Mylar seals for elevator
Old May 20th 08, 03:41 PM posted to rec.aviation.soaring
Andreas Maurer
Default Mylar seals for elevator
On Sun, 18 May 2008 13:45:39 -0700 (PDT), JJ Sinclair
We have had a bail-out caused by lifting mylar
on the stab.
JJ
Hi John,
what happened?
Bye
Andreas
Old May 20th 08, 08:14 PM posted to rec.aviation.soaring
JJ Sinclair
on the stab.
JJ
Hi John,
what happened?
Bye
Andreas
If memory serves me (big assumption at 74) this intrepid aviator waxed
his ship and then changed the safety tape....................it lifted
but didn't come off and caused such a flow change over the elevator
that he (intrepid aviator) didn't feel he had adequate control to try
and land the bird (Ventus B). Soooooooo, he tidied up the cockpit and
stepped smartley over the side!
JJ
Old May 20th 08, 09:53 PM posted to rec.aviation.soaring
on the stab.
JJ
Hi John,
what happened?
Bye
Andreas
JJ
There's a thread on this with accounts from folks who attended that
event. Here's a quote from John Cochrane based on the report at the
pilot's meeting after the accident occurred:
"I too was at Uvalde. The explanation for the Ventus crash given at
the pilot's
meeting was that there was NO thin tape holding down the mylar -- only
the mylar
itself, held down with double sided tape. It started to separate at
the leading
edge of the mylar, resulting in progressively worse elevator control.
Everyone
went out immediately to check that their thin tape was sticking well
in the
Uvalde heat! "
Sounds like the combination of the heat and the lack of any safety
tape was not a good one.
Old May 21st 08, 05:09 PM posted to rec.aviation.soaring
Bob Whelan[_2_]
on the stab.
JJ
Hi John,
what happened?
Bye
Andreas
JJ
Kinda-sorta related, mebbe 10 years ago, the owner of a DG-300 launched
from our club's site (municipal airport). I wasn't there, what follows
is hearsay...but some lessons probably lie within...
First tow was aborted due to the need to hold nearly full aft stick to
maintain tow position. On-ground diagnosis followed - no problem found.
Second tow, same problem, safe landing again ensued, further
diagnosis, considerable loose tape at leading edge of elevator's
upper-surface mylar installation found (installation details
unknown-to-me), situation dealt with in some unknown manner, subsequent
flight not problematic.
Lessons?
- sometimes it's best to assume that little voice in your head is right
- inadvertent spoilers always have some effects
- if it ain't fixed, don't broke it
Regards,
Bob - some hearsay probably contains grains of Real Truths - W.
Old May 21st 08, 08:09 PM posted to rec.aviation.soaring
Darryl Ramm
on the stab.
JJ
Hi John,
what happened?
Bye
Andreas
JJ
Hi JJ
Is it true that the ship later floated back, falling leaf style, by
itself to earth with some significant damage but was later repaired?
Darryl
Old May 21st 08, 09:10 PM posted to rec.aviation.soaring
JJ Sinclair
Darryl
Yes, I believe that Venti did fly again, but I didn't put it back
together!
I did put an LS-3 back in the air after a bail-out, but it flew with
other wings that came from a wind-shear accident in Texas.
Most abandoned ships will come down in a falling leaf-type maneuver
due the the extreme aft CG that resuls from the pilots premature
departure. The ship's flying at EWCG, usually about 22", rather than
about 10".
JJ
Old May 22nd 08, 02:00 AM posted to rec.aviation.soaring
Rick Walters
Darryl,
The ship was a Ventus A and the bail out occured while flying out of
Uvalde.
The glider received very little damage. Apparently the gear was down and
the gear "cage" took most of the impact. I owned it for a while but it
has
been passed on to someone else. It has not flown since the accident.
Ron Tabery had a similar problem in NZ flying his N3. He landed OK but
with very marginal elevator control. A good item to put on a checklist.
Rick Walters
Hi JJ
Darryl
Rick Walters
Darryl,
Uvalde.
has
Rick Walters
Hi JJ
Darryl
Rick Walters
Darryl,
Uvalde.
has
Rick Walters
Hi JJ
Darryl
Rick Walters
Darryl,
Uvalde.
has
Rick Walters
Hi JJ
Darryl
Mylar seals for PIK20D culverflyer Soaring 5 May 19th 04 06:25 PM
Mylar seals installation John W Soaring 2 May 5th 04 09:03 PM
mylar seals wing to flap/ Aileron culverflyer Soaring 2 May 5th 04 02:52 PM
ZZ Mylar seals Mike Soaring 3 March 29th 04 03:45 PM
mylar seals D.A.L Soaring 1 February 23rd 04 07:15 PM
