#11
![]() "Scott Ferrin" wrote in message ... On Wed, 03 Mar 2004 03:19:41 GMT, "Thomas Schoene" wrote: Scott Ferrin wrote: Nope. The X-32 would have but not the 35. My guess is they could have but maybe Lockhhed didn't want it competing with the F-22. Or they didn't want to pay the weight penalty in an aircraft designed for strike over air-to-air. I recently suggested that if the F/A-22 were canceled, the Air Force might look at an air-to-air version of JSF. An axi-symetrical thrust vectoring nozzle would be high on the list of desirable modifications for such an aircraft, I suspect. I'd think they'd have to make quite a few changes to make it good enough to be the primary air to air fighter. Internal weapon load is tiny (2 -120s), the thrust to weight leaves a lot to be desired, and how does it fair in the manueverability dept.? Sure you can add external weapons but then there goes your stealth. Then when the politicians start screaming because the F-35's cost is going up and service date is getting pushed back so the required changes can be incorporated. . . We can hope the F-35 folks will stand their ground. |
Scott Ferrin wrote:
On Wed, 03 Mar 2004 03:19:41 GMT, "Thomas Schoene" wrote: Scott Ferrin wrote: Nope. The X-32 would have but not the 35. My guess is they could have but maybe Lockhhed didn't want it competing with the F-22. Or they didn't want to pay the weight penalty in an aircraft designed for strike over air-to-air. I recently suggested that if the F/A-22 were canceled, the Air Force might look at an air-to-air version of JSF. An axi-symetrical thrust vectoring nozzle would be high on the list of desirable modifications for such an aircraft, I suspect. I'd think they'd have to make quite a few changes to make it good enough to be the primary air to air fighter. Internal weapon load is tiny (2 -120s), the thrust to weight leaves a lot to be desired, and how does it fair in the manueverability dept.? Sure you can add external weapons but then there goes your stealth. Then when the politicians start screaming because the F-35's cost is going up and service date is getting pushed back so the required changes can be incorporated. . . I used to despair.. Bradley, Sgt. York, Osprey, Crusader, The F-22 selection disaster.. - Oh Hell, they're falling like the Brits.. But now I rejoice. DIE Commanche! DIE Raptor. May you blunder in your rotten moral failing forever. May all your thumbs be left. May F-35 be interminably cursed by your obese, contemptible innate rottenness.. I turn away, I turn away in promise to the fast rising and glorious East.. I turn away, and behind me..may the rotted Whore of Babylon die soon! Rotted, rancid and befouled, forever. Grantland |
![]() "Scott Ferrin" wrote in message ... On Wed, 03 Mar 2004 03:19:41 GMT, "Thomas Schoene" wrote: Scott Ferrin wrote: Nope. The X-32 would have but not the 35. My guess is they could have but maybe Lockhhed didn't want it competing with the F-22. Or they didn't want to pay the weight penalty in an aircraft designed for strike over air-to-air. I recently suggested that if the F/A-22 were canceled, the Air Force might look at an air-to-air version of JSF. An axi-symetrical thrust vectoring nozzle would be high on the list of desirable modifications for such an aircraft, I suspect. I'd think they'd have to make quite a few changes to make it good enough to be the primary air to air fighter. Internal weapon load is tiny (2 -120s), the thrust to weight leaves a lot to be desired, and how does it fair in the manueverability dept.? Sure you can add external weapons but then there goes your stealth. Then when the politicians start screaming because the F-35's cost is going up and service date is getting pushed back so the required changes can be incorporated. . . First, you have to accept the conditional that Tom put forward--"if the F/A-22 were cancelled". If you do that, then what are you *left* with as a potential air-to-air fighter to replace the F-15C? Only three options are really open to consideration-- (a) buy newer F-15's, something along the line of the F-15K (unlikely IMO), (b) buy offshore (i.e., Typhoon) (unlikely, and yet to be proven significantly superior to option (a)--hold the catcalls, please), or (c) develop a more capable version (in air-to-air terms) of the F-35 series. Of course, you could just start a whole new program to produce a new air superiority fighter...but that would be a non-starter. IMO, Tom's option (c) would be the most likely outcome. Maneuverability? Apparently it will be a quite nimble aircraft; very similar layout to the F-22, and with the thrust vectopring postulated here... Internal weapons load? Yeah, two AIM-120's would be marginal, but if you are going to make versions primarily AAW oriented, there is lots of room in each bay to accomodate another AIM-120 in lieu of the bomb that would also be carried in the current versions) if they developed a new internal bay configuration, and four AIM-120's would be nothing to sneeze at. That thrust-to-weight ratio also looks a bit better with the deletion of 4000 pounds of internal bomb carriage in the air-to-air role--it should be around the 1:1 ratio in that scenario. It already will have a pretty good AESA radar, and presumably the required LINK 16 capabilities. So why do you think optimizing the weapons bays to carry four AIM-120's vice two AIM-120's and a couple of big bombs would require such significant rework as to be delayed at much greater cost? Personally, I don't see any of this happening--the F/A-22 will be purchased, albeit probably only in the 200 aircraft figure in its current guise, with a decent possibility of more production in the form of a strike optimized version. Brooks |
![]() "Kevin Brooks" wrote in message ... Personally, I don't see any of this happening--the F/A-22 will be purchased, albeit probably only in the 200 aircraft figure in its current guise, with a decent possibility of more production in the form of a strike optimized version. No matter wht the outcome of the F-22 procurement, the F-35 will have to fill part of the F-15 role. The 200 figue was a 180 figure 12 months ago and it is decreased by the 17 FSDs, at the very least. A capable F-35 is one issue, but at this point configuration control is a necessity of risk management. |
"Kevin Brooks" wrote:
"Scott Ferrin" wrote in message .. . On Wed, 03 Mar 2004 03:19:41 GMT, "Thomas Schoene" wrote: Scott Ferrin wrote: Nope. The X-32 would have but not the 35. My guess is they could have but maybe Lockhhed didn't want it competing with the F-22. Or they didn't want to pay the weight penalty in an aircraft designed for strike over air-to-air. I recently suggested that if the F/A-22 were canceled, the Air Force might look at an air-to-air version of JSF. An axi-symetrical thrust vectoring nozzle would be high on the list of desirable modifications for such an aircraft, I suspect. I'd think they'd have to make quite a few changes to make it good enough to be the primary air to air fighter. Internal weapon load is tiny (2 -120s), the thrust to weight leaves a lot to be desired, and how does it fair in the manueverability dept.? Sure you can add external weapons but then there goes your stealth. Then when the politicians start screaming because the F-35's cost is going up and service date is getting pushed back so the required changes can be incorporated. . . First, you have to accept the conditional that Tom put forward--"if the F/A-22 were cancelled". If you do that, then what are you *left* with as a potential air-to-air fighter to replace the F-15C? Only three options are really open to consideration-- (a) buy newer F-15's, something along the line of the F-15K (unlikely IMO), (b) buy offshore (i.e., Typhoon) (unlikely, and yet to be proven significantly superior to option (a)--hold the catcalls, please), or (c) develop a more capable version (in air-to-air terms) of the F-35 series. Of course, you could just start a whole new program to produce a new air superiority fighter...but that would be a non-starter. IMO, Tom's option (c) would be the most likely outcome. Maneuverability? Apparently it will be a quite nimble aircraft; very similar layout to the F-22, and with the thrust vectopring postulated here... Internal weapons load? Yeah, two AIM-120's would be marginal, but if you are going to make versions primarily AAW oriented, there is lots of room in each bay to accomodate another AIM-120 in lieu of the bomb that would also be carried in the current versions) if they developed a new internal bay configuration, and four AIM-120's would be nothing to sneeze at. That thrust-to-weight ratio also looks a bit better with the deletion of 4000 pounds of internal bomb carriage in the air-to-air role--it should be around the 1:1 ratio in that scenario. It already will have a pretty good AESA radar, and presumably the required LINK 16 capabilities. So why do you think optimizing the weapons bays to carry four AIM-120's vice two AIM-120's and a couple of big bombs would require such significant rework as to be delayed at much greater cost? Personally, I don't see any of this happening--the F/A-22 will be purchased, albeit probably only in the 200 aircraft figure in its current guise, with a decent possibility of more production in the form of a strike optimized version. Brooks What you need is an upscaled F-23 Bomber-Fighter Ultrastealth with 60 or more internal sbds or internal 14 RAMRAAMS. A ****ing fleet. Grantland |
Scott Ferrin wrote:
On Wed, 03 Mar 2004 03:19:41 GMT, "Thomas Schoene" wrote: Scott Ferrin wrote: Nope. The X-32 would have but not the 35. My guess is they could have but maybe Lockhhed didn't want it competing with the F-22. Or they didn't want to pay the weight penalty in an aircraft designed for strike over air-to-air. I recently suggested that if the F/A-22 were canceled, the Air Force might look at an air-to-air version of JSF. An axi-symetrical thrust vectoring nozzle would be high on the list of desirable modifications for such an aircraft, I suspect. I'd think they'd have to make quite a few changes to make it good enough to be the primary air to air fighter. Internal weapon load is tiny (2 -120s) But the bays also have space for a pair of 2,000-lb bombs. If you can't find a way to get another AMRAAM in each bay, you're not trying. Two more in each bay would be harder, but seems doable. A total load of four AMRAAM woudl be small, but acceptable. A toal of six would match the F/A-22. , the thrust to weight leaves a lot to be desired, The F135 is officially a "40,000-pound class" engine, against a max-fuel weight of just under 50,000 pounds. Depending on how much rnage that thrust actually covers, the plane has a max-fuel thrust:weight of around 0.8:1 to 0.9:1. With less fuel (say partway through a flight) it might approach 1:1. (And as Kevin says, taking out the bomb rakcs would help a lot) As a real widlcard, Rolls Royce says the F136 can put out 56,000 pounds of thrust. If that number is even remotely close to right, there's a lot of surplus power potential there. Might have to rethink the inlet design, but that's not impossble for a dedicated air-to-air variant (certainly cheaper than a new plane). http://www.paksearch.com/br2002/Jul/...%20have%20huge %20thrust.htm and how does it fair in the manueverability dept.? (Fare) The Air Force says its instantaneous and sustained g capacities are already comparable to an F-16. They don't say which version of the F-16 or under what loads, but it's a hint that maneuveravility are not too bad. Sure you can add external weapons but then there goes your stealth. Well, there are degrees of stealth here. Wingtip AIM-9Xs might not impose horrible RCS penalties. -- Tom Schoene Replace "invalid" with "net" to e-mail "If brave men and women never died, there would be nothing special about bravery." -- Andy Rooney (attributed) |
Kevin Brooks wrote:
[big snip] So why do you think optimizing the weapons bays to carry four AIM-120's vice two AIM-120's and a couple of big bombs would require such significant rework as to be delayed at much greater cost? Thanks for the assist Kevin. We seem to be thinking along the same lines here. Personally, I don't see any of this happening--the F/A-22 will be purchased, albeit probably only in the 200 aircraft figure in its current guise, with a decent possibility of more production in the form of a strike optimized version. Agreed. I wasn't putting this forward as something that is likely to happen, just what might happen if the Raptor program was terminated. I suspect you're right that the F/A-22 will be built in limited numbers, though I woudl also not be surprised to see produciton continue after the intial batch is bought. We've bought far more F-15s than originally planned, after all. I'm not entirely convinced about the FB-22 or other strike-optimized version. It would have to have a lot of range to justify not simply using an F-35 derivative, IMO. Again, a possible variant comes to mind: A hybrid with the F-35A fuselage and the F-35C big wing ought to yield even more range than the 700+nm radius of the C version. -- Tom Schoene Replace "invalid" with "net" to e-mail "If brave men and women never died, there would be nothing special about bravery." -- Andy Rooney (attributed) |
![]() "Thomas Schoene" wrote in message hlink.net... Kevin Brooks wrote: [big snip] So why do you think optimizing the weapons bays to carry four AIM-120's vice two AIM-120's and a couple of big bombs would require such significant rework as to be delayed at much greater cost? Thanks for the assist Kevin. We seem to be thinking along the same lines here. Personally, I don't see any of this happening--the F/A-22 will be purchased, albeit probably only in the 200 aircraft figure in its current guise, with a decent possibility of more production in the form of a strike optimized version. Agreed. I wasn't putting this forward as something that is likely to happen, just what might happen if the Raptor program was terminated. Yeah, I figured as much, which is why I pointed out the big conditional "if" in your post; not sure Scott caught that. I suspect you're right that the F/A-22 will be built in limited numbers, though I woudl also not be surprised to see produciton continue after the intial batch is bought. We've bought far more F-15s than originally planned, after all. I'm not entirely convinced about the FB-22 or other strike-optimized version. It would have to have a lot of range to justify not simply using an F-35 derivative, IMO. Again, a possible variant comes to mind: A hybrid with the F-35A fuselage and the F-35C big wing ought to yield even more range than the 700+nm radius of the C version. I don't know. I see the FB-22, or something similar, offering a couple of advantages; it provides a solution to the "what do we use to start replacing the Mudhen in 2015-2020" problem, and it could bring down the unit cost for a reduced F/A-22 buy as long as significant commonality remains. I believe you and I discussed the F-35A vs. F-35C issue before over in SMN, IIRC. I have long wondered why the USAF did not take the larger wing of the C model, as well. They could delete the wing fold requirement, thus shaving a few pounds from it, and get that increased range you mention. The only cost I can think of would be in maneuverability, but that would not be critical in the strike role. But F-35 users that don't have the luxury of having a more capable/dedicated AAW platform in addition to their F-35's (unlike both the US and UK) would likely prefer retaining the smaller wing and its improved maneuverability. Maybe what we really need is a fourth version--the current A model for those international users described here, the STOVL version for the US (both USMC and USAF), the CV version for the USN, and your A-version-with-C version wings for the USAF CTOL requirement... Not that there is a chance in hell of that happening, of course. Brooks -- Tom Schoene |
Hi!
"Kevin Brooks" writes: F/A-22 were cancelled". If you do that, then what are you *left* with as a potential air-to-air fighter to replace the F-15C? F-18E? Best regards, -- Titta gärna på http://www.lysator.liu.se/~redin och kommentera min politiska sida. Magnus Redin, Klockaregården 6, 586 44 LINKöPING, SWEDEN Phone: Sweden (0)70 5160046 |
