![]() "WaltBJ" wrote in message om... Slightly off track - the Germans did not seem to place the same level of importance on recce that the Brits and USAF did. Me109s could (some did) carry a camera in the aft fuselage like the recce P51s (F6?). A lightened waxed Me109F or G would have a very good chance of completing a recce pass on an in-and-out basis flown at max speed on a curving descent or in-and-out at naught feet (prop tips above the wave tips). The Me-109G-8 recce variant had a camera in the aft fuselage and did conduct some photo recon missions over the channel area in 1944. Keith |
In article , Keith Willshaw
writes "WaltBJ" wrote in message . com... Slightly off track - the Germans did not seem to place the same level of importance on recce that the Brits and USAF did. Me109s could (some did) carry a camera in the aft fuselage like the recce P51s (F6?). A lightened waxed Me109F or G would have a very good chance of completing a recce pass on an in-and-out basis flown at max speed on a curving descent or in-and-out at naught feet (prop tips above the wave tips). The Me-109G-8 recce variant had a camera in the aft fuselage and did conduct some photo recon missions over the channel area in 1944. Keith Hi Keith, Do you happen to know whether these were conducted at high level, low level, or the max speed altitude for the 109G-8? Cheers, Dave -- Dave Eadsforth |
In article , WaltBJ
writes Slightly off track - the Germans did not seem to place the same level of importance on recce that the Brits and USAF did. Me109s could (some did) carry a camera in the aft fuselage like the recce P51s (F6?). A lightened waxed Me109F or G would have a very good chance of completing a recce pass on an in-and-out basis flown at max speed on a curving descent or in-and-out at naught feet (prop tips above the wave tips). It appears to me that the 86R was declared a 'clay pigeon' when the LW found out Spits and Mosquitoes, appropriately modifed, could get up that high. Why the LW didn't use 'hot-rodded' photofighters is beyond me. Maybe they swallowed the 'XX' turned spies' reports as gospel. Walt BJ Yes, the success of agents like 'Garbo' in feeding duff stuff to the German High Command was remarkable. Without wanting to go wildly off-topic, there was a programme on UK TV a few nights ago ('Spitfire Ace') that had some very useful stuff on the mentality of the RAF versus the that of Luftwaffe in 1940. The RAF (through the vision and efforts of Dowding) had created a parless air defence system, while the Luftwaffe had concentrated overmuch on the lionisation of its individual pilots. I think that by 1944 the Allies had developed a war machine that was thorough enough to filter out most flakey thinking and to concentrate on the real issues. If the Luftwaffe in 1944 was still relying on the whims of 'gifted individuals' (Hitler, Goering), who would have prided their own (uncriticised) judgement then a lot of bad ideas would have good through and a lot of good ideas would have been turned away. Cheers, Dave -- Dave Eadsforth |
Dave Eadsforth wrote:
: Yes, the success of agents like 'Garbo' in feeding duff stuff to the : German High Command was remarkable. The familiar problem, as far as I know: Too many different intelligence services, every one a part of the personal empire of a different Nazi leader, and unwilling or unable to cooperate. And of course the 'Abwehr' leaked like a sieve. The Germans did produce recce versions of fighters, usually with fewer guns and more fuel; in addition to cameras of course. But I suspect the Bf 109 was just less adaptable to the task than the Spitfire. It was even smaller. The Spitfire had inherited a D-shaped leading edge structure from its direct ancestor, the Supermarine 227, which used this as a condensor for its steam-cooled Goshawk engine. This made a great fuel tank for the long-range reconnaissance versions. With better fuel and more powerful engines, these models could also operate at higher weights and reach higher altitudes than Bf 109s. On the other hand Ju 88s were less suitable for reconnaissance than Mosquitoes, because they were bigger and slower. Still, the Germans did develop a high-performance recce aircraft in the Ar 234A. Emmanuel Gustin |
In article , Emmanuel.Gustin
writes Dave Eadsforth wrote: : Yes, the success of agents like 'Garbo' in feeding duff stuff to the : German High Command was remarkable. The familiar problem, as far as I know: Too many different intelligence services, every one a part of the personal empire of a different Nazi leader, and unwilling or unable to cooperate. And of course the 'Abwehr' leaked like a sieve. The Germans did produce recce versions of fighters, usually with fewer guns and more fuel; in addition to cameras of course. But I suspect the Bf 109 was just less adaptable to the task than the Spitfire. It was even smaller. The Spitfire had inherited a D-shaped leading edge structure from its direct ancestor, the Supermarine 227, which used this as a condensor for its steam-cooled Goshawk engine. This made a great fuel tank for the long-range reconnaissance versions. With better fuel and more powerful engines, these models could also operate at higher weights and reach higher altitudes than Bf 109s. On the other hand Ju 88s were less suitable for reconnaissance than Mosquitoes, because they were bigger and slower. Still, the Germans did develop a high-performance recce aircraft in the Ar 234A. Emmanuel Gustin Thanks for that! Re. the Ar 234A, I believe that this machine made a number of attacks on the UK, but I do not know when. Do you happen to have any rough dates? Also, do you happen to know if the Ar 234 (of any mark) was ever used as a recce machine over the UK prior to D-Day? Cheers, Dave -- Dave Eadsforth |
Dave Eadsforth wrote in message ...
In article , WaltBJ writes Slightly off track - the Germans did not seem to place the same level of importance on recce that the Brits and USAF did. Me109s could (some did) carry a camera in the aft fuselage like the recce P51s (F6?). A lightened waxed Me109F or G would have a very good chance of completing a recce pass on an in-and-out basis flown at max speed on a curving descent or in-and-out at naught feet (prop tips above the wave tips). It appears to me that the 86R was declared a 'clay pigeon' when the LW found out Spits and Mosquitoes, appropriately modifed, could get up that high. Why the LW didn't use 'hot-rodded' photofighters is beyond me. Maybe they swallowed the 'XX' turned spies' reports as gospel. Walt BJ Yes, the success of agents like 'Garbo' in feeding duff stuff to the German High Command was remarkable. Without wanting to go wildly off-topic, there was a programme on UK TV a few nights ago ('Spitfire Ace') that had some very useful stuff on the mentality of the RAF versus the that of Luftwaffe in 1940. The RAF (through the vision and efforts of Dowding) had created a parless air defence system, while the Luftwaffe had concentrated overmuch on the lionisation of its individual pilots. Honestly this sounds like Brits patting themselves on the back while not looking at the strategic and tactical issues the Germans faced. (sadly this is a sort of anasthetic as the UK goes down a sewer) I think that by 1944 the Allies had developed a war machine that was thorough enough to filter out most flakey thinking and to concentrate on the real issues. If the Luftwaffe in 1944 was still relying on the whims of 'gifted individuals' (Hitler, Goering), who would have prided their own (uncriticised) judgement then a lot of bad ideas would have good through and a lot of good ideas would have been turned away. German thinking was predicated on the need to fight a short and sharp war as a nation sourunded by hostile countries. Avoiding a war of attrition was essential and avoiding a war on German territory was also essential. The nation was physically to small and to devoid of materials to handle a war in any other way and not loose thus substantial offensive capability was emphasised but it was all up front: resources were not devoted to reinforcements. This was the thinking even before the Nazis came to power. Much of the German work on Microwaves and Proximity fuses (which inspired British research) was suspended because the anything that could not be ready in 2 years would be a waste. It seems that at this point that many of the German might have beens got caned. Examination of this period is perhaps where it might be said that Germany's technical may be said to lie. It migh also just lay in the fact that Germany lacked the resources to develop them. The Tiazard commision handed the proximity fuse and magnetron on a platter for the USA to develop. The Germans just culled. The excelent Freya and Wurzburg Radars were not integrated into a defensive system because the bomber naviagation aids were considered more important. Cheers, Dave |
In article , The
Enlightenment writes Dave Eadsforth wrote in message news:s9BISHBVA3GAFw82 ... In article , WaltBJ writes Slightly off track - the Germans did not seem to place the same level of importance on recce that the Brits and USAF did. Me109s could (some did) carry a camera in the aft fuselage like the recce P51s (F6?). A lightened waxed Me109F or G would have a very good chance of completing a recce pass on an in-and-out basis flown at max speed on a curving descent or in-and-out at naught feet (prop tips above the wave tips). It appears to me that the 86R was declared a 'clay pigeon' when the LW found out Spits and Mosquitoes, appropriately modifed, could get up that high. Why the LW didn't use 'hot-rodded' photofighters is beyond me. Maybe they swallowed the 'XX' turned spies' reports as gospel. Walt BJ Yes, the success of agents like 'Garbo' in feeding duff stuff to the German High Command was remarkable. Without wanting to go wildly off-topic, there was a programme on UK TV a few nights ago ('Spitfire Ace') that had some very useful stuff on the mentality of the RAF versus the that of Luftwaffe in 1940. The RAF (through the vision and efforts of Dowding) had created a parless air defence system, while the Luftwaffe had concentrated overmuch on the lionisation of its individual pilots. Honestly this sounds like Brits patting themselves on the back while not looking at the strategic and tactical issues the Germans faced. (sadly this is a sort of anasthetic as the UK goes down a sewer) While I agree that we, as a nation, should be organising our lives better these days, there is no doubt that the British air defence system of 1940 was unmatched anywhere else in the world, and no-one, not even the Germans, dare to claim that Goering's boasts of 1940 held water. I think that by 1944 the Allies had developed a war machine that was thorough enough to filter out most flakey thinking and to concentrate on the real issues. If the Luftwaffe in 1944 was still relying on the whims of 'gifted individuals' (Hitler, Goering), who would have prided their own (uncriticised) judgement then a lot of bad ideas would have good through and a lot of good ideas would have been turned away. German thinking was predicated on the need to fight a short and sharp war as a nation sourunded by hostile countries. Avoiding a war of attrition was essential and avoiding a war on German territory was also essential. The surrounding countries were only hostile because of Hitler's belligerence - he could have been a peaceful leader had he so chosen. As for laying odds on a short war - having contingency plans in case your lightning strike does not work is fundamental to military planning. The nation was physically to small and to devoid of materials to handle a war in any other way and not loose thus substantial offensive capability was emphasised but it was all up front: resources were not devoted to reinforcements. This was the thinking even before the Nazis came to power. Germany had many resources to spare in the early years of the war. Their industry was still working single shifts until things got really bad. While Hitler was telling the German people about how well things were going, Churchill was telling the British that we had to get a wiggle on or lose - and our industry went to 100 percent from 1940 onwards. Much of the German work on Microwaves and Proximity fuses (which inspired British research) Um...they told us about their work in these fields? was suspended because the anything that could not be ready in 2 years would be a waste. Not a waste, a strategic error - no-one to blame but themselves. It seems that at this point that many of the German might have beens got caned. Examination of this period is perhaps where it might be said that Germany's technical may be said to lie. It migh also just lay in the fact that Germany lacked the resources to develop them. Poor prioritization - no-one to blame but themselves. The proximity fuse was a small printed circuit that any small group of radio men could have taken forward - there was no great industrial effort needed here. The Tiazard commision handed the proximity fuse and magnetron on a platter for the USA to develop. The Germans just culled. Good prioritisation on Tizard's part - hand the designs over to the people who can mass produce immediately. The excelent Freya and Wurzburg Radars were not integrated into a defensive system because the bomber naviagation aids were considered more important. Integration was a matter laying telephone connections and training a limited number of staff. If you have started a war, and it has gone pear-shaped, and your efforts have simply created a hostile world around you, air defence should then be recognised as a priority. After 1942 the allies were no longer fighting a war dictated by German initiatives - they were fighting according to their own. Cheers, Dave -- Dave Eadsforth |
"Tarver Engineering" wrote in message ...
"Gord Beaman" wrote in message ... (Hildegrin) wrote: Higher octane allows you to use higher boost pressures. It doesn't create more boost, it just allows you to "overboost" the engine at lower alts. Thus at rated alt and above, increased octane had no real effect (it may have reduced power by a tiny amount, because the fuel has a lower calorifc value, I think). Yes, this is exactly right...some think that the higher the Octane Rating the more "powerful" the fuel when actually high Octane fuel is less 'powerful' that low Octane fuel. You get the extra power because you can increase the Manifold Air Pressure (boost) without causing DETONATION. This is the whole reason behind high octane useage. Heavy detonation will trash an engine in short order so you must prevent it. Lead tetra ethyl is not short of energy, Gord. The amount of TEL added makes little difference to the energy content of a fuel becuase it is so small an amount. I don't even know how much energy it releases upon combustion if it does so at all. Ricardo, the great British engineer, developed the idea of using Tetra Ehyle Lead (TEL) because he reasoned that the milky color of gasoline was causing it to ignite due to to the transmision and absorbtion of infra red radiation rather than burn smoothly. TEL acted as a clarifying agent and this is how it increase the RON in a variable displacement test engine. That was the theory at least. Higher RON number do two things: First they eliminate pre-ignition due to hot surfaces or the high temperatures caused by compression. Second they prevent explosive combustion. Combustion should be a controlled burn at subsonic velocities along a wavefront caused by thermal conduction explosive combustion (not the technical term) means that the combustion becomes supersonic and is propagated by infra red radiation simultaneously in the mixture rather than smoothly along a wavefront. Water injection also results in higher engine power in a slightly different manner. No. Water injection only prevents the connecting rod bearings from being destroyed by detonation. Much the same as an EGR valve on automobile engines injecting exast gas into the manifold. Water injection does two things: 1 It lowers the temperature of the charge thus preventing preignition. 2 It increase the density of the air and thus allows more air into the combustion chambers and allows the supercharger to compress the same amount of air for less work. When engines are run rich the oversupply of fuel also cools the air in the same way. Side effect is loss of efficiency and flames and smoke from exhaust which your enemy can use to guage your intentions. |
spaceship one | Pianome | Home Built | 169 | June 30th 04 05:47 AM |
Yo! Fuel Tank! | Veeduber | Home Built | 15 | October 25th 03 02:57 AM |
Pumping fuel backwards through an electric fuel pump | Greg Reid | Home Built | 15 | October 7th 03 07:09 PM |
More long-range Spitfires and daylight Bomber Command raids, with added nationalistic abuse (was: #1 Jet of World War II) | The Revolution Will Not Be Televised | Military Aviation | 161 | September 25th 03 07:35 AM |
#1 Jet of World War II | Christopher | Military Aviation | 203 | September 1st 03 03:04 AM |
