Job well done
Old April 20th 08, 11:31 AM posted to rec.aviation.piloting
WingFlaps
Default Job well done
On Apr 20, 6:19*pm, wrote:
On Apr 18, 5:51 pm, WingFlaps wrote:
On Apr 19, 7:37 am, "tom418" wrote:
This is only an emergency because it looks good on TV. A gear up is
not a life threatening event.
It would have been even less of a risk and done a lot less less damage
to the plane if he had retracted the gear and stopped the engines and
done a belly landing
Cheers
Unless he had to go-around after feathering both engines.
Why would he want to go around after short final? Are you saying the
POH says land on on one wheel? Now apply some PIC skills. Which is
safer, a belly landing with engines off or the crash landing the pilot
made?
Cheers
Old April 20th 08, 11:33 AM posted to rec.aviation.piloting
WingFlaps
On Apr 20, 8:50*pm, Buttman wrote:
On Sat, 19 Apr 2008 23:19:37 -0700, momalley81 sayeth:
Sorry, I'll minimize the damage as best I can while following
manufacturer's approved procedures. *I'm betting nowhere in the 'ho's
AFM does it say to shut down and feather both engines on short final.
There are a million emergencies that can occur in a plane where there are
no procedures written about in the POH. There's nothing in the regs that
say you have to follow all "emergency procedures" in an emergency.
Handling an emergency isn't about just following what the book says.
They can't buy me a
new certificate when it gets yanked because I invented my own emergency
procedures.
Has this even ever happened before? Has there been an example of the FAA
going after someone who feathered the engines while doing a belly-up?
In fact they've been commended for their pilotage skills. Engines off
on short final is preferred for the fire risk.
Cheers
Old April 20th 08, 03:05 PM posted to rec.aviation.piloting
Bertie the Bunyip[_24_]
Buttman wrote in
manufacturer's approved procedures. I'm betting nowhere in the 'ho's
are no procedures written about in the POH. There's nothing in the
regs that say you have to follow all "emergency procedures" in an
emergency. Handling an emergency isn't about just following what the
book says.
They can't buy me a
emergency procedures.
FAA going after someone who feathered the engines while doing a
belly-up?
If it was me, I'd consider feathering them, but only if I thought it
could be done effectively. If it's a three-blade, or a turboprop of
any kind, I won't do it. If there's a chance of going around I
wouldn't do it either, but since I learned to land consistently (back
in my pre-private checkride days) I've had to go around, what, twice?
You are an idiot.
Bertie
Old April 20th 08, 04:00 PM posted to rec.aviation.piloting
WingFlaps
On Apr 21, 2:07*am, Bertie the Bunyip wrote:
WingFlaps wrote in news:3ba51b9f-6384-43cf-9f74-
is
damage
and
Cheers
made?
Actually, a partial gear landing is considered safer. I've made on ( not
by choice, one failed on touchdown) and damage was minimal. The airplane
was flying agian the next day.
S'funny you say that as I was reading some RAF stories from the war
and it seemed like gear up was the way to go. The touble with one
wheel down is what happens to the wing wen it catches on the ground
and starts a groundloop. It seems to me that accidental gear ups do
relativeley little damage to structure.
Cheers
Old April 20th 08, 04:17 PM posted to rec.aviation.piloting
WingFlaps wrote in news:cc5e0db0-3e13-42b8-8d46-
9f74-
up
is
damage
engines
and
Cheers
pilot
made?
not
airplane
Well, in my case it happened at high speed and we did eventually
groundloop, bt at low speed and with little damage. The left prop got
it, but the boss did a crank check and found it OK, so it flew the next
day. Cracked drag link was the culprit. For large aircraft, even those
without underslung engines, they do recommend that we take whatever is
down. I know a few guys who have landed completely wheels up and the
damage was pretty heavy. A Beech 99, for instance ( lots of those have
been wheels up)
Bertie
Old April 21st 08, 02:58 AM posted to rec.aviation.piloting
Maxwell[_2_]
Buttman wrote in
book says.
They can't buy me a
belly-up?
You are an idiot.
Bertie
Your a dumb ass.
Old April 21st 08, 02:59 AM posted to rec.aviation.piloting
Maxwell[_2_]
9f74-
up
is
damage
engines
and
Cheers
pilot
made?
not
airplane
been wheels up)
Bertie
Yeah, but you're just a liar.
Old April 21st 08, 03:19 AM posted to rec.aviation.piloting
WingFlaps
9f74-
up
is
damage
engines
and
Cheers
pilot
made?
not
airplane
been wheels up)
For the Gulfstream III landing with any two (2) gear legs down and
locked is preferred to landing
with only one gear down or all gear up. Should only one gear be
extended, it is recommended
that the gear be retracted and an all gear up landing be performed.
Landing with only
the nose gear down and locked is specifically not recommended.
Do you know why it would be different for heavies?
Cheers
