antenna dilemma
Old May 26th 08, 10:44 PM posted to rec.aviation.soaring
Ged McKnight[_2_]
Default antenna dilemma
SHOUT LOUDER
At 19:23 26 May 2008, Bill Daniels wrote:
"Ralph Jones" wrote in message
On Sun, 25 May 2008 17:57:22 -0700 (PDT), Brad
My buddies tell me my handheld is too painfull to listen to anymore. I
would put in a panel mount, but since I have a mostly carbon aircraft,
where should I put the antenna? Too late to install it in the rudder,
or is there a solution that would allow me to install one in the
rudder??
I think the main issue with the handheld, is line-of-sight from the
antenna to who I am talking to, it works fine when the aircraft is
pointing towards them, or they are on the side of the glider the radio
is on, but as I turn (while thermalling) I am told the transmissions
cut out.
I've seen a few ships that had a small whip antenna mounted on the
gear door. With the gear down, of course, the antenna was horizontal,
and if mounted close to the hinge line, it was high enough not to get
ground damage on most fields.
But that won't work if you trailer your ship with the gear up...
rj
Hmm, well, if you mounted a BNC thru-bulkhead connector on the gear door,
and the antenna had a mating BNC connector, it could br removed for
trailering. That said, antenna wires have a LOT of drag so maybe a
rubber
duckie....
Bill D
Aviation Dilemma 101 - How much trust in a 10 day forecast?? Kyle Boatright Piloting 25 July 22nd 06 12:52 PM
More on Fuel Management - and an Ethical Dilemma Greg Farris Instrument Flight Rules 46 July 22nd 05 06:38 PM
More on Fuel Management - and an Ethical Dilemma Greg Farris Piloting 47 July 22nd 05 06:38 PM
Briefing Dilemma Kyle Boatright Piloting 15 February 7th 05 07:10 PM
Small dilemma...YES, this is true.... Halen19717 Piloting 12 December 2nd 04 01:12 PM
