#11
![]() "monkey" wrote in message om... "Tarver Engineering" wrote in message ... "monkey" wrote in message om... "Tarver Engineering" wrote in message ... "BUFDRVR" wrote in message ... Face it - a non-stealthy combat aircraft is obsolete. I think you may be over stating that point a bit Walt. There's still years and years of play for non-stealth (and in the case of the BUFF, anti-stealth) aircraft. In fact, the addition of the F/A-22 ensures that. An F-15 life extension is a near certainty now. A lot of people will be crying into their beer after an F-15 lifex - that is just not an effective plan these days. We did that with our Hornets, and even with centre barrel replacement there are TONS of serviceability problems. There aren't enough F-22s to replace the F-15 and the F-35 is sliding further away. The options are to life extend the F-15, or have the USAF buy F/A-18Es. If we wait until the F-15s start falling out of the sky, then they will all be gounded. Besides that, the F-18 life extension doubled the usable life of the F/A-18As. I agree with the fact that something has to be done...however in my experience flying military jets "life extension" is a huge misnomer. Yes, the life of the airframe is "extended." But the fact of the matter is that our older "life extended" jets have a very low fatigue tolerance and as such have a very low g limit, as well as severe store carriage limitations. Yes, the jets are still flying, but you'll find that a lot of them are useless for anything except ifr training and cross countries. But hey, what can an air force do-until the new jets come on line or they get more money, they will have to stick with flying older aircraft less, and restricting the mission types. If only the F-22 had been cancelled in '98 ... |
Kevin Brooks wrote:
"Buzzer" wrote in message ... snip In th 60s skin-painting Buffs at 75 to 125 miles while they were down at 250 ft.? I don't believe the B-52's were typically down in the weeds during the sixties, when the force still included a lot of C, D, and F models--they were still doing a lot of higher altitude work. Like in Vietnam. SAC certainly would have been down in the weeds in the '60s when feet dry over the FSU if executing the SIOP (or training for it), which is what Buzzer was referring to. But I'm sure Walt was referring to ranges on them during enroute high altitude cruise. Guy |
![]() "Guy Alcala" wrote in message . .. Kevin Brooks wrote: "Buzzer" wrote in message ... snip In th 60s skin-painting Buffs at 75 to 125 miles while they were down at 250 ft.? I don't believe the B-52's were typically down in the weeds during the sixties, when the force still included a lot of C, D, and F models--they were still doing a lot of higher altitude work. Like in Vietnam. SAC certainly would have been down in the weeds in the '60s when feet dry over the FSU if executing the SIOP (or training for it), which is what Buzzer was referring to. But I'm sure Walt was referring to ranges on them during enroute high altitude cruise. Depends on when in the sixties, AFAIK. I ran across one former B-52 pilot's comments that the transition to the lower level profile, at least in his case, happened during the "early sixties"; FAS indicates it happened earlier than that, but then again FAS folks were not flying them... :-) Of course a lot of the B-52 force during the sixties were lugging Hound Dogs, which would have been launched from altitude in most cases and did not require a low-altitude penetration. The point was that Walt's comment about acquiring the B-52's was valid. Brooks Guy |
Non-stealthy aircraft were pigeons back in the 60s. That's when our
F102s were skin-painting Buffs at 75 to 125 miles. And with the IR the EWO hadn't a clue we were sneaking up on them, because we didn't lock on with our radar, we just intercepted them by eyeballing the rate of change of range and azimuth. Even the Forbes RB47Es with their cute gadgets were toast. All the jamming ever did was shout out real loud 'here I am!' Now, with look-down radar, even getting down in the weeds isn't a sure-fire way to survive. As for out over the water - lots of luck, GI. And at night - stealth's the only way to go. I've said before that at night the non-stealthy airplane might as well have all his lights on bright flash. Granted, stealthy airplane can be seen on radar - but way before he is detected he's already picked up and maneuvered to attack the non-stealthy bird. Just like way back when we had radar and the day fighters did not. Walt BJ - BT,DT Walt, if it were that easy to pop non-stealth aircraft, surely we would have lost more than we have (by an order of magnitude) since '91. The grand champion RCS of all time has suffered exactly zero losses and only 1 damaged in well over 1,000 missions over Iraq x 2 and Yugoslavia. In fact, more stealth aircraft have been downed than B-52s. BUFDRVR "Stay on the bomb run boys, I'm gonna get those bomb doors open if it harelips everyone on Bear Creek" |
sixties, when the force still included a lot of C, D, and F models--they were still doing a lot of higher altitude work. Like in Vietnam. The terrain avoidance radar was not installed until early 1970's (1973??). This is not to say you couldn't fly low visually, but I don't believe low level was a common practice until the 70s. BUFDRVR "Stay on the bomb run boys, I'm gonna get those bomb doors open if it harelips everyone on Bear Creek" |
BUFDRVR wrote:
Walt, if it were that easy to pop non-stealth aircraft, surely we would have lost more than we have (by an order of magnitude) since '91. The grand champion RCS of all time has suffered exactly zero losses and only 1 damaged in well over 1,000 missions over Iraq x 2 and Yugoslavia. In fact, more stealth aircraft have been downed than B-52s. SEAD has gotten a lot better since Vietnam? -HJC |
On 18 Mar 2004 22:19:52 GMT, (BUFDRVR) wrote:
I don't believe the B-52's were typically down in the weeds during the sixties, when the force still included a lot of C, D, and F models--they were still doing a lot of higher altitude work. Like in Vietnam. The terrain avoidance radar was not installed until early 1970's (1973??). This is not to say you couldn't fly low visually, but I don't believe low level was a common practice until the 70s. Bomb-nav maintainer might disagree with you about when the TA was installed. (This is just the earliest date I could find..) http://www.bombnav.org/guestbook.html "Did infinite T/A alignment long first then 24hrs short method Dec 1962 Carswell AFB TX." http://www.fas.org/nuke/guide/usa/bomber/b-52_hist.htm "Although the new low level requirement would apply to the other SAC bombers, it would have its greatest impact upon the B-52. To fly the new attack profile, the B-52C through H models were modified with a new terrain avoidance radar, an improved radar altimeter, increased cooling capacity for sustained low altitude operations, modified equipment mounts, and a general strengthening of the aircraft's secondary structures. The goal was to permit reliable, all-weather operation at 500 feet, to avoid detection, and to minimize encounters with enemy defenses. Low level training for SAC bomber crews began in the late 1950's, with actual aircraft modification beginning in 1961." |
Buzzer wrote:
On 18 Mar 2004 22:19:52 GMT, (BUFDRVR) wrote: I don't believe the B-52's were typically down in the weeds during the sixties, when the force still included a lot of C, D, and F models--they were still doing a lot of higher altitude work. Like in Vietnam. The terrain avoidance radar was not installed until early 1970's (1973??). This is not to say you couldn't fly low visually, but I don't believe low level was a common practice until the 70s. Bomb-nav maintainer might disagree with you about when the TA was installed. (This is just the earliest date I could find..) http://www.bombnav.org/guestbook.html "Did infinite T/A alignment long first then 24hrs short method Dec 1962 Carswell AFB TX." http://www.fas.org/nuke/guide/usa/bomber/b-52_hist.htm "Although the new low level requirement would apply to the other SAC bombers, it would have its greatest impact upon the B-52. To fly the new attack profile, the B-52C through H models were modified with a new terrain avoidance radar, an improved radar altimeter, increased cooling capacity for sustained low altitude operations, modified equipment mounts, and a general strengthening of the aircraft's secondary structures. The goal was to permit reliable, all-weather operation at 500 feet, to avoid detection, and to minimize encounters with enemy defenses. Low level training for SAC bomber crews began in the late 1950's, with actual aircraft modification beginning in 1961." What the man said. BUFDRVR, pull out your copy of Boyne and look up "Advanced Capability Radar" in the index. Boyne says the Hs got them first, but they were backfit to the D, F and G. Guy |
On Thu, 18 Mar 2004 15:19:53 -0500, "Kevin Brooks"
wrote: The point was that Walt's comment about acquiring the B-52's was valid. Only if he knew what their location would be within 125 miles before he took off.G |
![]() "Guy Alcala" wrote in message . .. Buzzer wrote: On 18 Mar 2004 22:19:52 GMT, (BUFDRVR) wrote: I don't believe the B-52's were typically down in the weeds during the sixties, when the force still included a lot of C, D, and F models--they were still doing a lot of higher altitude work. Like in Vietnam. The terrain avoidance radar was not installed until early 1970's (1973??). This is not to say you couldn't fly low visually, but I don't believe low level was a common practice until the 70s. Bomb-nav maintainer might disagree with you about when the TA was installed. (This is just the earliest date I could find..) http://www.bombnav.org/guestbook.html "Did infinite T/A alignment long first then 24hrs short method Dec 1962 Carswell AFB TX." http://www.fas.org/nuke/guide/usa/bomber/b-52_hist.htm "Although the new low level requirement would apply to the other SAC bombers, it would have its greatest impact upon the B-52. To fly the new attack profile, the B-52C through H models were modified with a new terrain avoidance radar, an improved radar altimeter, increased cooling capacity for sustained low altitude operations, modified equipment mounts, and a general strengthening of the aircraft's secondary structures. The goal was to permit reliable, all-weather operation at 500 feet, to avoid detection, and to minimize encounters with enemy defenses. Low level training for SAC bomber crews began in the late 1950's, with actual aircraft modification beginning in 1961." What the man said. BUFDRVR, pull out your copy of Boyne and look up "Advanced Capability Radar" in the index. Boyne says the Hs got them first, but they were backfit to the D, F and G. Actually, Guy, the man said the C models also got it. FAS as a source is not infallible, though in this case it remains unclear a sto which models got it and when they actually got it. If the aircraft did start getting T/A radars in 1961, it would have taken some time to outfit the remainder of the fleet, which IIRC was pretty darned big at that time. Your list also does not include the E models, which continued in service until the '69-70 timeframe. Another interesting item is the fact that throughout the sixties a large number of B-52's retained the silver upper/anti-flash white lower finishes, which was hardly a very good scheme for a low altitude penetrator. This all leads me to suspect that the "everything went to low level at the beginning of the sixties" bit may be another case similar to the old "all the B-29's stripped their armament per LeMay's orders" story--only partly correct, in other words. Brooks Guy |
Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 40 | October 3rd 08 03:13 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | October 1st 04 02:31 PM |
Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 0 | September 2nd 04 05:15 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | May 1st 04 07:29 PM |
Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 04:50 PM |
