#11
On Jul 24, 10:47*am, Eric Greenwell wrote:
After a trailer tire blowout last year, I installed a remote monitoring system that displays the trailer tire pressure on command, and alerts me automatically if the pressure drops. I don't know how effective this will be in avoiding tire problems, because it's possible tread separation can occur even if the pressure is OK, but at least I won't be driving on under-inflated tires. There are several systems that one can choose from. I'm using PressurePro, which is about $150 for the monitor and $50/tire for the sensors. I also put them on my tow vehicle, so it was $650 for the two trailer wheels and the six RV wheels. It was easy to install and seems to work well. Is anyone else using a trailer tire monitoring system? Has it helped you avoid tire problems? -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * Updated! "Transponders in Sailplanes"http://tinyurl.com/y739x4 * * * New Jan '08 - sections on Mode S, TPAS, ADS-B, Flarm, more * "A Guide to Self-launching Sailplane Operation" atwww.motorglider.org Trailer tires rarely fail because of improper inflation. This will affect tire life, but trailer tires rarely make it to the mileage life limit because of low usage. Trailer tires fail because of age (unless you drive over a nail!). Replace your trailer tires every 4 years, regardless of what they look like, and you will be fine. Tires rot from the insides by oxidation of the rubber with air, unless you fill with nitrogen. Checking the tire pressure once before hitting the road is often enough. Tom |
Ralph Jones wrote:
O Can't comment directly on trailers. But my wife's Dodge Caliber came with sensors as standard. For the first time that I can recall she has actually requested that I put air in her tire. Prior to that she has been known to drive for days with almost zero air pressure. I think the new sensors are great, on any application. They are, but it might be an expensive addition to a trailer. The tire pressure warning system on cars works by comparing the rotational speeds of all four wheels, and alarming when one wheel's speed is substantially below the mean. Not too many customers would pay for speed sensors on all four wheels just for this purpose -- but if your car has antilock brakes it already has those sensors, and the tire pressure logic is a trivial add-on. I believe most cars use actual pressure sensors, rather than the "indirect" rotational speed method, but I don't have any documentation for that. The pressure information from the sensor is transmitted wirelessly. That is how the system I use works. The cost is about $200 for the monitor, and $50 a wheel for the sensor. There are cheaper systems if you only want to monitor your trailer, but I wanted to monitor the six motorhome tires in addition to the trailer tires. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * Updated! "Transponders in Sailplanes" http://tinyurl.com/y739x4 * New Jan '08 - sections on Mode S, TPAS, ADS-B, Flarm, more * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
FA: 1-Day-Left: 3 Books: SPACE SATELLITE and AIRPHOTO INTERPRETATION, REMOTE SENSING, ENVIRONMENTAL MONITORING... | Mike[_18_] | Aviation Marketplace | 0 | July 7th 07 01:14 PM |
Tire tread wear vs inflation pressure | Ben Jackson | Owning | 22 | October 6th 06 04:35 AM |
Trailer tire rims | Gary Carter | Soaring | 7 | January 21st 05 03:15 PM |
Tire inflation pressure | Paul Lee | Home Built | 80 | November 19th 03 07:56 AM |
Tire Stiffness & trailer swaying | chris | Soaring | 42 | October 22nd 03 03:51 AM |
