What are the forces on a tied down glider?
Old August 14th 08, 12:05 AM posted to rec.aviation.soaring
Default What are the forces on a tied down glider?
There is no hard data on tie down strength. Just plan for the worst.
PolyPro will lose most of its strength rapidly from UV. Good covered
climbing rope and locking carabiners are the best bet.
Old August 14th 08, 01:10 AM posted to rec.aviation.soaring
Nyal Williams[_2_]
Back in the 60s someone wrote in Soaring about tying two-by-fours
along the tops of wings to act as spoilers. I've never seen it, but this
is strictly a "for at-home" solution if it works. Boards would need to
be stabilized in some way, of course.
Old August 14th 08, 01:13 AM posted to rec.aviation.soaring
Capt. Geoffrey Thorpe
"Andy" wrote in message
Others would say why worry - put it in the box!
"Glider trailers parked on the field were crushed from being tossed about
like dice."
(to be fair "The hangar right across the alleyway had it's roof and walls
blown off.")
http://iac78.org/newsletter/NL%20Fal...05%20Color.pdf Page 8.
Now, can someone explain why I can remember (and find) something I read
nearly 3 years ago, but I can't remember what I was doing on Friday when I
get back to work on Monday?
Geoff
Old August 14th 08, 01:25 AM posted to rec.aviation.soaring
Don Johnstone[_3_]
I used to leave my ASW17 with a trestle under each wing, to stop them
moving and ties the tail down. I also left it in full negative flap which
meant that it would not lift.
If the wind was forecast to be more than 30 knots it went in it's box
although I was caught out a couple of times with unexpected wind speeds of
up to 60 knots, it never moved.
I suspect with speeds of 100kts you would be luck to find the glider
intact even if the tie down held, and even in the trailer it would be at
risk.
Old August 14th 08, 02:46 AM posted to rec.aviation.soaring
Eric Greenwell
Doug Hoffman wrote:
Seems like wing and tailfeather covers should help some. Maybe
a lot. The full covers I've seen (Jaxida) hang down a lot of
covering beneath the wings and horizontal stabs/elevators. To my
eye the covers might be far more effective than even open
spoilers in destroying lift.
My observation is the the wind puffs up the covers so they stand
completely off the top and bottom of the wing. In a strong wind, the
covers look like they are inflated to a high pressure, making the wing
look more like a sausage than anything else. My guess is this is a high
drag, low lift "airfoil", but I have no documentation for it.
It also provides protection from hail, which just bounces off the taut
wing covers and never gets near the wing skin.
Old August 14th 08, 03:55 AM posted to rec.aviation.soaring
bumper
news:x7Mok.925$xv.899@trnddc02...
My observation is similar . . . except to me, the puffed up covers look like
the thick, high lift wing on a trainer.
I'd feel a lot better about covers in high winds if there were spanwise
fabric tubes sewn in to allow pipe foam insulation to be inserted for full
length spoilers.
bumper
zz
Minden
USA
Old August 14th 08, 04:10 AM posted to rec.aviation.soaring
Darryl Ramm
fabric tubes sewn in to allow pipe foam insulation *to be inserted for full
length spoilers.
bumper
zz
Minden
USA
The standard Jaxida covers look like this in the wind...
http://www.flickr.com/photos/darrylramm/517165653/
http://www.flickr.com/photos/darrylramm/517140648/
(maybe it was really faster than 20 knots in these photos).
Does Jaxida offer a sewn in place to insert a foam tube?
Darryl
Old August 14th 08, 04:31 AM posted to rec.aviation.soaring
Doug Hoffman
Andy wrote:
On Aug 13, 11:01=A0am, Eric Greenwell
I see gliders tied down in a bewildering variety of ways,
all apparently
"adequate" in the owner's mind.
Perhaps the real question is how well does it have to be tied
down to
satisfy the insurance company that you were not negligent.
Another significant factor is what is it tied too. We seem to
take
for granted that tie down wires etc that we find at the
airport are
secure, but I've seen a whole line of cable and the anchors
pulled out
of the ground. I used to trust the rings on the ramp at Hobbs
until
one year I cleared all the dirt out of the hole and found the
rings
corroded almost all the way through. Last time I flew there I
dug
around until I found a good one and tied the CG hook to it.
Doug
** Posted from http://www.teranews.com **
Old August 14th 08, 04:44 AM posted to rec.aviation.soaring
Eric Greenwell
length spoilers.
bumper
zz
Minden
USA
My covers are not Jaxidas, but are similar in design using a lighter
material (a type of Tyvek). They bulge more evenly on the top and bottom
than Darryl's Jaxida covers. Perhaps Darryl could slide one cover off
it's wing to determine if the other wing is lifting or not? It's not so
easy for me to do that because my covers attach to each other, not a
center section like the Jaxidas.
Old August 14th 08, 07:25 AM posted to rec.aviation.soaring
Bruce
How interested you were in Friday?
about like dice."
walls blown off.")
I get back to work on Monday?
FAA: FUNDING TIED TO MODERNIZATION Larry Dighera Piloting 1 March 28th 07 05:46 PM
Anti-Av Forces john smith Piloting 1 November 19th 05 06:27 PM
Delco unit tied to Chinook Otis Willie Military Aviation 0 July 20th 04 10:11 PM
airbrake position while tied outside CK Soaring 18 January 19th 04 02:34 PM
