When do you use boost pumps?
Old May 10th 08, 12:16 AM posted to rec.aviation.piloting
Ron Natalie
Default When do you use boost pumps?
Mxsmanic wrote:
When do you use boost pumps on small GA aircraft?
I know you wear your 6" pumps when you're out trolling
for tricks on the champs elysee.
Old May 10th 08, 01:18 AM posted to rec.aviation.piloting
Benjamin Dover
Mxsmanic wrote in
Whenever you need to get up from your seat.
Old May 10th 08, 01:58 AM posted to rec.aviation.piloting
Dave Doe
says...
Need to specify the aircraft.
Duncan
Old May 10th 08, 01:59 AM posted to rec.aviation.piloting
Dave Doe
says...
for eg. a Traumahawk (IIRC) is during landing and takeoff, and
emergency, ie FLWOP procedure).
Duncan
Old May 10th 08, 03:28 AM posted to rec.aviation.piloting
Aluckyguess
When Viagra quits working
Old May 10th 08, 05:13 AM posted to rec.aviation.piloting
BT
when the POH or Check list says too
BT
"Mxsmanic" wrote in message
Old May 10th 08, 04:44 PM posted to rec.aviation.piloting
Darkwing
I'll tell you for only $19.95, if you act now!
Old May 10th 08, 04:45 PM posted to rec.aviation.piloting
Bertie the Bunyip[_24_]
"Darkwing" theducksmail"AT"yahoo.com wrote in
I'll tell him for only 14.95, and I'll throw a set of steak knives at him!
er, in!
Bertie
Old May 11th 08, 12:20 AM posted to rec.aviation.piloting
Maxwell[_2_]
You couldn't stop if your life depended on it, could you Squirty ****drip?
Squirt, squirt.
Boost control for turbonormalizing. [email protected] Home Built 3 October 12th 06 04:06 AM
Soundwaves Boost Wing Lift [email protected] Home Built 30 September 5th 05 10:21 PM
how to boost vhf scanner NW_PILOT Piloting 5 January 9th 05 10:27 AM
Weldon boost pump keepitrunning Home Built 2 January 6th 05 07:52 PM
Boost phase interceptor. . . Scott Ferrin Military Aviation 4 December 5th 03 10:36 AM
