On Aug 15, 8:08 pm, "BT" wrote:
Don't forget the CG change.. losing 14# on the nose is a lot.. you are going to be tail heavy BT "Charles Talleyrand" wrote in message ... On Aug 15, 3:10 pm, "Vaughn Simon" wrote: "Charles Talleyrand" wrote in message ... Suppose I put this prop on my Cessna 150. It only weighs 9.5 pounds, as compared to the Sensenich weight of 24 pounds. So I save 14.5 #. But it will make a largish change in your CG. The fuel and passenger load for a 150 are both near the CG, so you might end up putting a few pounds of ballast in the tail to stay within the CG envelope. That would cost you some of the initial weight advantage. Can anyone guess how this would effect my performance? How much better climb and how much better cruise? Nobody can answer that question until you specify a pitch. Any given fixed pitch prop will be optimized for climb (at the expense of cruise speed) or cruise (at the expense of takeoff and climb performance) or somewhere in between. Actually, one can assume that it will climb at least as well as the standard climb prop, and cruise at least as well as the standard cruise prop. The difference between the cruise (normal) prop climb performance, and the climb prop climb performance, will be available to cruise prop users. The difference between the climb prop cruise performance, and the cruise prop cruise performance, will be available to climb prop users. Anyone know these numbers? Alternatively, there must be planes that have used both fixed and constant-speed props. Anyone know the difference? Can always make a spinner out of lead:-) I don't like Ivo. We had one on a Glastar and couldn't balance the thing because the blades wouldn't stop shifting chordwise in the hub. And that was on a redrive, not the more brutal direct-drive applications. They're not that efficient, either, since the pitch change is mostly outboard on the blades. There have been some issues with blades leaving the hub or the torque rods pulling right out of the blades. Those blades are a high-density foam with only the thinnest skin of carbon fiber on them, and the bolt bushings are therefore held in mostly by foam. Not for me. We put a Warp Drive on the airplane and it was much smoother, though adjusting the pitch was much more work. A Cessna 150 isn't likely to gain a lot of performance from an adjustable prop. The airframe is too draggy and the engine too anemic. Dan |
On Fri, 15 Aug 2008 14:35:38 -0700 (PDT), Charles Talleyrand
wrote: On Aug 15, 3:10 pm, "Vaughn Simon" wrote: "Charles Talleyrand" wrote in message ... Suppose I put this prop on my Cessna 150. It only weighs 9.5 pounds, as compared to the Sensenich weight of 24 pounds. So I save 14.5 #. But it will make a largish change in your CG. The fuel and passenger load for a 150 are both near the CG, so you might end up putting a few pounds of ballast in the tail to stay within the CG envelope. That would cost you some of the initial weight advantage. Can anyone guess how this would effect my performance? How much better climb and how much better cruise? Nobody can answer that question until you specify a pitch. Any given fixed pitch prop will be optimized for climb (at the expense of cruise speed) or cruise (at the expense of takeoff and climb performance) or somewhere in between. Actually, one can assume that it will climb at least as well as the standard climb prop, and cruise at least as well as the standard cruise prop. The difference between the cruise (normal) prop climb performance, and the climb prop climb performance, will be available to cruise prop users. The difference between the climb prop cruise performance, and the cruise prop cruise performance, will be available to climb prop users. Anyone know these numbers? for the 150... 48" pitch climb 50" pitch normal 52" pitch cruise look at it this way. your aircraft will be the only cessna in existence with a solid lead spinner to get the cg right. :-) Stealth pilot |
I would think he would need extra weight in the nose.. not in the tail.
BT "Vaughn Simon" wrote in message ... "Charles Talleyrand" wrote in message ... Suppose I put this prop on my Cessna 150. It only weighs 9.5 pounds, as compared to the Sensenich weight of 24 pounds. So I save 14.5 #. But it will make a largish change in your CG. The fuel and passenger load for a 150 are both near the CG, so you might end up putting a few pounds of ballast in the tail to stay within the CG envelope. That would cost you some of the initial weight advantage. Can anyone guess how this would effect my performance? How much better climb and how much better cruise? Nobody can answer that question until you specify a pitch. Any given fixed pitch prop will be optimized for climb (at the expense of cruise speed) or cruise (at the expense of takeoff and climb performance) or somewhere in between. -- Vaughn Nothing personal, but if you are posting through Google Groups I may not receive your message. Google refuses to control the flood of spam messages originating in their system, so on any given day I may or may not have Google blocked. Try a real NNTP server & news reader program and you will never go back. All you need is access to an NNTP server (AKA "news server") and a news reader program. You probably already have a news reader program in your computer (Hint: Outlook Express). Assuming that your Usenet needs are modest, use http://news.aioe.org/ for free and/or http://www.teranews.com/ for a one-time $3.95 setup fee. Will poofread for food. |
On Aug 15, 1:46*pm, Charles Talleyrand wrote:
I notice that there are Ivoprop makes an in flight adjustable propeller suitable for a an o-200 engine. I understand that putting this prop on my C-150 is illegal. *But suppose ... If Ivoprop makes an adjustable prop for the O-200 it seems there would be an STC for a conversion. Is there not? !50s & 152s have so many STCs available. Ricky |
On Aug 15, 11:41 pm, Ricky wrote:
On Aug 15, 1:46 pm, Charles Talleyrand wrote: I understand that putting this prop on my C-150 is illegal. But suppose ... If Ivoprop makes an adjustable prop for the O-200 it seems there would be an STC for a conversion. Is there not? !50s & 152s have so many STCs available. Ricky IVO isn't a certified propeller, and you can't get an STC to install an uncertified prop. Until it's certified there won't be any STC. IVO and Warp Drive and a bunch of other props are aimed exclusively at the kitplane, homebuilt and unltralight market. Dan |
Ground adjustable prop | [email protected] | Home Built | 1 | January 30th 05 06:15 AM |
adjustable prop bearing | Joe | Home Built | 5 | October 23rd 04 12:00 PM |
Cessna Prop Needed | Cy Galley | Aviation Marketplace | 0 | January 23rd 04 01:23 AM |
Hydraulic CS prop converting to Adjustable prop? | Scott VanderVeen | Home Built | 0 | December 5th 03 05:54 PM |
Adjustable prop experience? | Richard Lamb | Home Built | 0 | July 1st 03 04:07 AM |
