Isn't lift part of drag?
Old April 25th 08, 08:58 PM posted to rec.aviation.piloting
Maxwell[_2_]
Default Isn't lift part of drag?
"Dudley Henriques" wrote in message
news
es330td wrote:
Fortune magazine online has a photo essay about their new 787. On one
page,
http://money.cnn.com/galleries/2008/...ortune/16.html,
they make this statement:
The Dreamliner's wingspan is 197 feet, or about 25% longer than a
similar-sized plane, which increases lift and reduces drag.
I thought that lift, in addition to causing a net upward force on the
wing, also contributes to the drag force on the wing as well. If this
is the case then increasing lift should also increase drag. Did I
misunderstand?
The lift and drag curves for any given wing are a function of wing design.
Although induced drag is a product of lift creation, the design of the
wing could easily change the lift and drag coefficients and make the wing
more efficient.
These are complicated inter-relationships, and sometimes, when doing an
article in a non technical venue, a writer will simply present the tip of
the iceberg.
This isn't necessarily wrong but you will probably notice a distinct
difference between an article on wing design written for Fortune as
opposed to one written for Aviation Weekly :-)
Dudley Henriques
I think you can say more and explain less than anyone I have ever heard.
Do you think the value of any writing can be most accurately expressed by
it's printed weight in pounds?
Old April 25th 08, 09:06 PM posted to rec.aviation.piloting
WingFlaps
news
es330td wrote:
Fortune magazine online has a photo essay about their new 787. *On one
page,
http://money.cnn.com/galleries/2008/...y.boeing_dream...,
is the case then increasing lift should also increase drag. *Did I
misunderstand?
Old April 25th 08, 09:47 PM posted to rec.aviation.piloting
Bertie the Bunyip[_24_]
WingFlaps wrote in
news
on
e
page,
http://money.cnn.com/galleries/2008/...ry.boeing_drea
m...
the wing, also contributes to the drag force on the wing as well.
If this is the case then increasing lift should also increase
drag. *Did I misunderstand?
desig
n.
the wing could easily change the lift and drag coefficients and
make the win
g
more efficient.
doing an article in a non technical venue, a writer will simply
present the tip o
f
the iceberg.
distinct difference between an article on wing design written for
Fortune as opposed to one written for Aviation Weekly :-)
Dudley Henriques
heard.
expressed by it's printed weight in pounds?- Hide quoted text -
Do you think you are achieving anything more than exposing yourself as
a rather tedious loser?
He does, actually. And nothing you can say to him will convince him
otherwise. It's the very essence of what it is to be a k00k.
Bertie
Old April 25th 08, 09:57 PM posted to rec.aviation.piloting
Maxwell[_2_]
"WingFlaps" wrote in message
news
page,
misunderstand?
design.
wing
more efficient.
of
the iceberg.
Dudley Henriques
a rather tedious loser? Give it up man.
Cheers
No ****!!!!! What did I loose??
Old April 25th 08, 09:58 PM posted to rec.aviation.piloting,alt.usenet.kooks,alt.alien.vampire.flonk.flonk.flonk
Bertie the Bunyip[_25_]
"Maxwell" luv2^fly99@cox.^net wrote in
news
news:9aeabecd-d09c-46f0-9a11-7d1e15c45ff2
@l28g2000prd.googlegroups.com.
news
one page,
m...,
drag. Did I misunderstand?
design.
make the wing
more efficient.
present the tip of
the iceberg.
Dudley Henriques
heard.
Cheers
Marbles would be my guess.
Bertie
Old April 25th 08, 09:45 PM posted to rec.aviation.piloting
news
one page,
liner.fortune/16.html, they make this statement:
the wing, also contributes to the drag force on the wing as well. If
this is the case then increasing lift should also increase drag.
design. Although induced drag is a product of lift creation, the
design of the wing could easily change the lift and drag coefficients
and make the wing more efficient.
an article in a non technical venue, a writer will simply present the
tip of the iceberg.
Dudley Henriques
heard.
That's just because you're too dim to undestand the instructions on how
to open up your pop tarts.
Bertie
Old April 26th 08, 04:06 AM posted to rec.aviation.piloting
clint
listen to dudley dooright he is a senior
Dudley Henriques formulated the question :
Although induced drag is a product of lift creation, the design of the wing
could easily change the lift and drag coefficients and make the wing more
efficient.
article in a non technical venue, a writer will simply present the tip of the
iceberg.
difference between an article on wing design written for Fortune as opposed
Old April 25th 08, 05:55 PM posted to rec.aviation.piloting
Robert M. Gary
page,http://money.cnn.com/galleries/2008/...y.boeing_dream....,
misunderstand?
It could be more efficient. The Mooney wing produces more lift for the
amount of drag than a Cessna wing.
-Robert
Old April 25th 08, 06:50 PM posted to rec.aviation.piloting
On Apr 25, 10:55 am, "Robert M. Gary" wrote:
page,http://money.cnn.com/galleries/2008/...y.boeing_dream...,
misunderstand?
-Robert
From the original statement, it seems clear that they're
referring to the increase in efficiency that come from aspect ratio. I
wonder, now, if that increased span was made possible with the use of
composites instead of aluminum? Longer wings flex more, and aluminum
fatigues faster, I think, than composite construction. And carbon or
aramid fibers are stronger per unit weight than aluminum.
Dan
Old April 25th 08, 08:47 PM posted to rec.aviation.piloting
Peter Dohm
misunderstand?
-Robert
Dan
There are a lot of trade offs, and the gate spacing might also be larger at
the airports that the Dreamliner is expected to serve. Also, IIRC, a few
years ago, Boeing talking about future aircraft with folding wing tips to
overcome some of the spacing problems at the gates. I also agree with you,
that advances in materials also play a major role.
Peter
wide wingspan and good lift to drag ratios Tony Piloting 6 March 13th 06 01:19 AM
8 Percent More Lift and 32 Percent Less Drag Larry Dighera Piloting 9 September 7th 05 12:02 AM
about lift and drag coefficient for cessna C-160 Grandss Piloting 9 August 15th 05 06:15 PM
Lift-to-Drag Ratio? Toks Desalu Home Built 6 November 23rd 03 10:53 PM
Drag - Anti/Drag Wires log Home Built 3 August 28th 03 07:06 AM
