On Aug 6, 10:25*am, raulb wrote:
I am sorryJJ. *I mis-read the posts. *I didn't realize you were selling these things until after I posted. *I thought I was thumbing my nose at someone else. I've been using JJ's tie-down kit with my ASW27 successfully. The ASW27 does not have otherwise any acceptable method for tie down which I know off. JJ's tie downs can go over the aileron or flaps without damaging them since the force is mostly all forward. I use them over the aileron/flap juncture. They are small enough to be carried easily in most gliders. I also carry JJ's wing tip detachable wheel, another great JJ product, for aeroretrieves from dirt strips without wing runner. Both kits can be carried easily in my 27 compartment. I recently landed at Minden and used the tie downs without wing stands. The wind was calm when I landed but started blowing at dawn and was gusting over 30 when I arrived at the airport. It even blew the wind sock away, but the tie downs held nicely with no harm to the wings. JJ's tie down kit passed the test :-) Both products are available from Williams Soaring Center: http://store.williamssoaring.com/Mer...tegory_Code=SP Ramy |
On Sep 12, 2:13*pm, Ramy wrote:
On Aug 6, 10:25*am, raulb wrote: I am sorryJJ. *I mis-read the posts. *I didn't realize you were selling these things until after I posted. *I thought I was thumbing my nose at someone else. I've been using JJ's tie-down kit with my ASW27 successfully. The ASW27 does not have otherwise any acceptable method for tie down which I know off. JJ's tie downs can go over the aileron or flaps without damaging them since the force is mostly all forward. Ramy I thread nylon webbing around the divebrake pivot on the -27 (the steel tube that runs between the foreward and aft walls of the box about 1.5 inches down inside the divebrake box itself - not the tube that sticks up and holds the panels) then back down over the leading edge of the wing to whatever I'm tying to - no fabrication required. The same principle applies as for JJ's rig only more so since the webbing comes straight up out of the box, makes a 90-degree turn to follow the top surface of the wing to the leading edge and then straight down to the ground. The force on the divebrake pivot would be straight up if the tiedown comes under tension, but I think most of the force would be tranmitted to the top surface of the wing from surface fricton leaving the residual loads on the pivot relatively low. I also put wingstands under both wings so I am not sinching the dihedral out of my wings. I'm told the factory doesn't recommend tying to the divebrakes, but I suspect they were thinking about wrapping rope around the tubes that stick up when the brakes are deployed - pulling on those would put a lot of torque on the pivot. JJ's design looks good (thanks JJ!) as long as they are ensured of pulling the trailing edge forward along the chord - on a control surface I'd worry that it might deflect upward under tension and hurt something. 9B |
Low wing landing, high wing taking off...oops | [email protected] | Piloting | 1 | May 16th 08 09:41 PM |
Soft field landings - low wing vs high wing aircraft | Justin Gombos | Piloting | 19 | May 23rd 07 05:21 AM |
Books on Military Rotary Wing to Civilian Fixed Wing Transition? | Greg Copeland | Piloting | 5 | May 2nd 07 03:23 AM |
High wing to low wing converts...or, visa versa? | Jack Allison | Owning | 99 | January 27th 05 11:10 AM |
Mylar tape wing seals - effect on wing performance | Simon Waddell | Soaring | 8 | January 1st 04 03:46 PM |
