C172 and Spins
Old March 19th 08, 02:28 AM posted to rec.aviation.piloting
Dudley Henriques[_2_]
Default C172 and Spins
Dave Doe wrote:
says...
Roger wrote:
On Mon, 17 Mar 2008 18:38:38 -0400, Dudley Henriques
Dan wrote:
Anyone else have expereince with the C172E (1964)?
No matter what I did I could not get that bird to spin to the right.
Left spins take some work, and power helps (of course).
But right it just wallows and then steep spirals.
Dan Mc
Try accelerating the stall a bit just before reaching the 1g stall point .
Decelerate the airplane carrying just a bit of power into the stall,
then just before it would break naturally, apply aggressive pitch, as
the stall breaks, apply full pro-spin rudder. It should break a lot
cleaner and right into the spin; assuming normal rigging.
Of course an extra bit of enthusiasm could lead to a snap roll. :-))
www.rogerhalstead.com
Timing Rog....TIMING!!! With women and flying.......it's all in the
TIMING!!!! :-)))
Question on this - snap rolls can put some big strains on the a/c - so I
presume the a/c (most 172's I've flown, actually make that *all* - are
in the normal cat, not utility) - is aerobatic? - or at least in the
utility category?
I snap rolled a Traumahawk years ago when I performed a stall turn
(himmelman (sp?) - call it what you like) - when I whacked the rudder
in while I was (obviously) still above stall speed. I ended up flick
rolling and upside down and recovered just fine - but it scared the chit
out of me (the turning force was really quite considerable).
Opinions?
Only one. Don't snap a normal OR a utility category airplane. It ain't
healthy! :-)) Neither category comes near meeting aerobatic category
standards.
I would strongly suggest from reading what you say you were doing with a
Tomahawk that you not continue that practice PLEASE!!!!!!!!!!!!!!!!!!!!!
Dudley Henriques
Old March 20th 08, 03:58 AM posted to rec.aviation.piloting
Roger[_4_]
On Tue, 18 Mar 2008 21:03:09 -0400, Dudley Henriques
Dan Mc
TIMING!!!! :-)))
Yup, and if your timing is off on either they are likely to give you
an attitude adjustment along with a new outlook on life.:-))
Old March 20th 08, 04:27 AM posted to rec.aviation.piloting
Dan Mc
TIMING!!!! :-)))
At first glance the control inputs seem similar, but there are subtle
differences between the two maneuver entries.
There is no doubt that if mishandled, a ham handed pilot could initiate
a snap roll, but if done the way I suggested, the result should only be
an erect spin entry in an airplane like a 172.
The difference in the two inputs is that to initiate a snap, you need an
airspeed higher than for the spin entry but below Va, and the entry is
different. For the snap, you raise the nose to entry airspeed and
briskly apply full RUDDER in the desired roll direction. This is
FOLLOWED almost immediately with full back stick to cause an acellerated
stall. You need almost perfect timing to get it just right. Although
it's two control inputs, they are "jointed together" as one.
For the spin entry, you are simply leading a 1g stall at a very low
energy state with a pitch input without the rudder lead until the stall
breaks. As it breaks, you THEN apply pro-spin rudder to yaw the wing
into auto rotation.
I've never seen a snap roll develop from the spin entry input. The
controls are out of sequence; the timing is different; and the energy
state at initiation is not high enough to snap an airplane like a 172.
Dudley Henriques
Old March 19th 08, 01:40 AM posted to rec.aviation.piloting
Dan[_10_]
Dan Mc
(N833R, S# CD-2 Worlds oldest Debonair)www.rogerhalstead.com
An enthusiastic Cross control stall has the same effect.
"Hey, I'm right side up!"
"Hey, I'm upside down!"
Dan
Old March 19th 08, 04:04 AM posted to rec.aviation.piloting
Ken S. Tucker
Dan Mc
Now you're talking!
Do a 180 roll, then stall, and watch the heading
indicator do a fast 180, (The attitude indicator is
having a fit), as you recover from a spiral dive.
Most Flight Instructors are sissy pilots, that's
how I qualify them, by how much they shreak.
Ken
Old March 21st 08, 01:16 AM posted to rec.aviation.piloting
Bertie the Bunyip[_24_]
"Ken S. Tucker" wrote in
right.
Dan Mc
point . Decelerate the airplane carrying just a bit of power into
the stall, then just before it would break naturally, apply
aggressive pitch, as the stall breaks, apply full pro-spin rudder.
It should break a lot cleaner and right into the spin; assuming
normal rigging.
:-)) Roger Halstead (K8RI & ARRL life member)
Now you're talking!
Good God. Those poor boys
Bertie
Old March 19th 08, 01:46 AM posted to rec.aviation.piloting
Highflyer
"Roger" wrote in message
Dan Mc
Hi Roger,
That is understandable. Of course, a snap roll is just a spin in a
different direction! :-) It is the only way to roll in an old Citabria with
no spades. Otherwise your arm wears out holding that aileron pressure! :-)
Highflyer
Highflight Aviation Services
Pinckneyville Airport PJY
Old March 17th 08, 11:42 PM posted to rec.aviation.piloting
Dan Mc
172s are reluctant to spin anyway. They'll do it to the lft
readily enough if some power is used to get the speed lower and nose
higher just before stall, but to the right they'll sometimes just
rumble around into a spiral. The left wing stalls earlier due to the
rotating propeller blast striking the left root at a higher AOA, and
so trying to spin right just makes them both stall at the same time,
which won't encourage autorotation.
Dan
Old March 18th 08, 01:42 AM posted to rec.aviation.piloting
skym
Dan Mc
* * 172s are reluctant to spin anyway. They'll do it to the lft
* * * Dan
What is difference between a spin and a spiral?
Old March 18th 08, 01:47 AM posted to rec.aviation.piloting
Dan[_10_]
Dan Mc
Dan
A spin is a condition of stalled flight -- usually due to yaw applied
at the moment the wing stalls. This can be caused intentionally or
unintentionally (such as not accounting for left turning when
practicing stalls).
Airspeed is very low, while descent rate is high, all while pitching
and yawing to the right or left. One wing is providing slightly more
lift and this causes the autorotation.
The wings are not stalled in a spiral, and the airspeed is high and/
or increasing.
Dan Mc
Spins [email protected] Piloting 213 January 27th 08 12:37 AM
Any Spins Lately?? Ol Shy & Bashful Piloting 28 September 6th 07 10:22 PM
Slips and spins in FSX? Chris Wells Simulators 0 December 14th 06 08:24 PM
Spins in Libelles 301 & 201 HL Falbaum Soaring 9 February 10th 04 06:12 PM
Thanks for the Spins Rich David B. Cole Aerobatics 17 October 26th 03 08:37 AM
