"Sliker" wrote in message
... ... practice as in theory. And with a 180hp engine, the T-18 owner said he couldn't do a full power runup with the stick all the way back, without the tail coming off the ground. Seems the 180hp T-18's are a bit nose heavy, especially with a constant speed prop. I've noticed in accident reports, nose overs are the most common occurance. One reason ... Personally, the 180 hp is a bit of an overkill for a T-18 if you want my opinion... They will also tend to end up well over John Thorp's design gross weight. Take a look at http://www.t18.net/resources.htm if you havn't already. If you put a lot of attention into the details, you can do pretty darn good on a little old O-290 - see http://www.t18.net/resources/T-18%20orig%20hdbk.doc for some extensive performance data in the middle (I know the builder real well and I believe his numbers. ) -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. |
A 180 does seem like a big engine in that little T-18. If I did put
that much power in one, I'd use something like a Prince prop, which is made from wood, and light. A 180 with a constant speed is a lot of weight to hang on the nose of that little plane. Another thing about the T-18 I'm not wild about is the nose section taper. The sides of the nose taper inward, a design left over from the original idea of the T-18 being open cockpit and having it's cylinders hanging in the breeze, like a J-3's. When it was discovered the plane was too fast for open cockpit, and open cylinders, a canopy was installed and "cheeks" put over the cylinders sticking out. But what should have been done then, was to straighten out the sides of the nose, like an RV 6 or 7. Which would have eliminated the cheeks stuck on the side of the cowling, and provided more room in the forward part of the cockpit, where your feet are. I can't imagine that plane ever being an open cockpit. What was John thinking!? I remember something he wrote that said when they flew it open cockpit, if felt like it would suck you right out of it. So that idea was abandonned early. I guess John just didn't want to go back to the drawing board and draw all new plans for the entire nose section. Another thing one T-18 owner said at SNF was when John designed the T-18, he was thinking in terms of the FAA's 170 lb pilot. But if he had known, the reality is, most guys are upper middle age by the time they finish one, and many have the usual spare tire, and need more than a 38" cockpit width, even 40" is barely enough. 44" should be the minimum for side by side planes. My Glasair 3 is 42", which I think is a bit tight for 2 big guys. On Sat, 12 Apr 2008 18:11:16 -0400, "Capt. Geoffrey Thorpe" The Sea Hawk At Wow Way D0t C0m wrote: "Sliker" wrote in message .. . ... practice as in theory. And with a 180hp engine, the T-18 owner said he couldn't do a full power runup with the stick all the way back, without the tail coming off the ground. Seems the 180hp T-18's are a bit nose heavy, especially with a constant speed prop. I've noticed in accident reports, nose overs are the most common occurance. One reason ... Personally, the 180 hp is a bit of an overkill for a T-18 if you want my opinion... They will also tend to end up well over John Thorp's design gross weight. Take a look at http://www.t18.net/resources.htm if you havn't already. If you put a lot of attention into the details, you can do pretty darn good on a little old O-290 - see http://www.t18.net/resources/T-18%20orig%20hdbk.doc for some extensive performance data in the middle (I know the builder real well and I believe his numbers. ) |
Low towing thought | Martin Gregorie | Soaring | 45 | March 13th 07 03:00 AM |
And you thought AMARC was bad.... | Ron | Aviation Photos | 18 | February 2nd 07 05:27 AM |
Just when I thought I'd heard it all:-) | Dudley Henriques | Piloting | 14 | November 23rd 05 08:18 PM |
A thought on BRS | Martin Gregorie | Soaring | 47 | April 29th 04 06:34 AM |
I thought some of these are classics | goneill | Soaring | 0 | April 8th 04 10:51 AM |
