Boeing Reveals Sub-Tracking ScanEagle Study
Old June 29th 08, 08:01 PM posted to sci.military.naval,rec.aviation.military.naval
Mark Borgerson[_2_]
Default Boeing Reveals Sub-Tracking ScanEagle Study
In article caa4e8fe-7afd-4102-88ae-c432bde27500@
8g2000hse.googlegroups.com, says...
On Jun 27, 7:42*pm, Fred J. McCall wrote:
:It looks like the P-8 is going to use expendable UAV's to look
:at surface targets too:
http://www.aviationweek.com/aw/blogs...plckController....
:Using expendable UAV's for routine missions like this could get
:expensive after awhile.
Apparently that costs less than the loss of airframe life from using
the airplane to do it, which is why it's being considered.
"Millions for defense, but not one cent for tribute."
* * * * * * * * * * * * * *-- Charles Pinckney
I just spent 40 minutes responding to this post with an explanation of
what airborne ASW could do to really be part of the game and become a
serious threat to Submarines. It was really cool and relatively
inexpensive.
Then I realized what the hell I was doing and which side I favored so
I deleted the entire post.
I'm really glad I did, because while it would have been interesting to
see what some of you would have done with it, picking it apart and
playing with it, I know there are some very good S-T&E's here that
might have found a way to make it work. And that scared the hell out
of me.
It would probably have been an interesting discussion. As for making
it work---there might be people out there to do that. However, I
suspect that ONR is keeping a good number of them busy with similar
ideas. From my semi-insider point of view, there are more ideas
than engineers, scientists, and research dollars in the US now. That
balance may be different in China and Iran. They may have some
different set of ideas, funding and engineers. The ideas are
probably most easily exported from the US, so let's be a bit
stingy with those!
Mark Borgerson
Old June 30th 08, 03:48 AM posted to sci.military.naval,rec.aviation.military.naval
BlackBeard
On Jun 28, 4:32*am, "dott.Piergiorgio"
:http://www.aviationweek.com/aw/blogs...plckController....
serious threat to Submarines. *It was really cool and relatively
inexpensive.
might have found a way to make it work. *And that scared the hell out
of me.
How I must parse this ?
"I was writing ramblings on 'how things must be done' theme"
or
"I was on the verge of talking too much in a public place"
Best regards from Italy,
Dott. Piergiorgio.
Number two...
BB
I guess everybody has some mountain to climb in their life.
It's just fate whether you live in Kansas or Tibet.
Old June 30th 08, 03:52 AM posted to sci.military.naval,rec.aviation.military.naval
BlackBeard
inexpensive.
of me.
It would probably have been an interesting discussion. *As for making
it work---there might be people out there to do that. *However, *I
ideas. * From my semi-insider point of view, *there are more ideas
than engineers, *scientists, and research dollars in the US now. *That
balance may be different in China and Iran. *They may have some
different set *of ideas, *funding and engineers. *The ideas are
stingy with those!
Mark Borgerson
The idea was simple enough but it took full advantage sensitive
knowledge from the hunted side that would be inappropriate for the
group.
BB
Old June 30th 08, 04:47 AM posted to sci.military.naval,rec.aviation.military.naval
Fred J. McCall
BlackBeard wrote:
:On Jun 29, 12:01*pm, Mark Borgerson wrote:
: In article caa4e8fe-7afd-4102-88ae-c432bde27500@
: 8g2000hse.googlegroups.com, says...
: On Jun 27, 7:42*pm, Fred J. McCall wrote:
: wrote:
: :It looks like the P-8 is going to use expendable UAV's to look
: :at surface targets too:
: :http://www.aviationweek.com/aw/blogs...plckController...
: :Using expendable UAV's for routine missions like this could get
: :expensive after awhile.
: Apparently that costs less than the loss of airframe life from using
: the airplane to do it, which is why it's being considered.
: I just spent 40 minutes responding to this post with an explanation of
: what airborne ASW could do to really be part of the game and become a
: serious threat to Submarines. *It was really cool and relatively
: inexpensive.
: Then I realized what the hell I was doing and which side I favored so
: I deleted the entire post.
: I'm really glad I did, because while it would have been interesting to
: see what some of you would have done with it, picking it apart and
: playing with it, I know there are some very good S-T&E's here that
: might have found a way to make it work. *And that scared the hell out
: of me.
: It would probably have been an interesting discussion. *As for making
: it work---there might be people out there to do that. *However, *I
: suspect that ONR is keeping a good number of them busy with similar
: ideas. * From my semi-insider point of view, *there are more ideas
: than engineers, *scientists, and research dollars in the US now. *That
: balance may be different in China and Iran. *They may have some
: different set *of ideas, *funding and engineers. *The ideas are
: probably most easily exported from the US, so let's be a bit
: stingy with those!
:The idea was simple enough but it took full advantage sensitive
:knowledge from the hunted side that would be inappropriate for the
:group.
And this seems like an appropriate place for my usual disclaimer.
I will never say anything about specifics or capabilities that doesn't
derive from public sources (and yes, I usually go do a quick check -
Google is your friend). In point of fact, I will argue in favour of
positions or facts that I know to be incorrect if those positions or
facts are what the consensus of publicly available information says
and will argue against positions and facts I know to be correct for
the same reason.
If you're looking for classified or 'sensitive' data or arguments
based upon them, you're looking in the wrong place...
"I know Slayers. No matter how many people there are around
them, they fight alone."
-- Spike, the vampire
Old June 30th 08, 05:25 AM posted to sci.military.naval,rec.aviation.military.naval
Mark Borgerson[_2_]
says...
: inexpensive.
: of me.
:group.
the same reason.
Age and temporal distance from the subject are also a factor.
There are a lot of declassified documents available now covering
operations I was part of in the 1970s. There are also semi-official
sources like "Body of Secrets" covering sigint ops. Rather
than base my statements solely on my memories of the 1970s, I try
to find an online reference to any classified projects I might have
worked on.
OTOH, I feel reasonably free to speculate on possible
military uses of unclassified technology I've worked with. If some
of the government R&D I've worked on has slid into classified projects,
they're not telling me about it!
Since I last had a clearance in 1974, any remnants of classified
knowledge I might dredge up probably come under the "Top Secret
Embarassing" heading, rather than being a revelation of sensitive
technology. Technology we thought was hot in the 70's is now $1.95,
qty 1 in the DigiKey catalog (microprocessors with 1MHz clock rates,
etc.).
Mark Borgerson
Old June 30th 08, 05:55 AM posted to sci.military.naval,rec.aviation.military.naval
Mark Borgerson[_2_]
In article c24e0219-f846-4d01-a3d3-
, says...
inexpensive.
of me.
stingy with those!
Mark Borgerson
group.
I suppose there are lots of seemingly-insignificant operational
and technical details that could add up to a risk to our
submariners. Something as simple as "You know, the bojimbo
always clicks against the frammistan when we go from 400 to
450 ft." may sound insignificant in itself. But if you
fill a notebook with observations like that, it probably
shouldn't leave the boat.
Simple observations about recurring patterns, mixed with
bright minds can get you to something like Ultra. When it
comes to subs or other military operations, the biggest
leaks often start with "We always....". Part of the
problem for submariners is that the training may
emphasize "Before conducting procedure X, you will always
do procedure Y." If either X or Y has a physical manifestation
outside the boat, you could have a security problem.
Here's my own totally-made up version of an operational detail
that might be a security problem:
"When initiating TMA on the Seawolf Class submarine, it is
always best to make the initial turn to starboard and use
the port side lateral array between the hours of 1300-1500
and 1900-2100. During these hours, the galley
dishwasher, mounted against the starboard outboard bulkhead,
causes a 2.3dB reduction in the signal-to-noise ratio in the
forward half of the starboard lateral array. SUB_NAV_FIXEM
has issued a modification order to resolve this problem, and
parts are estimated to be sub qualified and available in
early 2011."
It gets even worse when a new mess crank arranges the plates
so that they clink together as the spray head rotates! ;-)
Mark Borgerson
Old July 2nd 08, 05:48 PM posted to sci.military.naval,rec.aviation.military.naval
dott.Piergiorgio
Number two...
OK I acknowledge; a year or so on the Italian military/Naval NG we have
haved a similiar incident.....
Dott. Piergiorgio.
Old July 2nd 08, 05:50 PM posted to sci.military.naval,rec.aviation.military.naval
dott.Piergiorgio
: serious threat to Submarines. It was really cool and relatively
: inexpensive.
: might have found a way to make it work. And that scared the hell out
: of me.
: It would probably have been an interesting discussion. As for making
: it work---there might be people out there to do that. However, I
: ideas. From my semi-insider point of view, there are more ideas
: than engineers, scientists, and research dollars in the US now. That
: balance may be different in China and Iran. They may have some
: different set of ideas, funding and engineers. The ideas are
:group.
the same reason.
Old July 2nd 08, 06:09 PM posted to sci.military.naval,rec.aviation.military.naval
dott.Piergiorgio
:group.
the same reason.
In this period I'm working on a study/essay what I consider the best
"no-nonsense" classification rule sets, whose can be read on the UK's
Naval Rewiew in the very first issue, 1913, pp. 9-11, article "War
thought and Naval war", whose, in a nut, says "if something can be
extrapolated by intelligent people with public sources and/or plain
facts, classifying it it's useless"
Hence my original question. Aside the issues on the (perceived or not)
excesses of classification by the current US (and other) administration
& gov't, I guess that a balance with Occam's razor in classifications is
what current state of scientific & military research needs, to be
restarted after the many SNAFUs in the procurement (even civilian)
worldwide.
Dott. Piergiorgio.
Old July 2nd 08, 06:16 PM posted to sci.military.naval,rec.aviation.military.naval
dott.Piergiorgio
etc.).
I guess that you have actually read, and also read between the lines, of
the my post on geeks & engineering Indeed the issues around the first
microprocessor and the F-14 CADC was in my mind when I wrote said post...
It's a pity that sometimes my posts are apparently ignored, albeit I
acknowledge that lately the quality of my English is a bit wandering, to
say the least.....
Dott. Piergiorgio.
Cessna Reveals "Cirrus Killer" Darkwing Piloting 31 July 28th 06 07:29 PM
For F-5 fans - Iran reveals new F-5 based twin-tailed Azarakhsh fighter TJ Military Aviation 1 July 11th 04 09:40 PM
Britain Reveals Secret Weapon - Chicken Powered Nuclear Bomb ! Ian Military Aviation 0 April 2nd 04 03:18 PM
Wild flight reveals gaps within FAA --Philadelphia Inquirer News Piloting 0 March 29th 04 01:30 AM
Aviation Conspiracy: AP Reveals Series Of Boeing 777 Fires!!! Bill Mulcahy General Aviation 18 October 16th 03 09:15 PM
