B-17s at Low Level
Old March 14th 04, 02:31 PM
Not that it applies to the B-17, but I would think that unless hydraulic
flaps were preloaded (spring or other or were heavy) to extend without
hydraulic pressure, the airflow would keep them retracted until airspeed
decreased or even until the a/c got on the ground. As for the gear,
unless it was kept in the retracted position by hydraulic pressure
alone, as on many modern light aircraft, the mechanical uplocks would
keep the gear up. Also, depending on gear door operation, the airflow
could very well keep the doors closed, or at least partially closed,
until airspeed decreased. Lack of pressure could also just allow the
doors to stay closed & the gear stay up regardless, depending upon how
they're actuated.
Old March 15th 04, 05:45 PM
M. H. Greaves
I remember seeing on T.V. that the B17 had like big long screw gears/rods
that raised and lowered the u/c in that case the u/c would have been
electrically operated wouldnt it!?? i.e. not hydraulically operated.
they're actuated.
Old March 15th 04, 07:53 PM
Dale
Correct, it's a jack screw that operates the gear and it is powered with
an electric motor....the same motor used to power the flaps...and the
tailwheel. Each gear has it's own motor.
Dale L. Falk
There is nothing - absolutely nothing - half so much worth doing
as simply messing around with airplanes.
http://home.gci.net/~sncdfalk/flying.html
Old March 14th 04, 03:21 PM
N329DF
Unless of course the hydraulic system has been shot out in which case both
flaps and landing gear would be down. As I vaguely remember it that
hydraulic
sytem in a B-17 worked off one engine.I don't remember which one. But I
might
be wrong about that,
You are, the only hydraulics on a -17 are cowl flaps and brakes, everything
else is electric. Boeing was even thinking ahead, all the gear and bombay
motors were the same.
Matt Gunsch,
A&P,IA,Private Pilot
Riding member of the
2003 world champion drill team
Arizona Precision Motorcycle Drill Team
GWRRA,NRA,GOA
Old March 12th 04, 03:11 PM
Mortimer Schnerd, RN
WalterM140 wrote:
Hi,
I am building a diorama with a 1/48th scale B-17 at low altitude. It will
have two engines turning and two shut down.
My question is, would a B-17 have its landing flaps deployed at all at this
lower speed and altitude if it was not landing, just hedge-hopping home? And
if so, how much?
No.... if I were flying a four engined aircraft with two fans out, the flaps
wouldn't drop out until short final. He's already in serious trouble; any added
drag might be the straw that breaks the camel's back.
http://www.mortimerschnerd.com
Old March 13th 04, 12:40 AM
WalterM140
And
if so, how much?
added
Okay, that's one less thing to think about.
The way I see it now, the base of the diorama will be the coast line of
Belgium, with the Fort just "leaving" Festung Europa with all deliberate speed.
Walt
Horsepower required for level flight question... BllFs6 Home Built 17 March 30th 04 12:18 AM
Q for Jim Weir or others: solid state fuel level probes? Charlie England Home Built 11 March 12th 04 12:35 AM
Heads up: threat level going to orange richard riley Home Built 6 December 23rd 03 10:49 PM
