#11
Larry Dighera wrote in
: On Sat, 15 Mar 2008 06:36:23 -0600, "Neil Gould" wrote: Recently, Ron Garret posted: Anyone know why landings for night currency have to be to a full stop? Possibly because currency for carrying pax also requires full-stop landings. Getting night currency satisfies both requirements. Day full-stop landings for passenger carrying currency are only required for tail-wheel aircraft: http://ecfr.gpoaccess.gov/cgi/t/text...dx?c=ecfr&sid= 477ffe5f8e7b7b 7fc7d82953c1e69200&rgn=div5&view=text&node=14:2.0. 1.1.2&idno=14 § 61.57 Recent flight experience: Pilot in command. (a) General experience. (1) Except as provided in paragraph (e) of this section, no person may act as a pilot in command of an aircraft carrying passengers or of an aircraft certificated for more than one pilot flight crewmember unless that person has made at least three takeoffs and three landings within the preceding 90 days, and— (i) The person acted as the sole manipulator of the flight controls; and (ii) The required takeoffs and landings were performed in an aircraft of the same category, class, and type (if a type rating is required), and, if the aircraft to be flown is an airplane with a tailwheel, the takeoffs and landings must have been made to a full stop in an airplane with a tailwheel. (2) For the purpose of meeting the requirements of paragraph (a)(1) of this section, a person may act as a pilot in command of an aircraft under day VFR or day IFR, provided no persons or property are carried on board the aircraft, other than those necessary for the conduct of the flight. (3) The takeoffs and landings required by paragraph (a)(1) of this section may be accomplished in a flight simulator or flight training device that is— (i) Approved by the Administrator for landings; and (ii) Used in accordance with an approved course conducted by a training center certificated under part 142 of this chapter. (b) Night takeoff and landing experience. (1) Except as provided in paragraph (e) of this section, no person may act as pilot in command of an aircraft carrying passengers during the period beginning 1 hour after sunset and ending 1 hour before sunrise, unless within the preceding 90 days that person has made at least three takeoffs and three landings to a full stop during the period beginning 1 hour after sunset and ending 1 hour before sunrise, and— (i) That person acted as sole manipulator of the flight controls; and (ii) The required takeoffs and landings were performed in an aircraft of the same category, class, and type (if a type rating is required). (2) The takeoffs and landings required by paragraph (b)(1) of this section may be accomplished in a flight simulator that is— (i) Approved by the Administrator for takeoffs and landings, if the visual system is adjusted to represent the period described in paragraph (b)(1) of this section; and (ii) Used in accordance with an approved course conducted by a training center certificated under part 142 of this chapter. I bet you sit at the airport and check on people doing this. Bertie |
On Sat, 15 Mar 2008 06:51:32 -0700 (PDT), Tina
wrote: What is the definition of a takeoff and landing anyway? It seems the FAA intentionally omitted those terms from the Pilot/Controller Glossary: http://www.faa.gov/airports_airtraff.../PCG/index.htm |
![]() "Tina" wrote in message ... What is the definition of a takeoff and landing anyway? On a long runway in a 172 one could land on the numbers, get below flying speed, add throttle and lift off and repeat that sequence a number of times in a single pass. Is each such touch and go an FAA recognized landing and take off? Sure, why not? |
: On Sat, 15 Mar 2008 06:51:32 -0700 (PDT), Tina wrote: What is the definition of a takeoff and landing anyway? It seems the FAA intentionally omitted those terms from the Pilot/Controller Glossary: A netkkkop AND a conspirawhacko. YOu're a man of many talents, there, Larry. Bertie |
On Mar 15, 8:30 am, Larry Dighera wrote:
On Sat, 15 Mar 2008 07:13:27 -0400, Bob Noel wrote: In article , "Neil Gould" wrote: Anyone know why landings for night currency have to be to a full stop? Possibly because currency for carrying pax also requires full-stop landings. Getting night currency satisfies both requirements. Day currency to carry passengers don't require full stop landings. The lighting conditions during the day may be superior to those at night, thus facilitating visually acquiring the location of the far end of the runway, so as to estimate whether there is sufficient runway remaining to conduct the takeoff phase of the touch and go maneuver. Do you perchance work for the IRS or other extraneous gub'mnt agency? If not, your talents for obfuscation are wasted here. |
On Mar 15, 9:17 am, Bertie the Bunyip wrote:
Larry Dighera wrote : On Sat, 15 Mar 2008 06:36:23 -0600, "Neil Gould" wrote: Recently, Ron Garret posted: Anyone know why landings for night currency have to be to a full stop? Possibly because currency for carrying pax also requires full-stop landings. Getting night currency satisfies both requirements. Day full-stop landings for passenger carrying currency are only required for tail-wheel aircraft: http://ecfr.gpoaccess.gov/cgi/t/text...dx?c=ecfr&sid= 477ffe5f8e7b7b 7fc7d82953c1e69200&rgn=div5&view=text&node=14:2.0. 1.1.2&idno=14 § 61.57 Recent flight experience: Pilot in command. (a) General experience. (1) Except as provided in paragraph (e) of this section, no person may act as a pilot in command of an aircraft carrying passengers or of an aircraft certificated for more than one pilot flight crewmember unless that person has made at least three takeoffs and three landings within the preceding 90 days, and-- (i) The person acted as the sole manipulator of the flight controls; and (ii) The required takeoffs and landings were performed in an aircraft of the same category, class, and type (if a type rating is required), and, if the aircraft to be flown is an airplane with a tailwheel, the takeoffs and landings must have been made to a full stop in an airplane with a tailwheel. (2) For the purpose of meeting the requirements of paragraph (a)(1) of this section, a person may act as a pilot in command of an aircraft under day VFR or day IFR, provided no persons or property are carried on board the aircraft, other than those necessary for the conduct of the flight. (3) The takeoffs and landings required by paragraph (a)(1) of this section may be accomplished in a flight simulator or flight training device that is-- (i) Approved by the Administrator for landings; and (ii) Used in accordance with an approved course conducted by a training center certificated under part 142 of this chapter. (b) Night takeoff and landing experience. (1) Except as provided in paragraph (e) of this section, no person may act as pilot in command of an aircraft carrying passengers during the period beginning 1 hour after sunset and ending 1 hour before sunrise, unless within the preceding 90 days that person has made at least three takeoffs and three landings to a full stop during the period beginning 1 hour after sunset and ending 1 hour before sunrise, and-- (i) That person acted as sole manipulator of the flight controls; and (ii) The required takeoffs and landings were performed in an aircraft of the same category, class, and type (if a type rating is required). (2) The takeoffs and landings required by paragraph (b)(1) of this section may be accomplished in a flight simulator that is-- (i) Approved by the Administrator for takeoffs and landings, if the visual system is adjusted to represent the period described in paragraph (b)(1) of this section; and (ii) Used in accordance with an approved course conducted by a training center certificated under part 142 of this chapter. I bet you sit at the airport and check on people doing this. Bertie He should (if he doesn't) work for the IRS in the Sanctimonious Buttmunchers Secftion. Crikey, what a ******! Larry "Never use a word where a paragraph will do" Dighera |
On Mar 15, 8:40 am, "Capt. Geoffrey Thorpe" The Sea Hawk At Wow Way
D0t C0m wrote: "Ron Garret" wrote in message ... Anyone know why landings for night currency have to be to a full stop? Because that's what in CFR part blah blah blah... If you are trying to make sense of the regulations, well, good luck... -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. Nah, he just wanted to give Larry a chance to air out his tonsils in the spirit of Christian brotherhood. |
On Mar 15, 9:22 am, Bertie the Bunyip wrote:
Larry Dighera wrote : On Sat, 15 Mar 2008 06:51:32 -0700 (PDT), Tina wrote: What is the definition of a takeoff and landing anyway? It seems the FAA intentionally omitted those terms from the Pilot/Controller Glossary: A netkkkop AND a conspirawhacko. YOu're a man of many talents, there, Larry. Bertie Define "man" and "talents" please Herr Bunyip. Grazie. Richard (I believe using either and esp. both in the same sentence to describe anything to do with Mr. D to be an example of faulty thinking). |
Old joke on night landings | Danny Dot | Piloting | 0 | November 14th 06 08:41 PM |
Touch and Goes versus Full Stop Taxi Backs | Kevin Dunlevy | Piloting | 81 | September 18th 05 09:26 PM |
First Stop Syria, Next Stop Iran | [email protected] | Naval Aviation | 6 | July 22nd 05 09:58 PM |
Radio protocol regarding full stops on full stop only nights | Ben Hallert | Piloting | 33 | February 9th 05 07:52 PM |
Night landings vs. day landings | Gerald Sylvester | Piloting | 15 | February 12th 04 06:38 AM |
