Air sickness
Old May 26th 08, 03:04 PM posted to rec.aviation.piloting
Stealth Pilot[_2_]
Default Air sickness
On Mon, 26 May 2008 14:52:50 +0200, Mxsmanic
Amine writes:
Does motion sickness fade away with experience?
Motion sickness caused by a specific situation tends to fade when that
situation is regularly and frequently experienced. It may still occur in
other situations, and the resistance to motion sickness even in the target
situation will fade if the situation is not encountered fairly frequently.
what *causes* motion sickness oh wise one?
Old May 26th 08, 09:00 PM posted to rec.aviation.piloting
muff528
"Stealth Pilot" wrote in message
Amine writes:
Me! Me! ....call on me! I've got my hand up!
My guess, just off the top of my head, would be ........... motion!
But it's probably more complicated than that.......prolly some math or
something involved. :-)
TP
Old May 27th 08, 03:18 PM posted to rec.aviation.piloting
Stealth Pilot[_2_]
On Mon, 26 May 2008 20:00:49 GMT, "muff528"
Amine writes:
TP
as far as I am aware the current medical thinking is that the symptoms
of (food) poisoning cause a difference between the somatogravic system
(balance in the inner ears) and the positional appreciation in the
mind from visual cues. we have evolved so that when this occurs we
heave up the stomach contents to remove from the body the source of
the poisoning.
unfortunately gyrations in an aircraft can cause differences between
the visual appreciation of position and the messages our inner ears
are giving us and this triggers the same primitive reflex.
the upside of all this is that the typical 2 litre ice cream container
holds a little more than the vomit volume and has a sealable lid.
carry one in your aircraft :-)
see MX, you didnt have a clue.
Stealth Pilot
Old May 27th 08, 09:10 PM posted to rec.aviation.piloting
Capt. Geoffrey Thorpe
Oh, yea, I forgot to mention. DO NOT stick your head out the window if you
are going to ralph. That is a real bad idea. A hat, chart, or even the floor
are better places than out the window.
Geoff
Old May 27th 08, 01:20 AM posted to rec.aviation.piloting
Mxsmanic
Stealth Pilot writes:
The exact mechanism is still unclear, especially for motion sickness induced
by stimuli other than motion, such as moving pictures.
Old May 27th 08, 01:38 AM posted to rec.aviation.piloting
Viperdoc
induced
The exact mechanism is unclear to you, Anthony, because you don't know what
you're talking about, as usual.
Old May 27th 08, 08:34 PM posted to rec.aviation.piloting
Mxsmanic
Viperdoc writes:
The exact mechanism is unclear to everyone.
However, if the mechanism is clear to you, why don't you explain it? That
would be far more productive than trying to discredit me.
Old May 26th 08, 03:44 PM posted to rec.aviation.piloting
Bertie the Bunyip[_24_]
Mxsmanic wrote in
Amine writes:
in other situations, and the resistance to motion sickness even in the
target situation will fade if the situation is not encountered fairly
frequently.
Oh god he's back to medicine again.
Bertie
Old May 26th 08, 02:55 PM posted to rec.aviation.piloting
R. Gardner
Yes it will fade possibbly and as mentioned the control of the airplane will
help.
Don't eat heavy before flying, keep cool air on you. Don't look at the
ground below you! The fast motion your eye see confusses the brain because
it senses that you are not realy moving. Look at a distant horizon to help
ease the on set of motion sickness. That helps the brain think that what it
sees is what it also senses with motion.
"Amine" wrote in message
Does motion sickness fade away with experience? How many of you
seasoned pilots had/still have serious issues with recurrent nausea?
(Assuming of course an otherwise good health.)
Old May 26th 08, 03:15 PM posted to rec.aviation.piloting
Frank Olson
"Yes it will fade possibly"? Isn't that like a double negative?? :-)
help.
Actually, my wife get's sick driving in the car on the *way* to the
airport. I think it's the "anticipation". :-)
anybody benefit once, mean therefore, then compensate since the sickness above the sentence Franklin Piloting 0 August 14th 07 01:34 AM
XC Sickness [email protected] Soaring 17 July 13th 07 05:45 AM
Anything new in to combat motion sickness? Gary Emerson Soaring 35 February 6th 07 04:38 PM
Gulf Sickness Redux? DunxC Military Aviation 0 September 18th 03 06:36 AM
