#11
Rich S. wrote:
"cavelamb himself" wrote in message ... Rich S. wrote: Even with washout, the Emeraude (elliptical planform - 23012 airfoil) will stall fairly abruptly. Like, at 50 you're flying - at 49 you're not. Rich S. That's a function of the wing planform - not the airfoil. That's what I said. The info on airfoil was for comparison with the "Hershey bar" RV wing - the same airfoil - different planform. Rich S. Just checkin' ![]() Some guys like to think it's the airfoil. Richard |
... Just checkin' ![]() Some guys like to think it's the airfoil. Gotcha. It's a bit ironic. You go to all the trouble to build a neat looking elliptical wing (I love a Spit and a Jug for that reason) and you get a sharper stall than a plain jane rectangular wing. 'Taint fair! Rich S. |
Rich S. wrote:
"cavelamb himself" wrote in message ... Just checkin' ![]() Some guys like to think it's the airfoil. Gotcha. It's a bit ironic. You go to all the trouble to build a neat looking elliptical wing (I love a Spit and a Jug for that reason) and you get a sharper stall than a plain jane rectangular wing. 'Taint fair! Rich S. Yeah, but you reduce induced drag and bending moment, so I guess it's a wash... out ![]() Richard |
On Tue, 25 Mar 2008 02:00:20 -0600, cavelamb himself
wrote: Rich S. wrote: "cavelamb himself" wrote in message ... Just checkin' ![]() Some guys like to think it's the airfoil. Gotcha. It's a bit ironic. You go to all the trouble to build a neat looking elliptical wing (I love a Spit and a Jug for that reason) and you get a sharper stall than a plain jane rectangular wing. 'Taint fair! Rich S. Yeah, but you reduce induced drag and bending moment, so I guess it's a wash... out ![]() Richard I'll still go with what I wrote. stick some vortex generators out in the last yard to the tips and see how that goes at keeping the flow attached Mr Shankland. dang I'll need to build my turbulent with the slots. Stealth Pilot |
Thanks for all the advice and discussion. Looks like stall strips
could be the way to go. I think I'll experiment with the VGs too. BTW, the wing is rectangular. Or put a "triangle" shaped addition on the leading edge of the wing's root, to trip that portion into stall, first. That's all anyone is after with washout. Keep the outer portion flying, while the root is stalling. If it were me, I would probably do a bit of both! g Advantages of keeping the wing with no washout is that the whole wing will be lifting at cruise, instead of throwing away part of the outer wing's lift with added washout. big john and morgans have it with the triangular strips. you just tape them on and keep shortening them until you have the stall chracteristics you need. then you replace the temporaries with permanent ones. make both sides identical. work out where the 3 degree angle of attack neutral point is on the leading edge and stick them there. |
![]() wrote: Thanks for all the advice and discussion. Looks like stall strips could be the way to go. I think I'll experiment with the VGs too. BTW, the wing is rectangular. See.... http://selair.selkirk.bc.ca/aerodyna...l_Pattern.html Since the AOA is reduced by the up-wash we must predict that a rectangular wing will have a greater effective angle of attack at the root, and therefore will stall first at the root. YMMV. - Barnyard BOb - |
Barnyard BOb wrote:
wrote: Thanks for all the advice and discussion. Looks like stall strips could be the way to go. I think I'll experiment with the VGs too. BTW, the wing is rectangular. See.... http://selair.selkirk.bc.ca/aerodyna...l_Pattern.html Since the AOA is reduced by the up-wash we must predict that a rectangular wing will have a greater effective angle of attack at the root, and therefore will stall first at the root. YMMV. - Barnyard BOb - Which brings us all back to the question What Is It??? Rectangular wing or soemthing else? Richard -- (remove the X to email) cave page at: http://www.home.earthlink.net/~cavelamb/index.htm#top It's never too late to be the person you might have been. George Elliot |
![]() "cavelamb himself" wrote Which brings us all back to the question What Is It??? Rectangular wing or soemthing else? I recall being told rectangular, but only after all of the stall strip advice began flowing. As Barnyard said, probably no need to do anything with rectangular, but I would thing if it was found to be needed afterwards, adding a stall strip would be easy enough. -- Jim in NC |
... Rich S. wrote: "cavelamb himself" wrote in message ... Just checkin' ![]() Some guys like to think it's the airfoil. Gotcha. It's a bit ironic. You go to all the trouble to build a neat looking elliptical wing (I love a Spit and a Jug for that reason) and you get a sharper stall than a plain jane rectangular wing. 'Taint fair! Rich S. Yeah, but you reduce induced drag and bending moment, so I guess it's a wash... out Just like putting some washout into a rectangular wing. ;-) ;-) -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. |
"Stealth Pilot" wrote in message
... stick some vortex generators out in the last yard to the tips and see how that goes at keeping the flow attached Mr Shankland. dang I'll need to build my turbulent with the slots. I wouldn't change a thing, actually. The abrupt stall isn't a problem at all - if you know it's coming. After the stall, you can hold the stick in your lap and, if you are quick on the rudder pedals, you can maintain a heck of a rate of descent in a level attitude. Let it go a bit too far though and she'll be in a spin right now. Normal recovery technique stops the spin within a turn. Rich S. |
Can Washout Cause Flutter?? | DonMorrisey | Home Built | 12 | January 19th 07 02:32 AM |
Stall strips vs. Washout | [email protected] | Home Built | 27 | February 27th 05 08:59 AM |
