Lightweight covering of 1/8 inch G1S plywood
Old August 6th 08, 03:26 PM posted to rec.aviation.homebuilt
BobR
Default Lightweight covering of 1/8 inch G1S plywood
The fiberglass being proposed for this is not the standard layup glass
used for normal layups. It is a very light weight (.5 oz) cloth that
is often used in boat construction to cover and protect teak and other
exposed wood. It is so thin and light that it becomes transparent.
Orval Fairbairn wrote:
"Morgans" wrote:
Application is exterior on fuselage.
Personally, I would go with the fiberglass and resin. Fabric and dope
works, but glass should last forever.
Oh, I've been told that the surface under the glass must be as smooth as the
finish you want to achieve.
Too heavy! Doped Ceconite (or Stits) essentially last forever, too, as
long as you keep the bird hangared. And -- you can get a mirror finish,
if you desire. The secret is lots of thin coats of dope, sanded between
coats, then polished.
Remove _'s from email address to talk to me.
Old August 6th 08, 04:25 PM posted to rec.aviation.homebuilt
On Aug 5, 10:04*pm, "Morgans" wrote:
Rich Shankland's Emerald used glass, I believe. *Many Falcos go with glass.
Thanks, Jim - but the Emeraude was covered (all surfaces) with 2.6 oz
Dacron, sealed with Poly-brush, UV'd with Poly-spray, then color
coated with Imron and the trim was clear coated. Since a good percent
of the surface is plywood rather than open framework, I considered
using 1.7 oz fabric on the ply. It would have made for a much more
difficult job, with the extra seams and all; and wouldn't really have
saved enough weight to go to the bother. Besides which, I'd rather
have a seam on the leading edge, wrapped over the curve, doubled, and
then taped. Using two weights of cloth would have meant an extra seam
adjacent to the open bay and right out there in the airstream, trying
to rip open.
I expect it to last at least 30 years if I keep it hangared, at which
time it should be removed to inspect the structure. I have seen
picture of Emeraudes being recovered and the wood rot was enough to
scare me. These were planes that spent their life outside - in
England, no less.
Because the Imron is not susceptible to solvents, as is a doped
finish, I expect the removal of the old fabric will be more of a
chore. Had I used fiberglass cloth and resin, it may have been
impossible to remove without damaging the structure. When it's time to
recover, whoever does the job (I don't expect to be doing such things
when I'm 87) will probably be wishing I had used dope.
Rich S.
Old August 6th 08, 08:50 PM posted to rec.aviation.homebuilt
Morgans[_2_]
Sorry about the false suggestion.
It was another plane at Osh the year I saw yours that I was thinking of, I
guess.
Old August 6th 08, 10:02 PM posted to rec.aviation.homebuilt
Ed Sullivan
On Wed, 6 Aug 2008 15:50:37 -0400, "Morgans"
guess.
Tony Bingelis' Emeraude was covered with Model airplane glass
Old August 7th 08, 03:10 AM posted to rec.aviation.homebuilt
Morgans[_2_]
I can't think of the guy's name, he passed a couple years ago, in his plane.
It was a pink GP-4, named cotton candy, IIRC.
Wasn't that one covered in model airplane glass, also?
I will not put down fabric and dope for covering plywood planes, but the
ones I have seen covered with light glass and resin are the slickest looking
wood planes I have ever seen. They look like well constructed and faired
fiberglass planes, with a mirror finish. Unbelievable, in my opinion.
I'm convinced if I build a wood covered plane, that is the route I will go.
Old August 7th 08, 04:27 AM posted to rec.aviation.homebuilt
Orval Fairbairn[_2_]
You ought to see my and Roy Foxworthy's Johnson Rockets, then.
Plywood/ceconite/dope (all rubbed and polished)
Old August 7th 08, 01:13 PM posted to rec.aviation.homebuilt
Stealth Pilot[_2_]
On Wed, 6 Aug 2008 08:25:49 -0700 (PDT),
to rip open.
England, no less.
Rich S.
Rich yours is the preferred method of covering ply as in the original
request. if you use polytone paint the surface remains infinitely
repairable.
even at 87 you'd be able to do the recover job (set that as one of
your life's targets :-) )
if you use MEK as the solvent the finish and the fabric can be taken
back to the wood quite easily.
in fact for polyfiber finishes MEK is a damned handy tool. you can
wipe the finish back to the fabric in a flash even after 20 years.
you can reapply it quite easily back to a concourse finish.
for the original poster, ignore the other suggestions, what Rich has
described is the optimum way of achieving a manageable long life
finish. using dope is a dumb idea.
(of course there will be a hundred posts disagreeing with this :-) )
Stealth Pilot
(who will go to hell for using enamel paint in repairs before
realising that it was going over polytone ..aaargh!)
Old August 7th 08, 02:06 PM posted to rec.aviation.homebuilt
Morgans[_2_]
If I did, what would I observe?
Old August 7th 08, 03:51 PM posted to rec.aviation.homebuilt
A finish that competes with the heavier glass/epoxy you recommend.
Old August 8th 08, 05:45 AM posted to rec.aviation.homebuilt
Tom Wait
plane.
It ws Jackie Yoder. He died in May 2002 flying Cotton Candy. It doesn't seem
like 6 years ago. His brother was with him and died in the crash also. Jack
was a great guy. Funny you should mention him, I was thinking about him last
Friday while watching departures from Homebuilt Headquarters. I don't know
if the plane was covered with glass, but it was a nice aircraft. There is an
article in the SA archives about it.
looking
go.
I agree. The glass cloth eliminates the need for aluminum bearing paint (
poly spray)to protect dacron from UV.
Tom
lightweight headset John T Piloting 4 July 5th 06 05:44 PM
NEED: Source for 2 pcs Aluminium Plate 1 Inch x 4 inch 5 foot length Spar Home Built 4 March 11th 04 11:31 PM
NEED: Source for 2 pcs Aluminium Plate 1 Inch x 4 inch 5 foot length Spar Aviation Marketplace 4 March 11th 04 11:31 PM
NEED: Source for 2 pcs Aluminium Plate 1 Inch x 4 inch 5 foot length Spar General Aviation 4 March 11th 04 11:31 PM
lightweight helmet Joa Home Built 16 January 14th 04 08:59 PM
