Experimental FAA registration
Old June 12th 08, 05:18 PM posted to rec.aviation.soaring
jb92563
Default Experimental FAA registration
On Jun 11, 2:37*pm, wrote:
Andrew,
Regarding specifically Experimental Exhibition and Racing certificated
gliders that were certificated after July 19, 1993;
Take a look at The Order 8130.2F, CHG 3, Paragraph 161. subparagraph
(37) (page 178) regarding the annual program letter requirement. Looks
to me like if you just do proficiency flying all summer and don't go
to a "sanctioned meet", you might be OK with your original letter. Of
course, per subparagraph (34) that pro flying takes place within a 300
mile radius of your home base airport. Subparagraph (35) is also
interesting reading, but in any case, all the paragraphs have to be
read together in detail ad nauseum to make any sense *- and then we
realize we are reading FAA guidance, so making sense may not be the
preferred task outcome.
Don't forget your copy of the "highlighted aeronautical chart" that
you carry with you aboard the aircraft per 161.(37).
While paragraph 132 may appear to be in conflict with the above -
we'll just go with the guidance specific to Exhibition and Racing
certificates, and even more specific to Group 1: Performance
Competition Aircraft, which iswhat the racing glider is defines as by
the FAA..
Paragraph 155.(c) (page 166) states that when the aircraft's base of
operation is changed or a change in ownership occurs, the owner must
notify the local FSDO and provide a copy of the inspection program (if
applicable, not likely for a glider, unless it's a turbine powered
glider) and a copy of the requested proficiency flight area.
Call your local FSDO for guidance specific to their area of operation.
Some FSDO's and aircraft Ops Limitations differ because The Order
allows it, see Paragraph 161, suparagraph a. (page 172) where it
states "The FAA Inspector may impose any additional limitations deemed
necessary in the interest of safety."
I'm speculating that if you do have a crash and the FAA determines
that you are out of compliance on your LOA and hence your
certificate of airworthiness that your insurance company may NOT cover
your claims?
That would be the most compeling reason to make sure you have the
proper LOA filed with the FAA.
Old June 12th 08, 05:33 PM posted to rec.aviation.soaring
I don't know anything about what insurance companies will do, but if
you have an accident and the FAA determines you were not operating in
accordance with your operating limitations, then you may have problems
with the FAA.
your claims?
proper LOA filed with the FAA.- Hide quoted text -
- Show quoted text -
Old June 13th 08, 04:58 AM posted to rec.aviation.soaring
Andrew Wood[_2_]
At 16:18 12 June 2008, jb92563 wrote:
On Jun 11, 2:37=A0pm, wrote:
Andrew,
Of
read together in detail ad nauseum to make any sense =A0- and then we
the FAA..
deemed
your claims?
hello Jim thanks for pointing out 161.37 in that Order to me. I confess
that I had not read the entire Order. Personally I'd say the operative
word is 'update' rather than 'annual'. Ie if there is no update, no
annual letter is required. I intentionally made my own letter very broad,
with the plan that futher updates would not be needed, per para 35. I also
included the words 'If you have questions, or need any further
information, please let me know' to put the onus for updates back on the
FAA. I heard nothing back, so I would argue that they accepted that. The
real fact is that no one read my letter. But that is ok. I know the people
in my local FSDO, and they are helpful and supportive with things that
genuinely matter, and I try to be the same, and don't plan to send them
unnecessary letters. If the SSA had any competence and use, they would
maybe provide help with stuff like this, like a form letter we could use,
instead of soaking up our money on a trash magazine and selling us
'merchandise'. Regards, andrew
andrew
Old June 13th 08, 05:09 AM posted to rec.aviation.soaring
Yes, Andrew, I agree with all of that. Some FSDO's want more than
others and some read the letters, others have much bigger fish to fry.
All depends on where you're at; or where they're at in the scheme of
things. Problems come when there is a problem, then everything gets
read and analyzed. Best to avoid problems in my opinion.
Jim.
Old June 13th 08, 05:24 AM posted to rec.aviation.soaring
Frank Whiteley
Andrew,
Of
the FAA..
deemed
your claims?
andrew
The SSA is a voluntary, non-profit organization. Though the solution
may seem simple, implementation may not be that easy. That said,
there are a number of volunteer committees, one of which addresses the
types of concerns you raise. I invite you to join one and bring your
competence and help develop the resources you wish the SSA to provide.
http://www.ssa.org/members/governance/volunteers.asp
Frank Whiteley
Old June 14th 08, 12:20 AM posted to rec.aviation.soaring
Frank Whiteley
Andrew,
Of
the FAA..
deemed
your claims?
andrew
http://www.ssa.org/myhome.asp?mbr=86...chive=4/1/2002
What you're looking has been on the SSA web site since 2002. But
check with your FSDO.
Frank
Old June 14th 08, 04:13 AM posted to rec.aviation.soaring
Andrew Wood[_2_]
Andrew,
certificated
subparagraph
Looks
go
letter.
Of
300
we
that
by
the FAA..
of
must
(if
operation.
deemed
cover
your claims?
confess
operative
no
broad,
also
The
people
them
use,
andrew
Frank
hello Frank
thanks for pointing the above SSA webpage out to me. It's useful and does
cover the question that has been discussed in this thread. I had not
discovered that page before. I had a hard time finding it without your
link. I'd guess that not many people have found it.
andrew
De-registration [email protected] Soaring 11 August 24th 07 06:09 AM
OLC Registration [email protected] Soaring 7 April 17th 07 04:10 PM
Registration question Michael Horowitz Owning 7 January 25th 06 03:50 PM
Canadian registration to US? CFLav8r Owning 7 March 15th 04 03:35 AM
Aircraft registration ??? Ludlow Johnson Piloting 13 November 12th 03 06:53 PM
