Been chatting with a few old time geek friends online it looks like we are
going to start an embedded Linux project for this hardware while keeping it capable of running current nav data/maps my unit just booted an 8 gig CF card (Avmap SW) a friend is going to try a 32 gig card in the next week or so on his. Looks like this hardware will make a great open source platform. Unit Booted SanDisk ConnectPlus With Wifi 2 bad they are not larger in capacity... Would be Great Wifi Addition. Unit Booted 8 gig CF Card Unit Booted 2 Gig SD With CF Type 1 Adapter Unit Booted 1 Gig micro SD With CF Type 1 Adapter Unit Did Not Boot With CFII Micro Drive..... Unit Did not Boot With 2 Gig SD With CF Type 2 Adapter I Will test Other Forms and sizes of flash memory when I can get my hands on them. If any one Know of any sources of low power Wifi CF cards with 4gb or larger capacity please let me know. Also if your looking for Interface Cables look Here Only $3.00 Pluss they have right Angle Plugs Pre Wired Add a DB9 Connector There You Go Connect to PC. http://www.minute-man.com/acatalog/4...mm_Cables.html See what happens when I take time off get bord and start playing..... Laters |
![]() "NW_Pilot" wrote in message . .. Been chatting with a few old time geek friends online it looks like we are going to start an embedded Linux project for this hardware while keeping it capable of running current nav data/maps my unit just booted an 8 gig CF card (Avmap SW) a friend is going to try a 32 gig card in the next week or so on his. Looks like this hardware will make a great open source platform. Unit Booted SanDisk ConnectPlus With Wifi 2 bad they are not larger in capacity... Would be Great Wifi Addition. Unit Booted 8 gig CF Card Unit Booted 2 Gig SD With CF Type 1 Adapter Unit Booted 1 Gig micro SD With CF Type 1 Adapter Unit Did Not Boot With CFII Micro Drive..... Unit Did not Boot With 2 Gig SD With CF Type 2 Adapter I Will test Other Forms and sizes of flash memory when I can get my hands on them. If any one Know of any sources of low power Wifi CF cards with 4gb or larger capacity please let me know. Also if your looking for Interface Cables look Here Only $3.00 Pluss they have right Angle Plugs Pre Wired Add a DB9 Connector There You Go Connect to PC. http://www.minute-man.com/acatalog/4...mm_Cables.html See what happens when I take time off get bord and start playing..... Laters Finding all sorts of cool things about this Hardware! |
On Sun, 27 Apr 2008 20:41:28 -0700, "NW_Pilot"
wrote in : Been chatting with a few old time geek friends online it looks like we are going to start an embedded Linux project for this hardware while keeping it capable of running current nav data/maps What sort of Linux applications are you considering for the Avmap EKP-IV? |
![]() "Larry Dighera" wrote in message news ![]() On Sun, 27 Apr 2008 20:41:28 -0700, "NW_Pilot" wrote in : Been chatting with a few old time geek friends online it looks like we are going to start an embedded Linux project for this hardware while keeping it capable of running current nav data/maps What sort of Linux applications are you considering for the Avmap EKP-IV? It's a Samsung Arm9 @ 226+ MHz there are many devices running Linux on this platform. Update: Friend who has had one for a few years cracked his Open Today Numbers On the CPU Chip Are S3C2410 Translates To ARM920T RISC CPU kernel with max. 266 MHz clock... Waiting on a newer unit to be opened to see whats inside. Info On CPU http://www.samsung.com/global/busine...artnum=S3C2410 Playing with cards it only supports 3.3 V flash will not support any 5V flash cards... or adapters... Waiting on a newer unit with a cracked/busted display to arrive for Disassembly and parts search and Possible Jtag connection Location unless can be Loaded/Downloaded Via onboard USB. |
![]() What sort of Linux applications are you considering for the Avmap EKP-IV? |
Larry,
What sort of Linux applications are you considering for the Avmap EKP-IV? I like your style ;-) -- Thomas Borchert (EDDH) |
Full E6B Calculator, Web Browser, Wi-Fi, Small Six Pack Display, Config
Files, Keyboard, Each CF Card contains a "CF-ID". Your GPS Software reads that CF-ID and compares this to a file on the card CMAP2.CER A mismatch blocks the maps from loading. You can read the CF-ID through the About Page. Now all we need to do is figure out the CMAP2.CER File So we can make our files for cards to load our maps. Garmin has a similar type of file protection system to prevent their maps from loading. There is a Key Gen Called jetmouse keygen that creates a Garmin check file for the SD/MMC ID format they use. As soon as we can get the maps to load on another card, we will know what will be required to include in the linux kernel for running their map data and be able to grab updates when needed etc. I have some Sketched some potentiol GUI's. "Larry Dighera" wrote in message ... What sort of Linux applications are you considering for the Avmap EKP-IV? |
Avmap EKP-IV XM weather and club avmap | [email protected] | Piloting | 1 | November 16th 07 12:29 AM |
EW model D and Linux | Martin Gregorie | Soaring | 1 | December 1st 06 04:55 PM |
Anybody else use C-MAP cards in their GPS? here's what came offmy AVMAP EKP IV avmap.zip (000/182) | George Patterson | Piloting | 10 | January 17th 06 03:21 PM |
Anybody else use C-MAP cards in their GPS? here's what came off my AVMAP EKP IV avmap.zip (000/182) | Grumman-581 | Piloting | 0 | January 15th 06 09:54 PM |
Anybody else use C-MAP cards in their GPS? here's what came off my AVMAP EKP IV avmap.zip (000/182) | Steven P. McNicoll | Piloting | 0 | January 15th 06 09:43 PM |
