breaking news russian nuclear warship set to explode
Old March 24th 04, 06:54 PM
Buzzer
On Wed, 24 Mar 2004 11:43:54 -0600, Alan Minyard
On Wed, 24 Mar 2004 02:14:38 GMT, "Gord Beaman" ) wrote:
(Krztalizer) wrote:
v/r
Gordon
PS, I agree - I doubt if his material condition would be bad enough to make it
blow up, any more so than any other boat.
I doubt that there's much danger of it "blowing up" (as in a
nuclear reaction) but as I understand it there may be a danger of
any poorly maintained Nuclear Vessel to have a failure in some
critical area of the reactor which could heavily contaminate the
vessel making it unfit for human habitation (bigtime). So there
you are...what to do now? How safe is it to 'deep six' such a
vessel?
Several nuke subs have gone down, with no evidence of any
negative impact on the environment (Thresher, Scorpion, unknown
number of Russian boats).
Hopefully in a hundred years your childrens children will be able to
say the same thing after seawater has had more time to eat away at the
housings of nuclear torpedoes containing plutonium.
Old March 25th 04, 02:07 AM
Dave Holford
Assuming that there really are plutonium warheads in torpedoes on those
vessels; does anyone here know what the half-life of those isotopes
might be? It is my understanding that nuclear and thermonuclear warheads
have to be refurbished on a regular schedule; and I understood that was
due to the radioactive decay of the isotopes used.
I know there are isotopes with half-lives in the thousands of years etc.
But I am asking about those used in weapons.
Dave
Old March 25th 04, 02:59 AM
On Wed, 24 Mar 2004 21:07:19 -0500, Dave Holford
"half-life for plutonium-239 is 24,000 years"
google +submarine +torpedo +plutonium +"24,000"
Cut off the 24,000 for more hits..
I believe the refurb is for the tritium trigger.
http://www.acronym.org.uk/dd/dd67/67nr04.htm
google +tritium +trigger +nuclear
Old March 25th 04, 03:48 AM
Steve Hix
Dave Holford wrote:
I'm not a weapon designer, nor do I play one on tv. (College, and my
partial physics minor, was 30 years ago...so why should I stop now?)
might be?
The plutonium part of the devices is Pu239 (~93%), Pu240 (~6.5%), and a
trace of Pu241 (~.05%). Their half-lives are, respectively; 24,110 yrs,
6,537 yrs., and 14.4 yrs.
IIRC, some current weapons may use Tritium (hydrogen with two neutrons
in the nucleus, slightly radioactive, sometimes used in things like
night sights for pistols, or wris****ch backlights) as part of a trigger
to boost the efficiency of fission-fusion bombs, it has a half-life of
12.3 years. (More may use LiD as a more convenient source of hydrogen;
neutrons from the fission "fuse" convert some of the Lithium to
deuterium and a bit of tritium, which will enhance the yield of the
overall reaction.)
Old March 28th 04, 10:11 PM
Tarver Engineering
"Dave Holford" wrote in message
It is the tritium used to create a population inversion prior to detonation
that limits the lifetime of the trigger, but plutonium will burn quite
violently as soon as it finds oxygen.
Old March 30th 04, 05:11 AM
Ad absurdum per aspera
Plutonium can be dreadful stuff if it's in a highly bioavailable
chemical state and/or a physical form that gets into the body,
especially the lungs, and lodges there. Whether macroscopic hard
integral shapes of plutonium metal are nearly as big a deal is
another question (especially deep underwater, rather than exposed to
the atmosphere.
The worry quotient depends also upon where they are in the ocean:
depth, hydrologic and geologic activity, and proximity to land.
Remember, the various nuclear-armed nations have actually fired quite
a number of weapons for test purposes, some of them quite large
(multimegaton), under and just above the ocean. This in addition to
all the chemical dumping, agricultural runoff, oil spills, etc. that
have occurred and continue to occur. If only man had stunk up the
sea so *little* that the innards of the odd "broken arrow" made a big
contribution!
Anyway, quite a bit of thought has gone into the problem of disposing
of high-level waste, and much of it is applicable to intact or broken
weapons shapes from the arms control effort and thus is first cousin
to lost weapons. Nonproliferation as well as short- and long-term
environment, health, and safety issues are considered there.
One of these methods is sub-seabed disposal in hydrologically and
geologically quiet areas where the bottom is covered with deep mud.
(This should not be confused with an older, apparently abandoned idea
involving deliberate introduction of the materials into deep-ocean
subduction zones.) Admittedly these ideas envision either drilling
or kinetic penetration so as to emplace the materials some meters into
the mud; and also some form of containment. See for instance page 200
et seq. of
http://books.nap.edu/html/plutonium/0309050421.pdf
However, it goes to show how the deep ocean can under some
circumstances be regarded in this context.
See also
http://www.llnl.gov/csts/publications/sutcliffe/
regarding what happens to plutonium in water (albeit with an emphasis
on relatively shallow fresh water; salt water under many many
atmospheres of pressure might be different).
Finely divided plutonium and/or plutonium dispersed in a fire is a
much bigger deal to those who get caught in the plume -- in the
atmosphere. The reason is that plutonium has the interesting property
of being a lot more reactive in small pieces than large. This is part
of the reason why physically energetic weapons accidents (e.g., bombs
lost from aircraft) present a special risk, and why insensitive
explosives were eventually developed for use in nuclear weapons.
Anyway, the reactor plant found in most of the same subs and ships is
probably a lot more significant as a hazard than are the weapons pits,
as long as the stuff is presumptively out of the reach of terrorist
organizations and aspiring nuclear states. On that subject, the
ability to find and salvage such an item in deep water far from land,
even if you start with a decent general idea of where it is, is not a
technically or economically trivial task.
In my personal opinion, if you are so unfortunate as to lose custody
of either a weapon or a reactor, losing it intact in the deep ocean
seems not nearly as bad as some of the other possibilities.
Cheers,
--Joe
Enola Gay: Burnt flesh and other magnificent technological achievements me Military Aviation 146 January 15th 04 10:13 PM
15 Dec 2003 - Today’s Military, Veteran, War and National Security News Otis Willie Military Aviation 0 December 15th 03 10:01 PM
Warszaw Pact War Plans ( The Effects of a Global Thermonuclear War ...) Matt Wiser Military Aviation 0 December 7th 03 08:20 PM
27 Nov 2003 - Today’s Military, Veteran, War and National Security News Otis Willie Military Aviation 1 November 30th 03 05:57 PM
18 Sep 2003 - Today’s Military, Veteran, War and National Security News Otis Willie Military Aviation 0 September 19th 03 03:47 AM
