fuel caps. Some older Cessna fuel caps were notorious for letting water into the tanks. There's an AD on those caps. The gaskets must be inspected every year. The gasket (an O-ring) shrinks and cracks with age and exposure to the sun's heat. If the gasket gets bad enough, the low pressure atop the wing can suck air out of the tanks faster than the vent can replace it and bladder tanks will collapse, forcing the fuel overboard while the rising bladder bottom lifts the fuel sender float and makes the gauge read full. Things can get quiet in a little while. There are kits available to replace the flush cap with a raised cap, like those found on the 172, and they don't let water in nearly so much. They have a decent rubber gasket, not an O-ring. Tanks that aren't full can promote condensation. Mostly it's a problem on airplanes parked outside where the wings suffer wide temperature swings between day and night. As the tanks cool (radiative cooling into a clear sky can really aggravate it) moist air is drawn in. As cooling progresses further, the moisture condenses out of that air onto the tank walls, where it runs down and under the fuel. Next morning, the sun heats the tanks, drives some of the now-drier air out and leaving the water behind, and makes room for another load that evening. Airplanes that sit outside for many weeks in humid areas will get water in the tanks. Some airplanes don't have sump drains. Sounds stupid, but the manufacturers can get away with it. Both of the Citabrias we bought had plugs in thos sump drains, which we replaced with drain valves. The fuel selector on most Cessna 172/182 and others has a plug in it too, that's supposed to come out every 100 hours. Most won't bother. It gets a drain valve, too. Look under the belly, about under the front of the copilot's seat. Sometimes you don't get the water out. Bladder-type tanks can have lateral wrinkles that prevent the water's flowing to the sump. There's another Cessna AD on that issue. If the wrinkles trap enough water, turbulence can dislodge it and it ends up filling the strainer to the point that the carb gets it. Silence ensues. Some carbs have really small metering jets that won't pass a droplet of water, due to its surface tension. Not a good scene at all. More silence. One drop can ruin your whole day. Many carbs have drain plugs that should come out once in a while to clear out the accumulated small bits that get past filters, and any water. The metering jet is a little above the bottom of the float bowl, so some water can exist in there until it becomes enough to cause trouble. Water that sits in a tank long enough can absorb the blue dye and some of the odor. Beware. Water left in aluminum tanks will corrode them. We've found corrosion products and pitting in fuel strainer bowls, indicating that some owners don't bother draining them, and their mechanics never take them apart. False economy of the worst sort. Water in fuel come in three forms: dissolved (all fuel has a little), entrained (suspended water droplets) and free water, the stuff we find in the test cup. Dissolved water can precipitate into what looks like "snow" in the fuel in cold weather and plug filters. Entrained water will do that, too. Neglected free water can freeze in drain valves and fuel lines, or just plain stop the engine. Winter mogas, the stuff "without" ethanol, has a little ethanol in it to prevent line freezup in cars. Seems to work ok in airplanes, too. It amounts to less than 1%, they tell me. I wouldn't trust it so much that I don't check for water. Automobile tanks are a different setup than in airplanes. Controlled venting through filter canisters, underneath the car where radiative cooling is no hassle, filters that won't pass water, and so on. Dan |
On Mar 15, 3:56*am, Ron Garret wrote:
It occurred to me today that in fifteen years of flying I have never once found water in my fuel when I've drained my tanks. *Not a drop. * Ever. *Am I just lucky, or is this really as rare an occurrence as it seems to be? *(I fly in SoCal. *Maybe that has something to do with it..) rg I've never come across any either, but my experience is limited. How do the big boys check for water, the Boeings and the Busses? Wil |
Stupid question: water in fuel | Scott Moore | Instrument Flight Rules | 18 | October 24th 05 04:19 PM |
"Out of fuel, out of hope: 'Help, I'm in the water'" | [email protected] | Piloting | 145 | May 3rd 05 11:21 PM |
Fuel quality control standards for aircraft rental/fuel sales... | [email protected] | Owning | 19 | January 19th 05 04:12 AM |
Water, water, everywhere, but none for thirsty wings.... | Chris OCallaghan | Soaring | 0 | November 21st 04 03:14 PM |
Airplane Parts on Ebay Vac Reg Valves, Fuel Floats, O-200 Spider, Fuel Injection Valve | Bill Berle | Aviation Marketplace | 0 | January 26th 04 07:48 AM |
