A BOMB PATTER IS LIKE A FOOTBALL
Old March 2nd 04, 03:24 PM
Emilio
If there is a hole in the pattern it means someone dropped late, and there
will
be more hell to pay.
I assume the over all formation pattern of B26 was in a form of a circle to
produce football pattern on the ground. That means there should be number
of overlap bombing at the center of football to reduce the hole in the
middle. Am I right?
Emilio.
"ArtKramr" wrote in message
A BOMB PATTERN IS LIKE A FOOTBALL: BOMB PATTERN ANALYSIS
One thing I never see in any WW II literature is bomb pattern analysis in
tactical bombing. There is a lot to it that we had to live with, and I
thought
I would share it with those on this NG before it gets lost to history.
Think of a formation of 56 B-26 Martin Marauders in tight formation. If
all are
in tight formation, and release on time and all functions are go the bomb
pattern on the ground will be shaped like a football.
After we fly a mission and the smoke has cleared a P-38 with guns removed
and
fitted with cameras will over fly the target area and record the bomb
pattern
damage on the ground. It should be a perfect football. But if there is a
bulge
or hole in the football pattern, that is trouble.
A bulge in the pattern means someone was out of formation. And astute,
well
trained., experienced photo analysis men can not only spot the bulge,
they can
identify the pilot that was out of formation. And for that pilot there
will be
hell to pay.
will
be more hell to pay. We didn't send 56 aircraft with 336 aircrews in harms
way
for one pilot or bombardier to screw up the mission. And our CO never took
these screw ups lightly. But neither did the aircrews. When someone
screwed
up, the aircrews made their displeasure known and friends became few and
far
between even when the target was effectively hit.
But the photo guys could tell the difference between a screw up and a
single
defective bomb. There were two reasons for a single defective bomb, one
was it
was off weight and the other was bent vanes. There were some other causes;
a
sticking A-2 shackle could cause a bomb to hang up momentarily and release
late. But that was very different than an entire bomb load going out late.
We lived with this analysis on every mission. And aft And after a mission
no
news from ops was good news. And that is the way it was in tactical
operations
in WW II. Moral of the story? Keep you head out of your ass and stay
alert,
always alert.
Arthur Kramer
344th BG 494th BS
England, France, Belgium, Holland, Germany
Visit my WW II B-26 website at:
http://www.coastcomp.com/artkramer
Old March 2nd 04, 04:04 PM
ArtKramr
Subject: A BOMB PATTER IS LIKE A FOOTBALL
Date: 3/2/04 7:24 AM Pacific Standard Time
Message-id:
will
middle. Am I right?
Emilio.
thought
all are
and
pattern
bulge
well
they can
will be
hell to pay.
will
way
screwed
far
single
was it
a
no
operations
alert,
always alert.
Arthur Kramer
344th BG 494th BS
No the formation was football shaped. Another cause of a hole in the pattern
could be a bomb load going out taking improperly installed arming wires with
them. But that was rare.
Arthur Kramer
344th BG 494th BS
Old March 2nd 04, 05:09 PM
Emilio
pattern
with
Were all the bombs released at the same time to form a football pattern on
the ground, or did each bomber released the bombs over the target? Was the
football shape chosen to minimize crosswind condition at the target? In
that case, bomb trajectory can drift sideways and the main axis of football
will be off the target.
Emilio.
Old March 3rd 04, 07:56 AM
John Keeney
"Keith Willshaw" wrote in message
The pilot had to continue to fly straight and level AFTER
bomb release until the camera flashed. When Radar bombing was used
the camera recorded the image on the radar scope. If there was no
it didnt count as a mission.
Keith
The problem with the Brit system was that the target was still smoking
when
the pictuere was taken so less information was recorded. But it saved
them
that
second recon flight If you check my website you will see impact shots
taken
with the bombay camera recorded at the detonation moment. Now click on "
Death
of a marshalling yard" to see the reults of the recon mission.
The recon flights were still made Art. Since the RAF were flying tight
formations
comparing the in-aircraft camera pictures with the after strike recon
photos was the only way of establishing individual accuracy
What was the point? If you are flying tight formation indivual planes
can't correct for drift. Were they not dropping when the lead did and
trying measure the single dimension?
Old March 3rd 04, 12:20 PM
ArtKramr
Date: 3/2/04 11:56 PM Pacific Standard Time
Message-id:
Keith
when
them
that
taken
Death
formations
"....trying measure the single dimension..." ?????
I don't understand that last phrase. Please clarify.
Arthur Kramer
344th BG 494th BS
Old March 3rd 04, 01:47 PM
Keith Willshaw
"John Keeney" wrote in message
formations
Sorry I misstyped
I should have said the RAF were NOT flying tight formations
Basically the night attack formation was the bomber stream, no
attempt was made to fly in formation and each aircraft basically
navigated to the target and dropped on its own. It was rare
for one bomber to even see another much less formate on it.
Later in the war the target would be marked by Pathfinders
and aircraft would be instructed to bomb the markers laid
down by that force.
In daylight they tended to fly a looser formation than the
USAAF with aircraft flying a loose gaggle at staggered heights
and individual aircraft would drop on their own bombardiers
command.
Keith
The U.S. Air Force awarded BOEING CO. a $188.3 million new small-diameter precision-guided bomb contract Larry Dighera Military Aviation 3 October 28th 03 12:07 PM
Air Force announces winner in Small Diameter Bomb competition Otis Willie Military Aviation 0 August 30th 03 03:06 AM
AIRCRAFT MUNITIONS - THE COBALT BOMB Garrison Hilliard Military Aviation 1 August 29th 03 09:22 AM
FORMATIONS, BOMB RUNS AND RADIUS OF ACTION ArtKramr Military Aviation 0 August 10th 03 02:22 AM
The written History of the 344th Bomb Group ArtKramr Military Aviation 1 July 8th 03 07:05 PM
