Computer help needed
Old July 18th 08, 02:42 AM posted to rec.aviation.homebuilt
clare at snyder dot ontario dot canada
Default Computer help needed
On Thu, 17 Jul 2008 17:52:38 +0000, jan olieslagers
schreef:
It looks as if I'll have to do the repair myself.
New keyboards are available from the OEM (Vivo) for about $40. The HP
maintenance manual is available via the internet. That leaves a few
issues unresolved but since the thing was working in the past I'll
assume it can be returned to service.
-R.S.Hoover
-(KA6HZF)
Bob,
Allow me to suggest some clarification.
I understand you are after an "identical" or "matched"
or "certified" keyboard - but there's no need.
Any PC keyboard with the proper interface
(in your case, USB, I understand)
and the proper layout (US English, assumedly) will do.
Indeed it shouldn't be too difficult to locate a
suitable keyboard near you (neighbours? friends? shop PC?)
and borrow it for a quick swap, just to confirm the diagnosis.
An IMPORTANT correction here.
This WILL work - BUT. The original damaged keyboard MUST be
disconnected first if, as I suspect, at least one key is "stuck"
electrically.
As for returning the PC to service:
yes, sooner or later that's always possible.
Questions are
1) if it's worth the money (I abandoned a laptop
after breaking the display, the replacement was over-expensive)
2) whether you can recover the data from the harddisk.
This is crucial: a new harddisk is easily available
at reasonable cost, but is unfortunately supplied blank.
Indeed you'll likely find the data on the disk
much more valuable than the PC as such.
It is not out of the ordinary for the data to be worth HUNDREDS of
times more than the computer it is on.
I'd pull the hard drive, stick it into a USB drive case, and connect
it to another computer to see if it is readable before wasting ANY
more time on the computer. No need to get the old computer running if
you can just pop the data from the old drive into a new computer.
(by the way, I do this a LOT in my business - repairing and
maintaining computer systems)
There's companies specialized in recovering data
from crashed harddisks but they're horribly expensive.
Hoping this helps,
KA
** Posted from http://www.teranews.com **
Old July 18th 08, 03:15 AM posted to rec.aviation.homebuilt
john smith
If the drive works when inserted in an external case and you get error
messages trying to read it, you can order and download a copy of
SPINRITE from grc.com. Cost is $89, money well spent.
It may take some time (the longest reported recovery time is 3-months, I
personally had one run 23-days on a 250GB HD on a Toshiba laptop) but it
will recover anything that is recoverable.
Old July 18th 08, 10:18 AM posted to rec.aviation.homebuilt
Stealth Pilot[_2_]
On Thu, 17 Jul 2008 21:42:49 -0400, clare at snyder dot ontario dot
chuckle
my laptop cost $1500.
the software on it that will be installed on site in the next few
months is worth $440,000 to the customer.
thats 293 times. 'bout right.
that advise is bang on the money Clare.
it is the easiest way to go.
Stealth Pilot
computer lynas Piloting 0 June 24th 08 07:43 AM
New computer Cal Vanize Simulators 0 April 6th 06 05:28 AM
Sim Computer Lifelists Simulators 8 January 6th 05 12:35 AM
Computer problem Mike Lindsay Soaring 1 April 22nd 04 12:08 AM
Soaring Flight Computer Comparison - Help needed Paul Remde Soaring 10 January 29th 04 07:35 PM
