Jet Engine Thrust Question
Old October 3rd 08, 01:39 AM posted to rec.aviation.piloting
Tman
Default Jet Engine Thrust Question
Bertie the Bunyip wrote:
Actually, it does. It's moving a lot of air from one end to the other an
also producing quite a bit of heat.
Guess by that definition Bertie is actually employed!
Old October 3rd 08, 02:25 AM posted to rec.aviation.piloting
....and Congress works, QED?
Please reconsider.
Old October 3rd 08, 07:19 AM posted to rec.aviation.piloting
Bertie the Bunyip[_24_]
Tman x@x wrote in :
an also producing quite a bit of heat.
Mmm, not a million miles form the truth,I suppose..
No more so than for anyone else in my trade, though...
Fly somewhere, whine and bitch. fly somewhere else, whine and bitch. ..
Bertie
Old October 2nd 08, 06:02 PM posted to rec.aviation.piloting
Panic
The only time you have to have more thrust than aircraft weight is if you
plan to take off vertically with no takeoff run.
"Darkwing" theducksmail"AT"yahoo.com wrote in message
How does rated thrust for a jet engine translate to actual power? I guess
my question is, for example, a Cessna Mustang has two engines that produce
1,460 lbs of thrust each (x 2) so the total is 2920 lbs of thrust for the
two engines. The takeoff weight for the Mustang is listed as 8,645 lbs. so
the engines are only putting out a 1/4 of the total aircrafts weights. So
do they rate thrust different to the actual weight that the engines can
fly? Is the reason that is does only produce 2920 lbs. of thrust but the
wing is what actually makes the plane fly so the thrust doesn't need to
equal weight?
thrust line for engine and not mounting engine on this thrust line tommyann Home Built 8 December 15th 06 03:31 PM
Propeller thrust question xerj Piloting 11 November 25th 05 03:12 AM
Engine question Max Richter Naval Aviation 13 August 29th 05 05:07 AM
Shutting down engine Question Lisa Piloting 26 April 5th 04 12:53 AM
Stupid hp to thrust question Mark Home Built 52 December 9th 03 01:41 PM
