On Jun 6, 2:10 pm, wrote:
In fact, I would think that if you hit the trailer brakes that if anything it would make the trailer more likely to sway. Afterall, when you want to drift a car, the easiest way to do that is to pull the emergency brake. It transfers weight forward and off the rear wheels (on in this case the trailer wheels) and it reduces the available traction for the tires to counter the swaying. Admittedly, removing weight from the back end reduces the polar moment as well. At one time I drove semi's and they have two ways to apply brakes; one (a pedal) worked exactly like your car (operated all the brakes) the other was a lever in the cab to operate the trailer brakes only. The rig could be slowed down or stopped using the trailer brakes only, theoretically a sure way to prevent jackknifing. I can tell you that tapping that trailer brake took the sway out very nicely. While it worked very well, owner/operators were rumored to use only the trailer brakes to save on their tractor brakes. This would cause premature brake failure of the trailer brakes and that would lead to some interesting situations during panic stops or runaway conditions with very effective tractor brakes and no brakes on the trailer. Anyway, I think maybe you are not understanding the use of the E brake in a drifted turn, which is done to break traction on the wheels (inducing drift) and not primarily for weight shifting (I think). |
Controlling sway with that lever in the cab of a semi (it's called a
trolley bar BTW) works only if the rear duals have some level of adhesion, in which case you didn't need to use it in the first place. If the trailer duals are already loose (or on the edge), really bad things can happen when you yank the trolley bar. I suspect the effect is similar with an electric brake controller. Most owner-operators have compression (Jake) brakes fitted to the engine and use the air brakes mostly to hold the rig in place at stoplights and the like, the exception being panic stops where you need all the help you can get. No need for brake-saving strategies if you don't use them much in the first place. It's very much like a spot landing, you want to run out of enery right at the stopping point. The above suggests a good strategy for towing any trailer - think far enough ahead of the combination that you can do much of your slowing with engine braking, keep the rig rolling slowly when approaching a stop-light (stopping and restarting costs fuel and adds wear and tear) and, as much as possible, use the brakes only to hold the vehicle in place when stopped. Change lanes to permit vehicles entering an interstate to merge. In this way, you won't be forced to slow down and if they do something stupid ( I once saw a four-wheeler stop and back up), you're already by them. Amuse yourself by trying to predict what the drivers around you are likely to do next. With practice you can get surprisingly good at it. Ray Warshaw 1LK there was the least bit On Jun 9, 12:20*pm, brianDG303 wrote: On Jun 6, 2:10 pm, wrote: * In fact, I would think that if you hit the trailer brakes that if anything it would make the trailer more likely to sway. *Afterall, when you want to drift a car, the easiest way to do that is to pull the emergency brake. *It transfers weight forward and off the rear wheels (on in this case the trailer wheels) and it reduces the available traction for the tires to counter the swaying. Admittedly, removing weight from the back end reduces the polar moment as well. At one time I drove semi's and they have two ways to apply brakes; one (a pedal) worked exactly like your car (operated all the brakes) the other was a lever in the cab to operate the trailer brakes only. The rig could be slowed down or stopped using the trailer brakes only, theoretically a sure way to prevent jackknifing. I can tell you that tapping that trailer brake took the sway out very nicely. While it worked very well, owner/operators were rumored to use only the trailer brakes to save on their tractor brakes. This would cause premature brake failure of the trailer brakes and that would lead to some interesting situations during panic stops or runaway conditions with very effective tractor brakes and no brakes on the trailer. Anyway, I think maybe you are not understanding the use of the E brake in a drifted turn, which is done to break traction on the wheels (inducing drift) and not primarily for weight shifting (I think). |
| Thread Tools | |
| Display Modes | |
| Hydraulic trailer surge brakes means no parking brake? | [email protected] | Soaring | 11 | March 18th 08 05:19 AM |
| Cobra Trailer brakes | R Barry | Soaring | 22 | July 19th 04 05:51 PM |
| A D Day Reflection Revisited | Dudley Henriques | Naval Aviation | 2 | June 5th 04 06:01 AM |
| Concorde Revisited | sandpebble | General Aviation | 0 | December 7th 03 06:10 PM |
| Trailer brakes | Bert Willing | Soaring | 1 | October 31st 03 08:55 AM |
