pitot tube down
Old March 3rd 04, 07:00 PM
Tarver Engineering
"Rick" wrote in message
hlink.net...
Tarver Engineering wrote:
Panic seems to be the reason people don't think their way out of these
kind
of single point failures. I have to winder if the pilot didn't expect
to
have to do more than raise the wheels and adjust the flaps.
One of your series connections is open circuit, Tarver,
As a congenital idiot who couldn't learn to fly an aircraft in a
thousand years your statment above pretty much defines the level of your
knowledge of aircraft operations ... zilch.
Since the FO's air data was correct, one can only believe you post from
ignorance, Rick. Robots fly 757 airplanes most of the time, but sometimes
the pilot has to operate.
I beleive UAVs are the way of the furture in the Military sense of the word
aviation.
Old March 4th 04, 01:13 AM
"W. D. Allen Sr." wrote:
How did they even get the 757 off the ground?
WDA
Well, it WAS a pretty confusing readout on the CVR tape for sure,
lots of shouts of 'what's it doing that for' and like
stuff,...but most of it seemed to happen after they were almost
off the ground (ISTR). I had the CVR transcript at one time. I
believe that they got up to several thousand feet at one point.
-Gord.
Old March 4th 04, 03:03 AM
C Knowles
"Leadfoot" wrote in message
news:f4c1c.9887$Zp.3539@fed1read07...
"C Knowles" wrote in message
news
Not that familiar with the 757 but GPS displays GS. Add or subtract
winds
to
get TAS, then correct for density (divide by SMOE) to get IAS?CAS.
Heard
it
suggested you could also depressurize and use the cabin altimeter for
altitude. Or, convert cabin altitude into aircraft altitude if the chart
is
available.
Curt
Multiple redundant systems on Commercial jets. Figure out which one is
bad
and turn it off. The standby #3 system is analog and totally separate if
it's like a 747-400. The captain should have given control to the copilot
in the turkish aircraft incident.
Well, that's only if you follow the flight manual and common sense.
Just discussed this one in my quarterly refresher. The discussion turned to
"what if" you lost all airspeed and altitude indications. It was an exercise
in making us think. It would also be a handy method to double check the
primary instruments, or to have something to do on those long overwaters.
Curt
Old March 4th 04, 05:28 PM
Tarver Engineering
. com...
news
winds
to
Heard
it
chart
is
available.
Curt
bad
if
copilot
to
exercise
There would be no loss of airspeed indications. The airplane would seem
perfectly normal until there was no change in the altimeter. Get the
confusion about pitot tubes out of your head, as there is no relevence to
the discussion at hand. In fact, ignorance about transport air data
instrumentation may have contributed to the confusion the operator
displayed.
Old March 4th 04, 05:41 PM
B2431
Date: 3/4/2004 11:28 AM Central Standard Time
Message-id:
.com...
news Not that familiar with the 757 but GPS displays GS. Add or subtract
winds
to
Heard
it
chart
is
available.
Curt
bad
if
copilot
to
exercise
displayed.
That depends on the amount of change in altitude. If the change is significant
your IAS will show a decrease in velocity since it will no longer be
compensating for altitude. That's the reason IAS requires both pitot and
static.
Dan, U.S. Air Force, retired
Old March 4th 04, 05:45 PM
Tarver Engineering
"B2431" wrote in message
Message-id:
.com...
winds
to
Heard
it
for
chart
is
available.
Curt
is
bad
separate
if
copilot
turned
to
exercise
overwaters.
displayed.
significant
static.
Sure.
Old March 6th 04, 11:37 PM
Leadfoot
winds
to
Heard
it
chart
is
available.
Curt
bad
if
copilot
to
exercise
Curt
Pitot tube question Doc Font Home Built 2 January 24th 05 04:28 AM
Pitot tube prices B2431 Home Built 2 May 16th 04 08:13 PM
Rag and tube construction and computer models? BllFs6 Home Built 24 April 12th 04 12:20 PM
Why 4130 tube? Leon McAtee Home Built 31 March 28th 04 03:04 PM
Chuck Yeager-pitot tube Ron Military Aviation 44 October 9th 03 03:13 AM
