On Mon, 21 Apr 2008 14:31:15 -0500, Big John
wrote in : Didn't one or more of the America's Cup sail boats have something like this in one of the last sail off's? Is this it? http://www.newscientist.com/article/...fect-skin.html Researchers have known for years that fast-swimming sharks are covered with renewable scales, called dermal denticles, that have microscopic ridges. Just what these ridges did was a mystery until the 1980s when specialists in aerodynamics developed a way of smoothing turbulent flow using microscopic surface grooves that are aligned with the movement of fluid. These grooves are called riblets. "There are very close connections between riblets and shark skins," says Kwing-So Choi, a mechanical engineer at the University of Nottingham specialising in drag reduction. Riblets work by making turbulence more ordered near the surface. "They are like tiny fences that prevent the lateral movement of turbulence across the flow," says Choi. While any lateral movement is hindered, any flow that is parallel with the riblets continues unabated. "If you optimise the size and shape of the riblets, a drag reduction of up to 10 per cent is possible." Riblets have already been tested in real applications. Their biggest claim to fame was as a putative contributor to the sailing coup in 1987 when the US won the America's Cup, the prestigious yachting trophy. The American boat had a riblet coating on its hull, a development that was later banned by race officials. Other mariners have been slow to follow suit because riblets are easily clogged by microscopic marine debris. A more promising application is in aircraft, where fouling is less of a problem. Such riblets are already in use on some commercial airliners. It sounds different from the active skin in the more recent article. |
Larry Dighera wrote in
: On Mon, 21 Apr 2008 14:31:15 -0500, Big John wrote in : Didn't one or more of the America's Cup sail boats have something like this in one of the last sail off's? Is this it? http://www.newscientist.com/article/...-secrets-of-a- perfect -skin.html Researchers have known for years that fast-swimming sharks are covered with renewable scales, called dermal denticles, that have microscopic ridges. Just what these ridges did was a mystery until the 1980s when specialists in aerodynamics developed a way of smoothing turbulent flow using microscopic surface grooves that are aligned with the movement of fluid. These grooves are called riblets. "There are very close connections between riblets and shark skins," says Kwing-So Choi, a mechanical engineer at the University of Nottingham specialising in drag reduction. Riblets work by making turbulence more ordered near the surface. "They are like tiny fences that prevent the lateral movement of turbulence across the flow," says Choi. While any lateral movement is hindered, any flow that is parallel with the riblets continues unabated. "If you optimise the size and shape of the riblets, a drag reduction of up to 10 per cent is possible." Riblets have already been tested in real applications. Their biggest claim to fame was as a putative contributor to the sailing coup in 1987 when the US won the America's Cup, the prestigious yachting trophy. The American boat had a riblet coating on its hull, a development that was later banned by race officials. Other mariners have been slow to follow suit because riblets are easily clogged by microscopic marine debris. A more promising application is in aircraft, where fouling is less of a problem. Such riblets are already in use on some commercial airliners. It sounds different from the active skin in the more recent article. It is and it isn't. The riblets on shark skins are more closely related to vortex generators. Bertie |
Piper 235 tail skin | Ross | Owning | 26 | March 6th 08 06:53 PM |
Anyone else crawling out of their skin... | Jay Honeck | Owning | 39 | July 22nd 04 02:24 PM |
Anyone else crawling out of their skin... | Jay Honeck | Piloting | 39 | July 22nd 04 02:24 PM |
Skin Game | Veeduber | Home Built | 9 | February 5th 04 12:49 AM |
Drag - Anti/Drag Wires | log | Home Built | 3 | August 28th 03 07:06 AM |
