#11
On Apr 8, 8:51 am, "Wayne Paul" wrote:
"Bob Kuykendall" wrote in message ... On Apr 6, 2:55 pm, wrote: So the question to RAS is: What are my best options? Anyone have any good ideas on how to build a glider trailer for cheap? I could probably make a 4 or 5 foot wide and 22 foot long trailer work. I understand steel prices are pretty high nowdays. Is anyone building their own trailers anymore or just buying factory built? Thanks! I've made things shaped like trailers, but fortunately never a whole trailer: http://www.hpaircraft.com/hp%2D24/up...9_March_06.htm Buy yourself a nice 180 amp MIG welder and set it up for flux core (no shielding gas) welding. I recommend the Hobart, not one of those cheap Harbor Freight zot boxes. Get a good auto-darkening hood and a mask for the particulates (lots of Manganese). You'll be making perfectly serviceable welds inside a couple hours. Also get a cheap 14" chop saw (HF will do for that). After that, copy any trailer you like. Thanks, Bob K. Here is another idea.http://www.soaridaho.com/Schreder/Co...Design_1/Trail... Waynehttp://www.soaridaho.com/ Tony, this nice clamshell homebuilt trailer design is on the 1-26 association's classifieds page: http://www.126association.org/graphics/126trlr.jpg. I can not get the link for the trailer guy's webpage to work from the 1-26 classifieds, but there is contact info in the title block on the picture I linked. Text from the 1-26 classifieds ad: "This fully enclosed lift top trailer is designed for the 1-26. It is constructed of steel tube frame and covered with pre-painted aluminum. A complete set of drawings showing trailer construction which provides a means of restraining the wings, fuselage and stabilizer for transport. The fittings allow easy loading and unloading of the components. This design is lifted from our very successful 15 meter sailplane trailer series. The 1-26 plans set includes ½ scale drawings, bills of material, source of material, individual part drawings showing necessary details and construction instructions." "Build time is approximately 100 hours. A drawing set is provided for your exclusive use, not to be resold or distributed. Cost is $100.00 per drawing set." It looks like a straightforward construction project, and since nearly any trailer you make will take appx the same amount of time, cost the same amount of money, so pick a good design from the getgo. The shape trailer you need is probably halfway between the 1-26 clamshell (similar root cord size= similar trailer hight) and the 15m trailer (length) they offer plans for. Use A 500 structural steel (grade b if available) for the frame and steel components. It has appx 80%-90% the strength of chromemoly, at appx 5% the cost. I too have a clamshell trailer design, but it is not intended to be a cheap or quick build. However, if I do pony up the cash and build it, my trailer will be several notches up on a Cobra, (mostly due to not being designed around cost effective repetitive construction, but also using far more exotic materials for most of it than can be justified as a commercially viable product). I disagree with the earlier poster recommending torsion axles. Without adding additional reinforcement to the frame above the axle, (or designing the trailer around a specific setup) these usually cause trailers to sag at the pinpoint fulcrum the whole burrito is balanced on. They will not have as much travel, and it has a much steeper progression to the suspension travel than do leaf springs. Trailer sales people love torsion axles because they are cheaper than a leaf setup in most cases, and you only have to pay for half the welding to install it. Leaf springs are also easy to install though (just take a little longer due to more parts and attach points) and distribute the weight of the trailer across a larger area, and usually do not require the trailer to be reinforced there. Best of all though, if you use a drop axle you have lots of room for suspension travel. If one wanted the ultimate in performance though, one would use independent suspension (available in both leaf or torsion), but I digress, this is an exotic, unnecessary, and expensive solution to a practically non existent problem. Lastly, I highly recommend against the notion of adding surge brakes to whatever trailer option you go with. A while back I posted 10 good reasons to use electric brakes instead, and I have not changed my position. In fact, I have only had longer to reinforce my opinion, based on more direct observation. I have a non published article I wrote on the subject I would be happy to forward you if interested, or anyone else for that matter. Paul Hanson Paul |
On Apr 8, 12:03 pm, sisu1a wrote:
On Apr 8, 8:51 am, "Wayne Paul" wrote: "Bob Kuykendall" wrote in message ... On Apr 6, 2:55 pm, wrote: So the question to RAS is: What are my best options? Anyone have any good ideas on how to build a glider trailer for cheap? I could probably make a 4 or 5 foot wide and 22 foot long trailer work. I understand steel prices are pretty high nowdays. Is anyone building their own trailers anymore or just buying factory built? Thanks! I've made things shaped like trailers, but fortunately never a whole trailer: http://www.hpaircraft.com/hp%2D24/up...9_March_06.htm Buy yourself a nice 180 amp MIG welder and set it up for flux core (no shielding gas) welding. I recommend the Hobart, not one of those cheap Harbor Freight zot boxes. Get a good auto-darkening hood and a mask for the particulates (lots of Manganese). You'll be making perfectly serviceable welds inside a couple hours. Also get a cheap 14" chop saw (HF will do for that). After that, copy any trailer you like. Thanks, Bob K. Here is another idea.http://www.soaridaho.com/Schreder/Co...Design_1/Trail... Waynehttp://www.soaridaho.com/ Tony, this nice clamshell homebuilt trailer design is on the 1-26 association's classifieds page:http://www.126association.org/graphics/126trlr.jpg. I can not get the link for the trailer guy's webpage to work from the 1-26 classifieds, but there is contact info in the title block on the picture I linked. Text from the 1-26 classifieds ad: "This fully enclosed lift top trailer is designed for the 1-26. It is constructed of steel tube frame and covered with pre-painted aluminum. A complete set of drawings showing trailer construction which provides a means of restraining the wings, fuselage and stabilizer for transport. The fittings allow easy loading and unloading of the components. This design is lifted from our very successful 15 meter sailplane trailer series. The 1-26 plans set includes ½ scale drawings, bills of material, source of material, individual part drawings showing necessary details and construction instructions." "Build time is approximately 100 hours. A drawing set is provided for your exclusive use, not to be resold or distributed. Cost is $100.00 per drawing set." It looks like a straightforward construction project, and since nearly any trailer you make will take appx the same amount of time, cost the same amount of money, so pick a good design from the getgo. The shape trailer you need is probably halfway between the 1-26 clamshell (similar root cord size= similar trailer hight) and the 15m trailer (length) they offer plans for. Use A 500 structural steel (grade b if available) for the frame and steel components. It has appx 80%-90% the strength of chromemoly, at appx 5% the cost. I too have a clamshell trailer design, but it is not intended to be a cheap or quick build. However, if I do pony up the cash and build it, my trailer will be several notches up on a Cobra, (mostly due to not being designed around cost effective repetitive construction, but also using far more exotic materials for most of it than can be justified as a commercially viable product). I disagree with the earlier poster recommending torsion axles. Without adding additional reinforcement to the frame above the axle, (or designing the trailer around a specific setup) these usually cause trailers to sag at the pinpoint fulcrum the whole burrito is balanced on. They will not have as much travel, and it has a much steeper progression to the suspension travel than do leaf springs. Trailer sales people love torsion axles because they are cheaper than a leaf setup in most cases, and you only have to pay for half the welding to install it. Leaf springs are also easy to install though (just take a little longer due to more parts and attach points) and distribute the weight of the trailer across a larger area, and usually do not require the trailer to be reinforced there. Best of all though, if you use a drop axle you have lots of room for suspension travel. If one wanted the ultimate in performance though, one would use independent suspension (available in both leaf or torsion), but I digress, this is an exotic, unnecessary, and expensive solution to a practically non existent problem. Lastly, I highly recommend against the notion of adding surge brakes to whatever trailer option you go with. A while back I posted 10 good reasons to use electric brakes instead, and I have not changed my position. In fact, I have only had longer to reinforce my opinion, based on more direct observation. I have a non published article I wrote on the subject I would be happy to forward you if interested, or anyone else for that matter. Paul Hanson Paul paul, please forward, and thanks for the suggestions. |
\ There is a Cherokee in an enclosed trailer at our airport that hasn't flown in decades. I can put you in contact with the owner, and maybe you can buy a trailer and Cherokee for less money and effort that building your own! \ Oh please do! Tony and I will take good care of it. I sent you an email with the contact info a few minutes ago. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * Updated! "Transponders in Sailplanes" http://tinyurl.com/y739x4 * New Jan '08 - sections on Mode S, TPAS, ADS-B, Flarm, more * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
Decision time....go/no go | Fred Choate | Piloting | 17 | July 14th 05 02:42 PM |
Landing Decision | Charles Talleyrand | Piloting | 33 | July 1st 05 04:16 AM |
Decision time | nobody | Owning | 31 | January 24th 05 10:42 PM |
On one Mag? Temptation and decision | Terry | Piloting | 16 | December 29th 03 11:07 PM |
they took me back in time and the nsa or japan wired my head and now they know the idea came from me so if your back in time and wounder what happen they change tim liverance history for good. I work at rts wright industries and it a time travel trap | tim liverance | Military Aviation | 0 | August 18th 03 12:18 AM |
