#11
"The Enlightenment" wrote in message ...
The tubes involved were special power amplifier tubes with heavy anode cathode currents that must have been erosive. I do not believe they had nearly 10,000 hours life. Amplifying DC was not possible because directly unlike today when complimentary npn and pnp transistors are available only valves were available and they had very particular biasing requirements. While I am not doubting your explanation of the turrets electronics, I must wonder what the engineers were drinking back then. They obviously did not talk much with the radar folks. In many WW2 era radars (ship, ground, and air), vibrators are not used. In fact, garden variety 6L6 tubes (of guitar amp fame, these days) were a favorite, used to vary the field windings in some sort of motor-generator (Amplidynes were used, even back to the pre-War Navy CXAM days, but there were some other types). This was a very good system - responsive, accurate, and able to swing an antenna around that was much heavyier than the turrets on an airplane. Why did the aircraft gun people not use this technology until later? During the Korean war the electromechanical computers of the B29 could not compute for the closing rates of the MiG 15s. I don't see how they would have coped with an Me 262 in that case. This problem was also around in other tracking radar computers. William Donzelli |
Its sounds crude but was quite accurate. A full serve system would involved resistors for position sensing that were amplified in DC, amplidynes which operated in AC to generate mathematical functions such as sine, cos etc (amplidyne is a sort of rotary transformer in which the overlap of the poles of the two secondary windings are added/subtracted from each other. The area of he poles can be used to generate voltages that are functions of shaft position. By the way, I think you are confusing "Amplidyne" with "Synchro" and "Selsyn". An Amplidyne is a special motor-generator that basically acts like a magnetic amplifier - vary the fields a little and get a larger change on the output. A Synchro (or Selsyn) is what you mean - a rotary transformer that can transmit angular data electrically (generally with three wires as multiphase AC). The things that can generate the sine and cosine from an angular shaft position are called "Synchro Resolvers". William Donzelli |
| Thread Tools | |
| Display Modes | |
| Czechoslovak nuclear weapons? Warszaw Pact War Plans ( The Effects of a Global Thermonuclear War ...) | Matt Wiser | Military Aviation | 25 | January 17th 04 03:18 PM |
| please stop bashing France | Grantland | Military Aviation | 233 | October 29th 03 02:23 AM |
| What about the AIM-54 Pheonix Missile? | Flub | Military Aviation | 26 | October 5th 03 06:34 AM |
| P-47/51 deflection shots into the belly of the German tanks,reality | ArtKramr | Military Aviation | 131 | September 7th 03 10:02 PM |
| Laser simulator provides weapons training | Otis Willie | Military Aviation | 0 | August 28th 03 10:58 PM |
