Here's a question for the trolls and flight simmers
Old June 19th 08, 02:49 PM posted to rec.aviation.piloting
Stealth Pilot[_2_]
Default Here's a question for the trolls and flight simmers
I know we beat on you guys a lot here but here is a serious question
for you to explore.
scenario: you are flying along on a bright sunny day with no cloud
cover. your wingspan is about 20 ft, fuselage length 14ft and
tailplane about 8ft span. your altitude is 4,500ft.
you look down below you in the exact opposite direction to the sun.
what do you see below you scooting along the ground below you?
is it a sharply defined shadow of your aircraft?
a fuzzy indistinct shadow of your aeroplane?
or what?
it is quite distinct and you can pick it from nearly a mile away.
.....now pilots dont tell them. these guys are actually quite
intelligent but not in' hands on' aviation matters. they should be
able to work this out.
John Gribbin's book 'Science - A History' contains a neat explanation
in the discussion of Fresnel's model of light on p408.
Stealth Pilot
Old June 25th 08, 01:43 PM posted to rec.aviation.piloting
Mike[_22_]
"Stealth Pilot" wrote in message
for you to explore.
or what?
In the grand scheme of "hands on aviation matters", how many beans are in
this hill?
Old June 25th 08, 03:13 PM posted to rec.aviation.piloting
Stealth Pilot[_2_]
for you to explore.
or what?
this hill?
I notice that there are no attempts at an answer.
Old June 25th 08, 03:46 PM posted to rec.aviation.piloting
alexy
for you to explore.
or what?
this hill?
Well, you directed the question to flight simmers and trolls. If you
want to open it up to non-pilot lurkers, I'll take a guess. Assuming
you will reveal the correct answer and explain it.
Alex -- Replace "nospam" with "mail" to reply by email. Checked infrequently.
Old June 25th 08, 06:32 PM posted to rec.aviation.piloting
glory be, what can the answer be?
for you to explore.
or what?
this hill?
Old June 25th 08, 08:05 PM posted to rec.aviation.piloting
alexy
for you to explore.
or what?
this hill?
My guess is that since the plane will subtend a much smaller angle
than the sun, there would be no noticeable shadow. My guess is a
"halo" around where the shadow would be, caused by diffraction, Since
most of the edges tend to be inline with the plane's axis or
perpendicular to it, it seems that this halo might be somewhat
brighter on those two axes, but I wonder if that would be noticeable.
The halo might have a slightly bluish cast, since the red end of the
spectrum would get diffracted more, and being over a larger area would
be not as bright.
So, what's the real answer?
Old June 25th 08, 09:32 PM posted to rec.aviation.piloting
On Jun 19, 8:49 am, Stealth Pilot
for you to explore.
or what?
Stealth Pilot
Is this a test, or are you curious what the sim does? :/
In real life, you will see a vague outline of the plane,
but it will be pretty fuzzy in general.
In the present sim I use, "FSX" the shadow is always sharp..
They don't have that "fuzzy" technology down yet..
I have pictures of both real shadows, and can easily fire
up the sim for it's version if needed.
Dunno about 4500 ft though.. I'm not sure if he was
quite that high in the best examples I have, which were
taken from a Piper Cub..
The sim has the same Cub, so it would be easy to compare
real to sim, using the same exact aircraft.
But I can tell you right now, the real version is going to be
a lot fuzzier than the sim.
Old June 25th 08, 09:36 PM posted to rec.aviation.piloting
for you to explore.
or what?
Stealth Pilot
look up 'glory' in an aviation context.
Old June 28th 08, 11:53 PM posted to rec.aviation.piloting
Rich Ahrens[_2_]
on 6/25/2008 3:36 PM said the following:
Does it have anything to do with Maxwell in an airport restroom?
Pilot's Assistant Directory - Free Information Resource for Flight Simmers - Updated AirToob Simulators 0 July 19th 07 11:10 AM
(OT) MS Simmers Dan544 Piloting 66 May 7th 07 10:04 PM
Slightly O/T for flight simmers. Building my own airport Andrew Scotland Simulators 4 July 24th 05 10:13 PM
Check This Out!!! (must have for all flight simmers) Boeing747 Simulators 1 July 3rd 04 12:43 AM
Calling Simmers in the Midlands, UK 'Mort' Simulators 0 March 24th 04 08:16 PM
