Flying Mag Clueless about LPV and NACO
Old May 1st 08, 08:01 PM posted to rec.aviation.ifr
Marco Leon[_5_]
Default Flying Mag Clueless about LPV and NACO
"Sam Spade" wrote in message
Last first: LPV IAPs are indeed precision IAPs.
And, let me add, my entire professional life has been with Jeppesen
charts.
But, I work with TERPS and the FAA a lot. NACO charts are the FAA's
method of charting IAP source. So, if they were wrong, they need to be
called on it. But, if is an issue of style, and Collins feels strongly
enough about it, he is welcome to attend the semi-annual FAA/Industry
Aeronautical Charting Forum, even submitting an issue paper in advance.
(His attendance has been mentioned to him before).
I've always wondered how much NACO would be able to copy Jeppesen (i.e. the
Briefing Strip) and not get sued for copyright infringement
At CRQ let's say I am flying the terminal routing from OCN. I would not
receive an LPV G/S on a Garmin 400/500W series navigator until crossing
KANAC at 3800. the LPV G/S would be a full fly-up because the G/S at
KANEC would be just over 5100. (So, there is no cross-check info for that
provided by either Jepp or NACO, nor should there be.) I can choose to
maintain 3800 until G/s intercept (just over 2 miles prior to JABEL, or
descend to 3100 to intercept at JABAL. Will the G/S be precisely 3100 at
JABEL? That depends on altimeter error, just like with an ILS.
If you'll be at 5,100 feet at KANEC, then (again in my opinion) the visual
depiction of a "glideslope" intersecting the waypoint at 3,800 feet is
misleading. I realize the G/S intersect at JABEL will be subject to
altimeter error which is why I made sure to qualify it with "or close to
it."
Marco
Old May 1st 08, 10:19 PM posted to rec.aviation.ifr
Sam Spade
The briefing strip came about as a result of a government study (Volpe,
DOT). So, that wasn't invented by Jeppesen.
it."
Marco
No, I said the G/S would be 5,100 at KANEC, but in my example coming
from the north the airplane was at 3,800, thus the intercept 4 miles
west of KANEC.
Old May 2nd 08, 03:25 PM posted to rec.aviation.ifr
Sam Spade
Airbus wrote:
In article , says...
Airbus wrote:
says...
John T wrote:
Oh, I did write them about it.
They erected a giant stone wall.
Maclellan says some readers took him to task for claiming that an LPV was flown
exactly like an ILS. He and Collins surmised that some of the confusion could
be attributed to charting ambiguities on NACO charts. This indeed seems to be a
pet peeve of theirs, as Collins goes into it in one of the Sporty's videos as
well, and uses the same DMW approach as an example, if I recall.
The gripe seems to be that the profile view in the NACO chart does not show a
stepdown, as the Jepp does, neatly intercepting the glideslope from below. In
purely graphical terms, they have a point. An architect would agree it's
misleading, and the continuous, sloping line on the NACO chart suggests a fixed
descent rate from the IF would have you magically intercept the glideslope at
the right place and altitude and even on the correct slope, which of course is
not true, and is not the way it's flown.
You argue this is a conventional depiction, unchanged from the way they have
always depicted ILS's and simply knowing the convention allows the pilot to fly
it correctly and intercept at the right altitude at the lightning bolt. You
certainly have a point as well, but if it were that clear and simple perhaps
there would have been fewer confused readers writing to Mac because they didn't
understand how to fly the approach.
We don't know what those readers wrote, but perhaps he has some reason to
believe their confusion stems in part from an imperfect charting convention,
which could stand some clarification.
Readers are often confused. It is the duty of the editors to have
sufficient knowledge to help their readers out. If the editors don't
possess sufficient knowledge in fundamental technical areas, such as the
case in point, then they should seek out expert advice, perhaps in this
case from both the flight procedures experts at the FAA and the charting
experts at NACO.
They apparently missed the point that the NACO altitudes with an
underscore govern in any segment other than a precision final approach
segment. They also apparently misunderstood the cartographic license
that Jeppesen used for the feather and that NACO uses in a more advisory
sense, and not at all on NACO LPV charts.
I also took the trouble to show them a Jepp and NACO charting of a
strictly non-precision RNAV IAP (first F70, then at "their" airport
DMW.). But, that seems to fly right over their collective heads. And,
they made no effort to be fair or make rebuttals, observations, and
perhaps (yegads!) ask some reasonable questions.
As you can see, as a paid subcriber I tried to help, but only revceived
rude treatment at their hands.
The NACO sloping line is cartographic license. They have done it this
way for years. It does not govern. The segment underscored altitudes
govern. Look at the NACO chart for the ILS 25L at LAX for an example of
an extended ILS profile.
Unlike Jeppesen, who mostly sets its own standards, NACO is governed as
to charting specs by an inter-government panel (FAA and military "IACC")
who established government charting specifications to the nth degree.
These guys aren't a bunch of numbskulls so they presumably had their
good reasons for going with the sloping but *advisory* provfile line
many years ago.
Flying Magazine, just like other aviation user groups, has the
semi-annual FAA/Idustry Aeronautical Charting Forum available to air its
technical concerns about instrument procedures and all forms of
charting. I recommened that to Collins as a venue open to him several
years ago when he ignorantly and incorrectly critized FAA procedure
design. But, that went unanswered and unheeded.
As a reader, I find their ignorance in this area understandable,
although it brings into question their editorial standards. But, as to
their unwillingness to listen or seek expert advice, I do not have much
understanding of that.
Old May 2nd 08, 03:35 PM posted to rec.aviation.ifr
Airbus[_4_]
Airbus wrote:
says...
Old May 3rd 08, 12:25 AM posted to rec.aviation.ifr
Valued Corporate #120,345 Employee (B A R R Y)
It always seemed pretty obvious to me based on the crossing altitudes,
but again, I don't have much experience with Jepp charts.
When one section of the continuously sloping line descends 200-400
feet, and the other (after the lightning bolt) goes from say, 2200 to
400 AGL, it's obviously not to scale.
Kind of like the 10 MN ring...
Old May 3rd 08, 12:34 AM posted to rec.aviation.ifr
On Fri, 02 May 2008 07:25:22 -0700, Sam Spade
segment.
Right. The underscore should _always_ grab a pilot's attention.
I don't think they even bothered to try to understand your point.
Just as it does where course reversals are depicted. I've never seen
a course reversal depicted where the slope made sense, so I always
read it as Cross "X" @ NNNN, descend to NNNN and cross "Y", then
descend to NNNN to cross "Z". I never assume the slope to mean
anything other than "descend", as opposed to "level" as depicted for
holds and some procedure turns.
I don't see why the "FLYING" folks were so confused.
Old May 16th 08, 06:26 PM posted to rec.aviation.ifr
Greg Esres[_2_]
The AIM refers to them as APV approaches, approaches with vertical
guidance. For alternate purposes, they're to be considered non-
precision.
Old May 20th 08, 01:58 PM posted to rec.aviation.ifr
Sam Spade
precision.
First, the term APV is applied to any FAA approach with vertical
guidance that does not meet the precision approach requirements of ICAO
Annex 10. The FAA does not agree with Annex 10 because the FAA
considers LPV IAPs to be precision IAPs and, in fact, use ILS obstacle
clearance containment areas for obstacle protection.
An LDA with a G/S is also an APV because it clearly does not meet any
definition of a precision IAP.
As to the alternate requirements, your statement is incomplete. You
cannot plan to use the precision line of minimums on a WAAS IAP for
alternate planning purposes. But, if WAAS LPV is available when
arriving at the alternate you may use the LPV *precision* line of minima.
Old May 23rd 08, 06:46 PM posted to rec.aviation.ifr
Greg Esres[_2_]
Sam Spade wrote:
FAA considers LPV IAPs to be precision IAP
The FAA that writes the AIM says differently:
1-1-20.
A new type of APV approach procedure, in addition to LNAV/VNAV, is
being implemented to take advantage of the lateral precision provided
by WAAS. This angular lateral precision, combined with an electronic
glidepath allows the use of TERPS approach criteria very similar to
that used for present precision approaches, with adjustments for the
larger vertical containment limit. The resulting approach procedure
minima, titled LPV (localizer performance
with vertical guidance)...
But, if WAAS LPV is available when arriving at the alternate you may
Yes, that's obvious, but it still underlines that the FAA doesn't not
consider the LPV approach to be a precision approach as far as the
user is concerned.
Old May 23rd 08, 11:16 PM posted to rec.aviation.ifr
Sam Spade
1-1-20.
user is concerned.
The FAA is covering its butt with ICAO. Technically, there are now
three types of IAPs.
1. Precision
2. APV
3. Non-precision
1 and 2 are flown identically when the APV is an RNAV IAP with LPV or
VNAV minimums. They both have DAs.
If it walks like a duck and quacks like a duck.....
When you fly an LPV (or teach it) do you teach precision or
non-precision procedures and flap settings, etc, for the final approach
segment?
NACO Plates/How do you hold them? Mitty Instrument Flight Rules 14 November 4th 07 02:37 PM
NACO charts Michael Ware Piloting 13 December 1st 05 10:10 PM
NACO charts Michael Ware Owning 12 December 1st 05 10:10 PM
NACO charts Michael Ware Instrument Flight Rules 12 December 1st 05 10:10 PM
Jep p or NACO Charts? Judah Instrument Flight Rules 66 December 9th 04 03:34 AM
