HID Lighting Questions
Old June 29th 08, 04:11 PM posted to rec.aviation.owning
The Visitor
Default HID Lighting Questions
What orientation is the bulb placed in?
In the bulb there is a glass tube and a wire that runs forward, paralell
to it. That wire/electrode should be in the 6 oclock position. For
instance if it is at the 12 oclock position the bulb will develop a
yellow cast and have problems.
Well that's what I have been told from my lighting guy.
John
On Jun 27, 7:40 pm, Steve - KDMW wrote:
Some questions on HID lighting. I have a 1974 PA28-151 and would like
to replace my landing light (cowl mounted) with an HID light. I know
about the boom beams, but I also see that Precise Flight makes HID
lighting also, and it's about half the price of LoPresti's.
The HIDs are quite a bit deeper. And you need a place to mount the
power supply.
Around here, a local shop is installing them with a field approval. A
sample
337 that has been approved would help you.
I seem to be a corner case.... I installed one in my Bonanza and I've
had
trouble with the vibration killing the bulb. No one can figure it
out.
FWIW. Bill Hale Loveland CO
I looked at Precise Flight's installation manual and noticed that it
was written by Knots2U. In addition, it states that the lighting is
for wing mounting only and for Piper models PA24/30/39 aircraft.
My question is... a PAR36 bulb is a bulb is a bulb, isn't it? Aside
from perhaps the legality of the FAA approving this STC for one
specific location, wouldn't this bulb and installation kit work just
as well for a cowl-mounted light? The specifications for this bulb are
exactly the same specs as for all of the other HID bulbs, i.e. 500,000
CP, 35 watts, 12 volts, 2.5 Amps, PAR36, etc.
Steve
KDMW
Lighting Rio Aviation Photos 0 December 28th 07 02:13 AM
HID Lighting Mike Rapoport Owning 35 October 5th 06 09:02 PM
EL Cockpit Lighting? JB Owning 10 October 21st 05 07:23 PM
Electroluminescent Lighting dave Home Built 10 February 27th 04 03:46 PM
Mig-29 questions & general aviation questions 2003 Steven Military Aviation 1 October 20th 03 06:06 AM
