canopy breaking tool?
Old September 19th 03, 02:02 AM
Corrie
Also, it would mean flying with a pipe bomb in the cockpit.
Pipe bomb with a steel spike in the end. FARs or no FARs, that is the
operative statement. It also has to be built to survive the crash and
turnover, safetied to not go off until triggered despite the G-loads
of a hard landing and turnover (not to mention normal flight)...
Build in a kick-out panel between the seat and rudder pedals, maybe?
Old September 19th 03, 04:28 PM
Snowbird
Dave Hyde wrote in message ...
Russell Duffy wrote:
Rusty (building 3 planes for every one that Dave finishes g)
OW! Who stuck the 'kick me' sign on my back?
Dave 'Only 3? I'm not done yet' Hyde
Far side cartoon: "Bummer of a Birthmark, Hal"
http://store1.yimg.com/I/coolrags_1753_1742593
It's only because you're so CLOSE, and the Natives are
restless for the First Flight report.
Sydney
PS Mike said "sure" and would be happy to talk specifics.
Old September 21st 03, 09:18 PM
Bruce A. Frank
Corrie wrote:
All good reasons to fly open cockpit, eh, Ron? ;-)
But with a roll bar!
Bruce A. Frank, Editor "Ford 3.8/4.2L Engine and V-6 STOL
Homebuilt Aircraft Newsletter"
| Publishing interesting material|
| on all aspects of alternative |
| engines and homebuilt aircraft.|
While trying to find the time to finish mine.
Old September 22nd 03, 02:12 AM
On Sun, 21 Sep 2003 20:18:00 GMT, "Bruce A. Frank"
I'd be happy enough with the key to the roll mini-bar. :-)
Old September 22nd 03, 05:37 AM
Bruce A. Frank
There is certainly no law against carrying personal firearms in a
privately owned plane.
Bryan Martin wrote:
in article .net,
Flightdeck at wrote on 9/17/03 8:50 AM:
Here is the question. I used the 32 cal blank shells because that was the
most direct way to get the gas pressure I needed in the chamber. I made one
version that used a modified 410 shot gun shell - but it required more bulk
than the 32 cal shell firing mechinism. And, I considered using the
internal volume of the "pry tube" as a pressure chamber for high pressure
Nitrogen, but the complexity of the filling fittings and the explosive
decompression valve was too much work. Also, it would mean flying with a
pipe bomb in the cockpit. I happened to be describing the device to a
friend over a $100 cup of coffee one day and a fellow in the next booth
overheard the conversation. He volunteered that the device violated FARs
because it could be considered as carrying an "explosive device" in a civil
aircraft.
If a .32 blank is considered an explosive device illegal to carry in a civil
aircraft, then every bush pilot in the country is in violation of the law by
carrying firearms in the cockpit for survival in case of forced landing. As
I understand it, in some areas a firearm is required by law to be carried in
the airplane. And of course, gasoline must be far too dangerous to carry in
an airplane.
Old September 22nd 03, 06:05 AM
richard
On Mon, 22 Sep 2003 04:37:04 GMT, "Bruce A. Frank"
:There is certainly no law against carrying personal firearms in a
Depends on what state you're in. Don't try it in Massachusetts.
Old September 22nd 03, 06:29 AM
B2431
Airports are federally controlled despite the state cops (in Logan's case)
patrolling. If you secure your fire arm in the aircraft when you leave it there
should be no problem.
My 2000 Federal Firearms Regulation Reference Guide says nothing about it. Now
I am curious and will call ATF.
Dan, U. S. Air Force, retired
Tool Question??? Paul Home Built 2 September 1st 03 04:06 PM
FS: SECURITY 150 PARACHUTE PACK W/O CANOPY Tim Hanke Home Built 0 July 21st 03 05:59 PM
