On Mar 15, 10:57 pm, wrote:
I think the more bottom rudder you give in a turn, the more the nose will appear to move lower against a given horizon. All the rudder does is pull the plane around an axis from ear-to-ear. The rudder is intended to control adverse yaw, not to turn the airplane. Banking the airplane turns it. Some airplanes, the "idiot- proof" ones, sometimes need no rudder at all in a turn. Dan |
On Mar 16, 3:41 pm, wrote:
On Mar 15, 10:57 pm, wrote: I think the more bottom rudder you give in a turn, the more the nose will appear to move lower against a given horizon. All the rudder does is pull the plane around an axis from ear-to-ear. The rudder is intended to control adverse yaw, not to turn the airplane. Banking the airplane turns it. Some airplanes, the "idiot- proof" ones, sometimes need no rudder at all in a turn. Dan Actually, I beg to differ. Banking rotates the airplane about its longitudinal axis. Yawing rotates about its vertical axis. Neither of these causes the airplane to change heading. It is the aerodynamic forces that streamlines the airplane with the relative wind is what makes it turn (ie weather vaning). For comparison, think of the space shuttle banking or yawing in orbit. This does not change its heading because there is no streamlining effect. |
On Mar 16, 1:47 pm, Andrew Sarangan wrote:
On Mar 16, 3:41 pm, wrote: On Mar 15, 10:57 pm, wrote: I think the more bottom rudder you give in a turn, the more the nose will appear to move lower against a given horizon. All the rudder does is pull the plane around an axis from ear-to-ear. The rudder is intended to control adverse yaw, not to turn the airplane. Banking the airplane turns it. Some airplanes, the "idiot- proof" ones, sometimes need no rudder at all in a turn. Dan Actually, I beg to differ. Banking rotates the airplane about its longitudinal axis. Yawing rotates about its vertical axis. Neither of these causes the airplane to change heading. It is the aerodynamic forces that streamlines the airplane with the relative wind is what makes it turn (ie weather vaning). For comparison, think of the space shuttle banking or yawing in orbit. This does not change its heading because there is no streamlining effect. http://www.av8n.com/how/htm/4forces.html#note64 Section 4.3 http://www.av8n.com/how/htm/yaw.html#sec-yaw-stability Section 8.2 The bank moves the airplane sideways. The fin, moved sideways, points the airplane in the new direction. The rudder controls adverse yaw, which tends to drag the nose away from the turn. Dan |
On Sun, 16 Mar 2008 13:47:41 -0700 (PDT), Andrew Sarangan
wrote: Banking rotates the airplane about its longitudinal axis. Yawing rotates about its vertical axis. Neither of these causes the airplane to change heading. It is the aerodynamic forces that streamlines the airplane with the relative wind is what makes it turn (ie weather vaning). And here I always thought it was the lift vector being tilted to one side of vertical that caused the airplane to turn. :-) |
On Mar 15, 4:38*pm, William Hung wrote:
I have heard definitions for both, but I'm still confused. *Anyone care to elaborate? Wil A lot of good inputs, I'm going to need some time... Thanks all, Wil |
Looking for Wing Tip Skids | [email protected] | Soaring | 2 | June 23rd 07 02:48 PM |
slips to landing in PTS | BB | Soaring | 6 | April 17th 07 05:58 AM |
Slips and spins in FSX? | Chris Wells | Simulators | 0 | December 14th 06 08:24 PM |
About forward slips | Mxsmanic | Piloting | 77 | November 2nd 06 11:35 PM |
High skids vs low skids | JKimmel | Rotorcraft | 0 | February 8th 06 01:15 AM |
